Bolt joint with metal to metal contact + oring design according to EN 13445 Annex C
Hi, I intend to verify a component, including a bolt joint, according to EN 13445-3 Annex C. My concern is how to show that the bolt joint fulfill the requirements according to EN 13445-3 Annex C.
I am familiar with traditional bolt joint calculations for example according to VDI2230. The bolt joint has metal-metal contact and an oring.
For admissible stress levels (design stress fd and ftest) Annex C makes reference to Clause 6. For bolts Clause 6 point to Clause 11 and 12 and further also to Annex G. Annex G makes reference to EN 1591.
Question: Do I have to dig deep into Annex G and EN 1591 to actually show that requirements are fulfilled? Or would it be allowed in a more simplified way to use the results from VDI2230 or even from a finite element calculation and show that requirements(according to EN 13445-3 Annex C) are fulfilled? For example define preload method, calculate bolt stresses in assembled and loaded condition, calculate contact clamping force etc according to CDI2230/FEA and then finally evaluate towards allowable limits that fulfill EN 13445-3 Annex C?
BR/Micke
RE: Bolt joint with metal to metal contact + oring design according to EN 13445 Annex C
It is clear to understand: read again
In PD 5500 you can see "suggest working form"
Avoid FEA
Hi, Thank you for tour reply! I do not have access to BS or PD.
I have started to look into the details of Annex G/GA.
BR/Micke
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
