NX11 Family Part (Hoping for a 1 in a billion chance)
I dont see any way this is possible but I am hoping anyway...
I was going to make a family part master for some simple Switch Brackets. There are several different types of brackets with no real way to name them so someone would know which bracket they need by the description. Basically it would be almost a crap-shoot to guess which one they need.
Unless there is some way to get a small image to show up in the selection box that pops up when you are adding a Family part?
Like I said. One in a billion chance.
RE: NX11 Family Part (Hoping for a 1 in a billion chance)
That's standard re-use stuff so no problem.
Your going to have a spreadsheet drive all the dimensions so...
The last Column in the spreadsheet should #bitmap
That Column contains the name of the bitmap you want to use for that part selection.
Just store the bitmap with the rest of the re-use data: *.xls, *.krx, *.prt
Of course, your talking part family. So that would mean an internal spreadsheet.
I suspect it still work the same way tho.
If you don't specify a path to the bitmap its assumed its in the same folder as the part.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX1851, Win 10 Pro
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - The Future of Product Development is Here
Looking to make the design and manufacturing of your products more agile? For engineering and manufacturing organizations, the need for digital transformation of product development processes just became more urgent than ever so we wanted to share an eBook that will help you build a practical roadmap for your journey. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
