Trim Body Help 1
BrittToolEngineer
Aerospace
Greetings:
I have a block of model that I am attempting to trim body with an extracted sheet body from part geometry. I've been successful at (3) sides, but the 4th is not cooperating. Can someone look at the attached parasolid and help me figure out how I need to create a good trim body to work effectively?
Brent
I had a look.
Found two self intersecting faces and a "odd face".
I replaced the self intersecting faces and added two support faces and a blend. ( i cannot explain why this blend does the trick but sometimes Parasolid needs a little help...)
NX10.
I kept the features such that you can see how i did it.
Tomas
The trim will work if you set your modeling tolerance to .05.
Tomas,
This worked like a charm. I appreciate your helping.
Brent
