Contact US
NACE MR 0175 vs NACE MR 0103
Dear Enginers ,
I have the Mill Test Report for 316L grade forged Bar with only NACE MR 0175 compliance , Can I use this Bar in our production when the project specification demands for NACE MR 0103 complaince material ?
I assume , NACE MR 0175 is superior to NACE MR 0103 , so it can be used or is it really necessary to have NACE MR 0103 compliance in the mill report when NACE MR 0175 is already there ?
Shiva Prasad
RE: NACE MR 0175 vs NACE MR 0103
If the material is based on ASTM specification, there is no major requirement for NACE MR 0103, except for hardness while 0175 would have some more stringent requirements for each material that we should not ignore with environmental limit. I would recommend you to check the hardness requirement of NACE MR 0103.
Lee Sihyoung,
Certified user of NAVE MR 0175 -CS
Certified user of NAVE MR 0175 -CRA
Lee SiHyoung,
So which level of service severity did you specify for MR 0175?
There is no such thing as global conformance, the purchaser must specify which level of service he is after.
MR0175 is not a certification document, i.e. it isn't possible to certify compliance. It is a question of the purchaser having knowledge of the exposure environment, reviewing the inspection data, and determining compliance. So, having NACE MR0175 on the inspection document is worthless anyway. MR0103 is a little more straightforward to get on the inspection document, if it had been requested. Why not simply get a copy of MR0103, look at the requirements, review the inspection data and determine compliance for yourself?
Steve Jones
Corrosion Management Consultant
www.linkedin.com/in/drstevejones
All answers are personal opinions only and are in no way connected with any employer.
Just a FYI. If you become a member of NACE, the documents are free. Membership is less than 2 documents.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
