Tower liquid outlet, hydrostatic
in the image attached, two towers, same geometry, operating conditions, and liquid properties.
One has an outlet that goes directly into the receiving vessel
The option B has same outlet, but with a P trap type outlet, i.e. down and up before disposing into the next vessel.
Apart from the obvious extra 2 or 3 90 degree elbows and extra pipe length, if the heights are the same as shown, will there be extra pressure required to push the liquid into the next vessel?
Thanks for your help.
As much as possible, do it right the first time...
RE: Tower liquid outlet, hydrostatic
No.
What is going in here?
How many variations are you going to come up with?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
