Aug 14, 2019 #1 cementpaste Civil/Environmental Joined Aug 14, 2019 Messages 2 Location SG How to design flush end plate and extended end plate connection that connect steel beam to RC beam according to BS5950? I attach here with the setting of the beam. https://files.engineering.com/getfile.aspx?folder=9b09c319-65e2-4087-b157-b1152e1be056&file=a.png
Aug 15, 2019 #2 chicopee Mechanical Joined Feb 15, 2003 Messages 6,199 Location US Take a look at this document"https://civteam.files.wordpress.com...-to-steelwork-in-building-to-bs-5950-200.pdf" Upvote 0 Downvote
Aug 15, 2019 #3 chicopee Mechanical Joined Feb 15, 2003 Messages 6,199 Location US Oops only partial above, so her is the rest" .../2012/03/introduction-to-steelwork-in-building-to-bs-5950-200.pdf" Upvote 0 Downvote
Aug 17, 2019 Thread starter #4 cementpaste Civil/Environmental Joined Aug 14, 2019 Messages 2 Location SG Well, although I did not find what I wanted in this document. This is indeed a good reference material. Thank you! Upvote 0 Downvote
Sep 9, 2019 #5 Agent666 Structural Joined Jul 2, 2008 Messages 3,080 Location NZ There's an example of column to concrete moment connection within SCI P207 (attached). The latest version of this to Eurocodes is SCI P398 so there may be some additional information in this. https://files.engineering.com/getfile.aspx?folder=8c3029a0-6d0d-45f6-aa97-5aa1877d6f2c&file=P207_-_Joints_In_Steel_Construction_-_Moment_Connections.pdf Upvote 0 Downvote
