WB: External Data with two input files
Trying to import external data and I get “Error Data in the worksheet is invalid. Please correct before proceeding to import.” The External Data is two files, actually the same file entered twice, and the second is rotated 90 degrees. Either file can be imported correctly separately, the problem only occurs when there are two files in External Data. I suppose I could use two external data items, but I have convection to bring in as well and apply it to 45 cooling channels. 45 external datas would be a bit messy. Anybody seen this before?
Rick Fischer
Principal Engineer
Argonne National Laboratory
RE: WB: External Data with two input files
Rick Fischer
Principal Engineer
