Regional Use of ASTM C33 Aggregate in Concrete Mix
3
A building I designed is currently in the bid phase and is located in Omaha, NE, right on the border of Iowa and Nebraska. Our specification on this project (as well as every other project I have done in the area) requires ASTM C33 aggregate for the concrete mix. I was told by a concrete supplier bidding the project that ASTM C33 aggregate is common in central Iowa, but not common in Nebraska. This is the first I have ever heard this comment. I am struggling to find any data that could either support or disprove this claim. Has anyone else in the Omaha area ever heard this comment?
RE: Regional Use of ASTM C33 Aggregate in Concrete Mix
3
ASTM C33 is not a specific aggregate, it "defines the requirements for grading and quality of fine and coarse aggregate (other than lightweight or heavyweight aggregate) for use in concrete."
ACI 318 requires that normalweight concrete use aggregates that conform to ASTM C33 with the following exception: "Aggregates that have been shown by test
or actual service to produce concrete of adequate strength and durability and approved by the building official."
Maybe call the Omaha building department and see if they have any thoughts on the issue.
I find it hard to believe that a reputable supplier would take issue with meeting ASTM C33 requirements for structural concrete.
dauwerda...exactly!
A Great Place For Engineers to Help Engineers
Thanks dauwerda. I agree that it is odd for a supplier to object to this standard. I have a message out to the Omaha Building and Planning Department to see if they frequently approve aggregate that does not meet ASTM C33 requirements. We'll see what they have to say...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
