Vehicle washing greese and oil trap design 1
vij36
IN
Dear all,
We require vehicle washing effluent greese and oil trap design. The effluent is per day 1,000 liters. We do have an existing design (attached here). but I feel it's over designed. Request you to please throw some light on this. Please let me know the optimisation can be done to the attached design.
 https://files.engineering.com/getfile.aspx?folder=86b1555d-b708-4ccf-98f7-3c01e92e4597&file=oil_trap_1000_liters.png
This design is problematic. You have a sand filter in the system which will get clogged quickly with residue.
Your flow is relatively small and there are lots of commercially available oil/water separators on the market that would be more efficient and likely less expensive than building the tank you have shown.
Many oil/water separators work on a flat plate/lamellar flow process...others work by vertical baffles with liquid flowing from the bottom to top through weirs or slots at the bottom of the baffles and the oil/grease floats to the top. It is important that the flow be very slow through these devices.
A Great Place For Engineers to Help Engineers
Follow me there.....
Funny, I was just sizing one for a 3 bay garage for our public works department. By our State Plumbing Code I show a need for a 184 gallon unit and readily found commercial units at 250 gallons. In my case I'm just filtering floor drains and am not concerned with maintaining a specific flow rate through the unit.
