what can I do in below situation
It has been a year that I have been searching for a water pump which can transfer heating water (<100C) and 220V. I bought 3 pumps, to use them for home brewing, but not one of them is working properly. I would like to post you a photo of my pumps and if anyone can give me any syggestions about what I am doing wrong I would appreciate it.
RE: what can I do in below situation
Not pumping, not enough fliw, not enough pressure, motor keeps tripping, ???
These look like central heating pumps?
What is data? (Fliw, head etc)
What flow or pressure do you need?
These pumps won't"lift" very well and usually work under pressure in a closed circuit.
When three different new technical items all are not working like intended, you are probably not using them according to the correct technical limitations.
For pumps check: fluid conditions (degree/type of particles in fluid, sugar, alcohol), temperature, alcohol,compatibility of sealing and other materials to fluid, correct start (wet or dry), sucking height and pumping height, cleaning after use, lubrication and maintenance.
Sugar or residues on components?
Would help to write up a technical description of how, what, where, why - - give us something to look at.
Please describe your system. I see that you have an "automatic brewing pot" there, so I'm kinda confused on why you would need an extra pump. Are you using this pump to move the sparging water?
I use an HERMS system with a regular sanitary pump and have to yet encounter a problem with the system (apart from my brewing friends destroying the pump's seal one time by restricting the inlet - someone call the pump police please).
So, again, describe exactly what you are trying to accomplish with your pump and then we can think of a solution.
