Imagine a closed loop with the following; fan, duct work, cyclone. Assume a system loss of say 6 inwc. That fan has the potential to overcome the pressure loss. If the fan is turned on and the system allowed to operate (no heat gain or loss, no air added or removed) at what pressure (gauge) would the inlet of the fan be? What would the outlet be?
One could assume the inlet would be -3 and the outlet +3 inwc. Why couldn't it be -6 at the inlet and 0 at the outlet or some other combination there of?
If you can site some technical studies or sources that support your response, please do so.
erex
erex
