Using membrane elements on Tetra Hedeal mesh
Hello All,
Thank you for your time and help. I have one more question for you,
Its about adding a surface layer of membrane elements with negligible thickness on tetra elements.
May I know the reason for reading stress results on membrane elements?.
I would appreciate your ideas.
Kind regards,
RE: Using membrane elements on Tetra Hedeal mesh
Membrane elements are used with solids to represent thin layers such as membranes in geocell soil mechanics analyses. Another common use is for post-processing reasons - to extract plane stress state from the outer surface of the model and perform some specific operations on this data.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
