Alternative Replacement of Scaffolding at Plant
3
Hi everyone
Let me introduce you overall situation that I am encountering now and hope that there exist alternatives. At refinery, each year we have to perform Non-Destructive Test at pipelines ( near welds, at elbows,after supports and etc.). It means, that at each welds, elbows, support we must build scaffold in order to dismantle insulation and perform Non-Destructive Examinations. As you may understand it costs a lot. Each year more than 1500 pipelines have to be examined. That is why I need some alternative replacement for scaffolding that will be cost effective and safe. Is there any alternatives?
Thank you in advance
RE: Alternative Replacement of Scaffolding at Plant
I assume you mean piping and not pipelines?
If you can get access you could use soething like this http://www.ais4ndt.com/internal-pipe-crawlers
Or look up longe range UT / guided wave. Tends to have difficulty seeing beyond wleds but might help
e.g https://inspectioneering.com/tag/lrut
Hi LittleInch
Thank you for answer. Yes, I meant piping:)
Here, at local refinery all non-destructive examination for piping are done while in service to save time and energy.
Unfortunately, local law dictates that it is mandatory to make Ultrasonic Thickness Measurement while UT/guided wave is more like a screening tool
Ah, you never said that before.
Well you're stuck then.
I have heard of people placing permanent UT probes / mats to measure WT remotely so maybe in the ones which cost the most you could do that.
Where is there a "law" to make UT measurements yearly ??
Overall situation is like this:
Authorities decided to monitor overall condition of pipes and equipment at the plant by making us or subcontractors to develop special non- destructive programs. Okay, lets now concentrate at pipes. Each program consists of several non-destructive examination (Visual Inspection, Ultrasonic Measurement, Magnetic Particle, Liquid Penetrant and etc.). At program, it is pointed at which places we have to execute those examinations (before welding, after welding; before support, after support and etc.). After examinations are completed, special governmental organ will issue authorization for 10 years with obligation to perform UT( after each 2 or 4 years, depends on report issued by organ) . That is why it is very expensive to build scaffolds and dismantle insulation in order to perform UT. That is why I am concerned about alternative solution to replace scaffolding:) Basically, I am concerned about saving money somehow
Any suggestion?
Would any of these manlift options work for you? Maybe a combination of them for different locations?
Yeah, we are using this kinds of manlifting machines, however, they don't have access to inside of installation. IT is unfortunate limitation
About those 3 options that LittleInch provided. They are pretty good. I will try to find some way to implement them. Than you.
How about Ubits - under bridge inspection trucks with booms that go anywhere.
Seems like you may be down to creating some type of modular scaffolding that can be attached to permanently installed support points. If the testing is a one person job, perhaps some strategically located permanently installed hoists and Bosun chairs?
Dear Buggar and HotRod10
Good idea! However, pipes are above ground and there isn't much space at installations to maneuver
About Bosun chairs, I need to talk with Safety Department if it is acceptable. But as far as i know Bosun chairs are not as stable as scaffolds and that can be the reason why management can reject this idea. Moreover, is it possible to dismantle insulation using Bosun Chair :(
If you have any other alternative ideas, please share, you are more than welcome:)
Perhaps a similar concept to the chairs, but something more substantial. I was thinking of permanently installed hoists, a platform big enough for the inspector(s) and the insulation that needs to be removed, and permanent stabilization anchor points to attach the platform to at the working height, to lock it off and keep it from swinging while the work is done. It might take a fair number of hoists installed and wired up, and likely some creative fabrication and welding to get the anchor points where they need to be, but it seems it could be an option.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
