[ SEATING FORCE FOR CONTROL VALVES ]
Dear All,
I am completely new to the control valves and currently studying the control valve actuator sizing. May be my question is basic but i have found the following thing very suspicious.
The book says:
the direction of the seat load is in upward if the valve is push down to close. What I think is the opposite. Can someone clarify me on that point?
RE: [ SEATING FORCE FOR CONTROL VALVES ]
Qulu Quliyev (Industrial),
Please do not be hurt by my comments, My intent is to help you.
1: What does "Industrial" mean in your world?
2: What does "I am completely new to the control valves" mean?
3: What does "currently studying the control valve actuator sizing." mean?
4: What does "I have found the following thing very suspicious." mean?
5: What Book?
6: Why do you question the flow direction through a "Globe type Control Valve?
You will need to do more study on the many different types of valves that are used to "Control" fluids and gases. Just to name a few, there are; Globe Type Control Valves, Gate Type Control Valves, Butterfly Type Control Valves, Plug Type Control Valves, Ball Type Control Valves, Needle Type Control Valves, Pinch Type Control Valves, and so on and so on. They all tend to have the same function but they will each have unique, specific needs
Then there are the many different types of actuators. It goes on and on.
Go here for a place to start:
https://www.google.com/search?q=Images+of+differen...
Sometimes its possible to do all the right things and still get bad results
QQ,
pennpiper makes some very good points.
For many types of relatively simple control valves the flow is vertically up into the body where either a cone or cylinder or a flat plate moves vertically up and down to change the flow characteristics of the valve.
This means that there is a vertical force upwards on the moving item which needs to be taken care of by the actuator.
some types of valve have different actions and don't have this effect.
The most simple example is a normal tap.
LittleInch
I am talking about the sliding stem control valves..
the thing which u are saying is called static unbalance force. I am talking about the seating force. why it is in upward direction while it has to be in downward?
Please post a drawing or sketch and also it is much better to say what you just posted in your original post.
Little Inch
I didn't post anything actually.
i am talking about the unbalanced control valve where the inlet pressure is applied to the bottom of the plug while the outlet pressure is around the plug.
here the seating force (force applied by the actuator in order to achieve the required shutoff class) has to be directed downward, in where training books says upward :/
QQ
You appear to have answered your own question "where the inlet pressure is applied to the bottom of the plug"
This will create a force which you need to counter if the plug is to close.
I know you didn't post anything, but I asked you to add a drawing or sketch to show better what it is you are talking about.
Also next time just write your title without the [ ] and don't use all CAPITALS. It is interpreted as shouting.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
