Dear all,
I would like to know, based on your experience, which is the best seal (configuration) and API Plan for Crude Oil sealing.
The service is desalted Crude Oil at suction conditions = 150ºC and 9.5 kg/cm2 (discharge pressure = 38 kg/cm2), centrifugal pump between bearings (United Pumps DVS type)
Our MTBR, with single seal metal bellows and API Plan 11 is very poor, in fact the seal always leak but depending on the crude oil processed the leakage is greater.
Any thoughts, ideas and recommendations will be very welcomed
