cuting parameter
savian
Automotive
RO
Can anyone help me with the cutting parameters for a 1000W INANLAR laser.
manufactured has only a few established ... stainless steel, steel ..
I would need to burn the protective film of stainless steel
thank you
I don't know the laser but your nesting software should have a vaporization setting such as engraving to burn the film away first then do a cutting pass. Or just do as I do and peel it off before I load it onto the machine. But then again the finish on the SS isn't critical for what I manufacture.
On my nesting software the setting is in the export settings.
If you ask me to do something, I will do it. There's no need to nag me every 6 months
