Combined Displacement/Rotation BC?
I'm looking for any suggestions on how to get this snap fit together.
I can physically/experimentally do this with the 3D-printed equivalent; however, I'd like to scale and substitute materials beyond prototyping.
I'm currently trying the following approximate path (43deg arc displacement of left hook *Black*-below & in-place Amplitude UR3 of right hook to ease entry of left hook *Red*-below (Step-Time:0,0.5,1; Amp:0,1,0; Rotation-Amp:2deg). Any force-based suggestions?
The analysis currently terminates 6ksi short of yield (21ksi):
I'm not necessarily looking for suggestions on analysis methods on the "snap" portion. I plan to use viscous dissipation or dynamic implicit methods to accomplish this.
RE: Combined Displacement/Rotation BC?
Is that plot below on undeformed shape ? Or is it the actual deformation with unit scale ? Make sure that all properties (especially those regarding plasticity) and dimensions are correct and thus the hooks aren't too stiff. General contact should handle this but in case of convergence issues try stabilization. Is that dynamic implicit analysis ? You can apply displacement/rotation BCs to whole hooks instead of single node on each one.
Quote (FEA_way)
The plot is the deformed shape to scale. This is a static general analysis. My self-prescribed protocol was to try static with viscous damping then move onto dynamic implicit if there isn't success in my first attempts.
Quote (FEA_way)
My Reference points are currently kinematically coupled to the surfaces that I press on with my fingers when I snap-fit the part. If I were to apply the BC to every single node as you suggest, wouldn't that force no strain to occur and both objects to act as rigid bodies?
Thank you for your response FEA_way.
That’s fine. I thought you apply displacement BCs to the nodes alone without any coupling to the surface. Stick with displacement control. It's much better than force control in analyses involving contact.
What is your material model ? Can you attach .inp file ? I would take a look.
I would apply pressure load to bend the hooks (open them a bit) in a first step. In a second step I would then move the hooks into each other and take away the pressure load.
Maybe a quasi-static analysis in A/Explicit is more efficient, when constant changes in contact and plasticity challenge the convergence in A/Standard.
Wow, thanks FEA_way & Mustaine3 for the follow up (my first posts on this site, and your responses are very welcoming).
Quote (FEA_way)
I'm using an linear-elastic model to debug and once bugs are worked out I will use an elastic-perfectly-plastic set of Al-6063 T5 properties (E=10,000,000 psi; nu=0.33, S_y=21000psi)
Quote (Mustaine3)
Thanks for the suggestion, Mustaine3. I am mostly interested in the reaction forces at the Control/Reference points, so this may complicate my end goal. I will try it though and make some judgements on the output.
Inp File (reduced interfering geometry feature from original post; using linear displacement rather than arc with little help):
CODE -->
*Heading
** Job name: Job-0002-1-0-1-5 Model name: Model-0002-1-0-1-5
** Generated by: Abaqus/CAE 2018
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Part-1
*Node
      1, -0.0583981052,  0.880026281
      2, -0.0551195592,   0.89368242
      3, -0.0463112965,  0.912789047
      4, -0.0380563326,  0.924151003
      5, -0.0281256009,  0.934081733
      6, -0.0167636219,  0.942336679
      7, 0.00234297896,  0.951144934
      8,  0.015999116,  0.954423487
      9, 0.0299999993,  0.955525398
     10, 0.0440008864,  0.954423487
     11,  0.057657022,  0.951144934
     12, 0.0767636225,  0.942336679
     13, 0.0881256014,  0.934081733
     14, 0.0980563313,  0.924151003
     15,  0.106311291,  0.912789047
     16,  0.115119562,   0.89368242
     17,  0.118398108,  0.880026281
     18, -0.0595000014,  0.866025388
     19,  0.119499996,  0.866025388
     20, -0.0572544448,  0.854736269
     21, -0.0508596487,   0.84516573
     22, -0.0412891619,  0.838770986
     23, -0.0299999993,  0.836525381
     24, -0.0187108386,  0.838770986
     25, -0.00914034992,   0.84516573
     26, -0.00274555385,  0.854736269
     27, -0.000500000024,  0.866025388
     28, 0.00182167429,  0.877697229
     29, 0.00843324326,  0.887592137
     30, 0.0183281545,  0.894203722
     31, 0.0299999993,  0.896525383
     32, 0.0416718461,  0.894203722
     33, 0.0515667573,  0.887592137
     34, 0.0581783243,  0.877697229
     35, 0.0604999997,  0.866025388
     36, 0.0594242029,   0.85211277
     37, 0.0566980876,   0.84006983
     38,  0.050819587,  0.825301409
     39, 0.0440175049,   0.81395179
     40, 0.0349252857,  0.802978158
     41,  0.024791006,  0.793996274
     42,  0.012464026,  0.786106348
     43, 0.000386648317,  0.781421304
     44, -0.0167160388,  0.778112113
     45, -0.0299999993,  0.777975917
     46, -0.040874701,  0.774977267
     47, -0.0497091375,  0.767962754
     48, -0.0550946593,   0.75805074
     49, -0.056172546,  0.746821821
     50, -0.0527709275,  0.736066341
     51, -0.0454321951,  0.727499306
     52, -0.035808567,  0.716692388
     53, -0.0326175466,  0.710165262
     54, -0.0299999993,  0.695933163
     55, -0.0299999993,  0.688729167
     56, -0.0299999993,  0.674321234
     57, -0.0299999993,  0.667117298
     58, -0.0299999993,  0.652709365
     59, -0.0166666675,  0.652709365
     60, -0.00999999978,  0.652709365
     61, -0.00333333341,  0.652709365
     62, 0.00999999978,  0.652709365
     63, 0.0166666675,  0.652709365
     64, 0.0299999993,  0.652709365
     65, 0.0299999993,  0.660575271
     66, 0.0299999993,  0.668441236
     67, 0.0299999993,  0.676307201
     68, 0.0299999993,  0.684173107
     69, 0.0512835272,   0.73850888
     70,  0.041649241,  0.725744426
     71, 0.0353639983,  0.712973595
     72, 0.0311268046,  0.697552919
     73, 0.0611980744,  0.747563779
     74,  0.118898921,  0.852632821
     75,  0.116181143,  0.834699333
     76,  0.111987635,  0.819230497
     77,  0.106922962,  0.806005776
     78,  0.101424433,  0.794766247
     79, 0.0920848399,   0.77973783
     80, 0.0832192451,  0.768395245
     81, 0.0723142028,  0.757020593
     82, 0.0262497235,  0.697753727
     83, 0.0983719155,  0.805070937
     84,  0.106689863,  0.847795069
     85, -0.0466441549,   0.87177074
     86,  0.107257031,  0.871450067
     87, 0.0653204992,   0.85849148
     88, 0.0756531283,  0.857914448
     89, 0.0873188376,  0.860774934
     90,  0.106673524,  0.859434664
     91, 0.0966132283,  0.871863544
     92, 0.0782517567,  0.866898596
     93, 0.0671851784,  0.869688094
     94, 0.0711801648,  0.880427182
     95, 0.0794659629,  0.879526973
     96, 0.0882683769,  0.880847037
     97, 0.0973467678,  0.880427063
     98,   0.10809876,  0.891411006
     99,  0.101037458,  0.889127374
    100,  0.085514158,   0.88930577
    101, 0.0792602599,  0.890471816
    102, 0.0653476417,  0.890031874
    103, 0.0567917041,  0.891254902
    104, -0.0490689352,  0.891816854
    105,  -0.04207436,  0.890838683
    106, -0.028917674,  0.893168509
    107, -0.0173474345,  0.889050126
    108, -0.00384963304,  0.888757706
    109, 0.00442864001,  0.890348613
    110, 0.0975405499,  0.900616109
    111, 0.0892778635,  0.900953829
    112, 0.0789519027,  0.897537172
    113, 0.0740988255,   0.90290463
    114, 0.0616221949,  0.908239424
    115, 0.0458583422,  0.903984368
    116,  0.036268007,  0.900888562
    117, 0.0244532656,  0.901466012
    118, 0.0131221861,  0.903709173
    119, 0.000201409974,  0.903566658
    120, -0.0203822795,  0.906367421
    121, -0.0275921728,   0.90304184
    122, -0.0362590551,  0.904024601
    123, 0.0962167755,  0.914377213
    124,  0.090109244,  0.909913599
    125, 0.0791765377,  0.909769177
    126, 0.0715010166,  0.914978206
    127,  0.058656659,  0.913978338
    128, 0.0446984842,  0.911355019
    129, 0.0348338261,  0.912013531
    130, 0.0261983629,  0.912203789
    131, 0.0161586422,  0.914113939
    132, 0.00371229323,  0.913323224
    133, -0.00740179233,  0.918286026
    134, -0.0163717512,  0.914044619
    135, -0.0266776308,  0.913041294
    136, -0.0367733948,  0.913693964
    137, -0.0223690365,  0.918529749
    138, -0.0129411565,  0.920659065
    139, -0.00424117362,  0.925517559
    140, 0.0045800833,  0.925569594
    141, 0.0159364417,  0.926007986
    142, 0.0229598135,  0.921138465
    143, 0.0326213725,  0.924730837
    144, 0.0583827384,  0.921681583
    145, 0.0684465542,  0.919867873
    146, 0.0827775225,  0.920009851
    147, 0.0881667584,  0.924370885
    148, 0.0782221258,    0.9321872
    149, 0.0687595978,  0.929115891
    150, 0.0634293109,  0.932559609
    151, 0.0483854078,  0.928109348
    152, 0.0297841039,   0.93616724
    153, 0.0185924079,  0.939704895
    154, 0.00662451843,   0.93237859
    155, -0.0068103564,  0.932489395
    156, -0.0139434952,  0.937228262
    157, 0.0605776757,  0.941440403
    158, 0.0477961712,  0.946074605
    159, 0.0261072684,  0.940485179
    160,  0.017419422,  0.946867704
    161, 0.00403307471,  0.944071591
    162, -0.0379815511,  0.882042944
    163, -0.0261679422,  0.877829492
    164, -0.00691177323,  0.883376002
    165, -0.00660021557,  0.870498657
    166, -0.0181792323,  0.871021688
    167, -0.0248903129,  0.869910359
    168, -0.0354304761,  0.869079888
    169, -0.0476847328,  0.861671567
    170, -0.0389393643,  0.857199192
    171, -0.0277463235,  0.860223114
    172, -0.0195758846,  0.857770681
    173, -0.0104147075,   0.86262089
    174, -0.0365754031,  0.847801685
    175, -0.0274990704,  0.848801732
    176, -0.0210640449,  0.844527423
    177, 0.0653569251,  0.845098197
    178,  0.077107057,  0.842357278
    179, 0.0849278346,  0.849525511
    180, 0.0954194367,  0.846449673
    181, 0.0675197914,  0.836425185
    182, 0.0770403221,  0.832561493
    183, 0.0856615677,  0.839050353
    184, 0.0980724394,   0.83737278
    185,  0.110563494,   0.83582449
    186, 0.0584694855,  0.815002382
    187, 0.0661785007,  0.811682165
    188, 0.0780884549,  0.818330526
    189, 0.0884764791,  0.816204727
    190, 0.0971537977,   0.81368041
    191,  0.109662399,  0.830482185
    192,  0.099016048,  0.821771562
    193, 0.0895797238,  0.828251719
    194, 0.0797748864,  0.827047706
    195, 0.0694437772,  0.825424314
    196, 0.0551056787,  0.823532164
    197, 0.0459624119,  0.803254247
    198, 0.0580443293,  0.802342653
    199, 0.0655870214,  0.802850842
    200,  0.077168867,  0.805562973
    201, 0.0878854319,  0.804755867
    202, 0.0364469402,  0.793589056
    203, 0.0438776761,  0.792580664
    204, 0.0553868897,  0.792504072
    205, 0.0699768066,   0.79195261
    206, 0.0772242174,  0.793062389
    207, 0.0856725723,  0.791348934
    208, 0.0146583691,   0.78033942
    209, 0.0245527178,  0.782149851
    210, 0.0353689194,  0.783468604
    211, 0.0455137976,  0.782298446
    212, 0.0651015937,  0.782452404
    213, 0.0770038292,  0.781281948
    214,  0.087795727,  0.783273458
    215, -0.0373664387,  0.770596564
    216, -0.0288090222,  0.771136642
    217, -0.0161340497,  0.773838103
    218, -0.00988045242,  0.771271229
    219, 0.00543991942,  0.772012353
    220, 0.0153957196,   0.77026391
    221, 0.0248427894,   0.77001214
    222, 0.0351399258,  0.772904515
    223, 0.0468228832,  0.772009134
    224, 0.0561793558,  0.769385159
    225, 0.0672718734,  0.773263931
    226,  0.076669015,  0.771712482
    227, -0.0448195934,  0.764305532
    228, -0.0363513939,  0.758189619
    229, -0.0249610636,  0.756568551
    230, -0.0167935342,  0.762386501
    231, -0.00670996821,  0.762786925
    232, 0.00319724553,  0.762321055
    233, 0.0153621202,   0.75919795
    234, 0.0245124362,  0.759330034
    235, 0.0365412198,  0.761469722
    236, 0.0450036153,  0.761603832
    237, 0.0567389429,  0.761979163
    238, 0.0665461197,   0.76138556
    239, -0.0468223244,  0.751218021
    240, -0.0410705544,  0.751100302
    241, -0.0313052684,  0.749418914
    242, -0.0171541609,  0.749092102
    243, -0.0103251347,  0.751171231
    244, 0.0014920478,  0.749943435
    245, 0.0133394022,  0.748166621
    246,  0.023946112,  0.750050187
    247, 0.0349010304,  0.749948919
    248, 0.0451446734,  0.750605404
    249, 0.0548875481,  0.751018524
    250, -0.0500377789,  0.742746115
    251, -0.0410989858,  0.737609446
    252, -0.0315863229,  0.737019837
    253, -0.0160544589,  0.738427639
    254, -0.00868781749,  0.735959888
    255, 0.0117318295,  0.739211917
    256, 0.0231589824,  0.738757253
    257, 0.0348762535,  0.739093423
    258, 0.0456402525,  0.736911833
    259, -0.0409311205,  0.730573297
    260, -0.0283127949,  0.727247596
    261, -0.0160708316,  0.726901352
    262, -0.00370104075,  0.724941671
    263, 0.00137682306,  0.723704457
    264, 0.0141550824,  0.726014793
    265, 0.0223817807,  0.730891764
    266, 0.0338026173,  0.729344726
    267, -0.0311100688,  0.719185054
    268, -0.0177953802,  0.719277859
    269, -0.00381027046,  0.719063163
    270, 0.00479149772,  0.716017008
    271, 0.0105059911,  0.717307985
    272, 0.0216530561,  0.719010115
    273, 0.0340346918,  0.718147218
    274, -0.0181958675,  0.710315704
    275, -0.00700365705,  0.701940119
    276, 0.00533913169,  0.704487324
    277, 0.0149820177,  0.707522571
    278, 0.0253671482,  0.708085656
    279, -0.0171771552,  0.688800633
    280, 0.00324663636,  0.679312706
    281, 0.00789904688,  0.683359563
    282, 0.0235964451,  0.684516907
    283, 0.0134956539,  0.695329428
    284, -0.0157867707,  0.674727857
    285, -0.00258183712,   0.67728579
    286, 0.00634164037,  0.673917651
    287, 0.0140470248,  0.677676678
    288, 0.0225734357,   0.67673254
    289, -0.00982690789,  0.663146794
    290, 0.00143782096,  0.665749252
    291, 0.0153848054,  0.668530762
    292, 0.0226556733,  0.668687463
    293, -0.0592241026,  0.873047471
    294, -0.057027109,  0.886918783
    295, -0.0526872166,  0.900275588
    296, -0.0497450829,  0.906657577
    297, -0.0424070209,  0.918632209
    298, -0.0332860574,  0.929311454
    299, -0.0226067808,  0.938432395
    300, -0.0106321499,  0.945770502
    301, -0.0042501674,  0.948712647
    302, 0.00910663977,  0.953052521
    303, 0.0229779109,  0.955249488
    304, 0.0370220877,  0.955249488
    305, 0.0508933589,  0.953052521
    306, 0.0642501637,  0.948712647
    307, 0.0706321523,  0.945770502
    308, 0.0826067775,  0.938432395
    309, 0.0932860598,  0.929311454
    310,  0.102407023,  0.918632209
    311,  0.109745085,  0.906657577
    312,  0.112687215,  0.900275588
    313,  0.117027111,  0.886918783
    314,  0.119224101,  0.873047471
    315, -0.0589331649,  0.860270262
    316, -0.0545283519,  0.849636078
    317, -0.0463893227,  0.841497064
    318, -0.0357551649,  0.837092221
    319, -0.0242448356,  0.837092221
    320, -0.0136106778,  0.841497064
    321, -0.00547164632,  0.849636078
    322, -0.0010668342,  0.860270262
    323, 8.60489454e-05,   0.87197566
    324, 0.00464017689,  0.882970273
    325, 0.0130551076,  0.891385198
    326, 0.0240497459,   0.89593935
    327, 0.0359502546,   0.89593935
    328, 0.0469448939,  0.891385198
    329, 0.0553598218,  0.882970273
    330, 0.0599139519,   0.87197566
    331, 0.0602139086,  0.858835101
    332, 0.0582248047,  0.845860243
    333, 0.0549155325,   0.83472681
    334, 0.0529385805,  0.829811573
    335, 0.0486027673,  0.821171701
    336, 0.0463251583,  0.817396998
    337, 0.0417050831,  0.810810983
    338, 0.0394084565,  0.807950318
    339, 0.0371441618,  0.805346668
    340, 0.0327620171,  0.800824344
    341, 0.0306620933,  0.798866212
    342, 0.0286311992,   0.79708606
    343, 0.0266733132,  0.795467734
    344, 0.0229856856,  0.792658031
    345, 0.0212578159,  0.791440666
    346,  0.019607095,  0.790332675
    347, 0.0180326104,  0.789323926
    348, 0.0165329669,  0.788404942
    349, 0.0151063949,  0.787567377
    350, 0.0137508372,  0.786803484
    351, 0.0111384913,  0.785485983
    352, 0.00959477201,  0.784798145
    353, 0.00779552339,  0.784042239
    354, 0.00569684803,  0.783220947
    355, 0.0032472664,  0.782342196
    356, -0.00295477966,  0.780484438
    357, -0.00685714278,  0.779573262
    358, -0.0114109805,  0.778751314
    359, -0.0228777863,  0.777790308
    360, -0.0355885476,  0.777024865
    361, -0.045645602,  0.771915436
    362, -0.0529016741,  0.763278306
    363, -0.0561997853,   0.75249064
    364, -0.055014044,  0.741272569
    365, -0.0495335236,  0.731412828
    366, -0.0401276127,  0.722534657
    367, -0.0306598283,  0.703168571
    368, -0.0299999993,   0.68152523
    369, -0.0299999993,  0.659913301
    370, -0.0233333334,  0.652709365
    371, 0.00333333341,  0.652709365
    372, 0.0233333334,  0.652709365
    373, 0.0556118004,  0.742841065
    374, 0.0479240194,  0.734636724
    375, 0.0453073345,  0.731235445
    376,  0.043259833,  0.728283763
    377, 0.0403752327,  0.723573506
    378, 0.0393617488,  0.721726239
    379, 0.0385510474,  0.720159888
    380, 0.0378991216,  0.718835235
    381, 0.0371525101,  0.717237353
    382, 0.0363070108,  0.715307415
    383, 0.0343343616,  0.710148335
    384, 0.0332445651,  0.706725359
    385, 0.0321456827,  0.702577055
    386,  0.030334441,  0.691480577
    387,  0.119343385,  0.859184086
    388,  0.118202358,  0.846370637
    389,  0.117286474,  0.840394437
    390,  0.114913546,  0.829278767
    391,  0.113508299,   0.82412529
    392,  0.110371545,  0.814585328
    393,  0.108677968,  0.810180366
    394,  0.105120808,  0.802051842
    395,  0.103284217,  0.798308611
    396, 0.0995513648,  0.791415095
    397, 0.0976737291,  0.788245797
    398, 0.0957991481,  0.785248995
    399, 0.0939342678,  0.782415926
    400, 0.0902558118,   0.77720654
    401, 0.0884514228,  0.774814069
    402, 0.0866752639,  0.772552788
    403, 0.0849303678,  0.770415485
    404, 0.0815439522,  0.766485453
    405, 0.0799061283,  0.764679968
    406, 0.0783070847,  0.762972891
    407,   0.07674779,    0.7613585
    408, 0.0752289444,  0.759831607
    409, 0.0737510026,  0.758387208
    410, 0.0709185973,  0.755727232
    411, 0.0695640668,  0.754503012
    412, 0.0682503656,   0.75334394
    413, 0.0669771209,  0.752246261
    414, 0.0657438487,  0.751206577
    415, 0.0645499825,  0.750221491
    416, 0.0633948743,  0.749287903
    417, 0.0622778237,  0.748402894
    418, 0.0606679395,  0.750246227
    419, 0.0621855855,  0.751096249
    420, 0.0131192934,  0.784119725
    421, 0.0115745096,  0.783325732
    422, 0.0350164548,  0.720108449
    423, 0.0635487437,  0.751907885
    424, 0.0648601502,  0.752777815
    425, 0.0661404729,  0.753745973
    426, 0.0160842203,  0.785839856
    427, 0.0674061254,  0.754817486
    428, 0.0686746761,  0.755976617
    429, 0.0176096987,  0.786767066
    430, 0.0360043161,  0.721890092
    431, 0.0699583218,  0.757217348
    432, 0.0192106813,  0.787733078
    433, 0.0712668672,  0.758544326
    434, 0.00798988435,  0.781673014
    435,  0.072617054,  0.759966195
    436, 0.0209009331,  0.788745642
    437, 0.0740153044,  0.761473477
    438, 0.0370861888,   0.72371459
    439, 0.0226868503,  0.789820373
    440, 0.0754635856,  0.763065219
    441, 0.0769507512,  0.764737606
    442, 0.0245714914,  0.790979803
    443, 0.00583490357,  0.780713677
    444, 0.0784689412,  0.766491413
    445, 0.0265444685,  0.792257369
    446, 0.0800182521,   0.76833415
    447, 0.0382911451,  0.725711823
    448, 0.0329919122,  0.715971172
    449, 0.0285574999,  0.793686688
    450, 0.0816049799,  0.770273328
    451, 0.00336735602,  0.779684842
    452, 0.0305812433,  0.795302927
    453, 0.0848921463,  0.774446249
    454, 0.0326974168,  0.797114849
    455, 0.0865705758,  0.776691258
    456, 0.0882640779,     0.779064
    457, 0.00053475413,  0.778606892
    458, 0.0319355577,  0.713472188
    459, 0.0349216349,  0.799058974
    460, 0.0899697915,  0.781582952
    461, 0.0373043977,  0.801125467
    462, 0.0933787152,  0.787087083
    463, 0.0398908742,  0.803372741
    464, -0.00275282259,  0.777481675
    465, 0.0950785577,  0.790061116
    466, 0.0412717834,  0.730610549
    467, 0.0307140928,  0.710493863
    468, 0.0425668918,  0.805915117
    469, 0.0967761353,  0.793192387
    470, 0.0984665751,  0.796490133
    471, 0.0449022874,  0.808907807
    472,  0.100141242,  0.799975395
    473, -0.00658391882,  0.776298523
    474, 0.0472404175,  0.812219262
    475,  0.101786204,  0.803654552
    476,  0.029290963,  0.707034767
    477, 0.0432344638,  0.733588457
    478,  0.103380881,  0.807516098
    479, 0.0496800728,  0.815728545
    480,  0.104903154,  0.811575711
    481, -0.0110285468,  0.775068998
    482,  0.106321543,   0.81588304
    483,  0.107599363,  0.820470989
    484, 0.0596494079,  0.752186537
    485, 0.0613162704,  0.752854943
    486,  0.009884133,  0.782527447
    487, 0.0138337603,  0.782209694
    488, 0.0146036157,    0.7849437
    489, 0.0640857816,  0.754275262
    490, 0.0653205737,  0.755184054
    491, 0.0337029137,  0.723439634
    492, 0.0665180534,  0.756233871
    493, 0.0185949001,  0.785163164
    494, 0.0677108094,  0.757391036
    495,  0.068911843,  0.758633733
    496, 0.0202639233,  0.786138713
    497, 0.0701260492,   0.75996989
    498, 0.0220370032,  0.787117541
    499, 0.0348719656,  0.725474715
    500, 0.0713919327,   0.76143086
    501, 0.0727242753,  0.762988985
    502, 0.0239337031,  0.788112879
    503, 0.00842445716,  0.779306769
    504, 0.0741071776,  0.764639199
    505, 0.0259747002,  0.789153934
    506,  0.075514555,  0.766375184
    507, 0.0769404247,  0.768184781
    508, 0.0281760804,  0.790297508
    509,  0.036106959,  0.727645636
    510, 0.0783953071,  0.770071507
    511, 0.00624694256,   0.77822274
    512, 0.0304444823,  0.791657209
    513, 0.0396603495,  0.727990925
    514, 0.0832290426,  0.772308469
    515, 0.0311638657,  0.719315052
    516,  0.032501664,  0.793417931
    517, 0.0830325559,  0.776237428
    518, 0.0346195735,  0.795327067
    519, 0.0846182406,  0.778455138
    520, 0.00378725538,  0.777061462
    521, 0.0862080753,  0.780785561
    522, 0.0368563458,  0.797222078
    523, 0.0916776061,  0.784256339
    524, 0.0296659768,  0.717019439
    525, 0.0393083468,   0.79912436
    526, 0.00102975755,   0.77583617
    527, 0.0908794254,  0.788735211
    528, 0.0285111386,   0.71435529
    529, 0.0421609655,  0.801092267
    530, 0.0923886672,  0.791698337
    531, 0.0939012095,  0.794801295
    532, 0.0954191759,   0.79803741
    533, -0.00212551956,  0.774514735
    534, 0.0481490158,  0.806995511
    535, 0.0407465436,  0.735850275
    536, 0.0503883846,  0.810432434
    537, 0.0997555926,  0.808820546
    538,  0.052827362,  0.813870072
    539,  0.042760741,  0.739226103
    540,  0.102256209,  0.816857636
    541, 0.0522905588,   0.81946826
    542,  0.108704902,  0.825344145
    543, 0.0607288033,  0.754629672
    544, 0.0154346554,   0.78317523
    545, 0.0621181987,   0.75510323
    546, 0.0121643143,  0.781243205
    547, 0.0633864999,  0.755661368
    548, 0.0655515641,  0.757592559
    549,  0.031448666,  0.724916399
    550, 0.0587746464,  0.749104142
    551,  0.017010197,  0.784154713
    552,  0.066657342,  0.758770823
    553, 0.0195336193,  0.783558965
    554, 0.0677762106,  0.760004342
    555, 0.0103756338,  0.780282319
    556, 0.0324867256,  0.721456409
    557, 0.0688841119,  0.761300266
    558, 0.0212133303,  0.784537613
    559, 0.0700810701,  0.762792051
    560, 0.0230139866,  0.785465062
    561, 0.0713711008,  0.764382005
    562, 0.0726913437,  0.766071498
    563, 0.0249617938,  0.786349356
    564, 0.0326008983,  0.727060676
    565,  0.073998481,    0.7678743
    566, 0.0270963348,  0.787219405
    567, 0.0753059834,  0.769759297
    568, 0.0090900138,   0.77693218
    569, 0.0374556407,  0.730055332
    570, 0.0798985809,  0.772045791
    571, 0.0295115523,  0.788120031
    572,   0.05908411,  0.754202425
    573, 0.0814458579,  0.774101555
    574,  0.032519374,  0.789157093
    575, 0.0810985491,  0.777954638
    576, 0.0069129644,  0.775758743
    577, 0.0825996846,   0.78013289
    578, 0.0840990916,  0.782392323
    579, 0.0259338841,    0.7187801
    580, 0.0893561095,  0.785914958
    581, 0.0409551263,  0.797011793
    582, 0.00448312424,  0.774483502
    583, 0.0249827281,  0.715262771
    584, 0.0435592756,  0.798556805
    585, 0.0272595361,  0.711291313
    586, 0.0389770344,  0.732771218
    587, 0.0909073874,  0.796257734
    588, -0.00575738773,  0.773037553
    589, 0.0969246179,  0.801450193
    590,  0.103945829,   0.82607615
    591, 0.0586513728,  0.809728086
    592, -0.00782783888,  0.767799258
    593, 0.0416764319,  0.744779587
    594, 0.0555838682,  0.817398369
    595, 0.0948953107,  0.806283951
    596,  0.101067133,  0.812720835
    597, 0.0163169559,  0.781426013
    598, 0.0589870512,  0.755914629
    599,  0.060288623,  0.756453216
    600, 0.0628132299,   0.75677073
    601, 0.0179293826,  0.782497466
    602, 0.0220958907,   0.78294456
    603, 0.0291041695,  0.726323128
    604, 0.0129219135,  0.779166758
    605, 0.0576002449,  0.751508713
    606, 0.0686860606,  0.764071941
    607, 0.0238547623,  0.783798575
    608, 0.0699853152,  0.765669346
    609, 0.0110765994,  0.778018653
    610, 0.0257799346,  0.784542739
    611, 0.0712435171,  0.767338037
    612, 0.0644425452,   0.75888437
    613, 0.0724033788,  0.769198239
    614, 0.0278922804,  0.785204589
    615, 0.0302179847,  0.785780072
    616,  0.073542051,  0.771195352
    617, 0.0675062761,  0.762540102
    618,  0.078089729,  0.773730934
    619, 0.00998958293,  0.774445057
    620, 0.0795768276,  0.775819242
    621, 0.0790892094,  0.779636562
    622, 0.0286764707,  0.720843852
    623, -0.0010392291,  0.771627069
    624, 0.0386033468,  0.795355022
    625, 0.00779488171,  0.773281455
    626, 0.0327414423,  0.786123276
    627, 0.0213433765,  0.710558712
    628, 0.0869926289,  0.787372828
    629, 0.0805014893,  0.781782985
    630, 0.0424518362,  0.794809997
    631,   0.05026187,  0.802264035
    632, -0.00433178758,  0.769964039
    633,  0.036560867,  0.790262043
    634, 0.0616417751,  0.817984104
    635, 0.0302449577,  0.728498578
    636, 0.0363932811,  0.734651446
    637,  0.035029266,  0.731898427
    638, 0.0611346178,  0.812390864
    639,  0.053523466,  0.808652282
    640, 0.0392282046,  0.741637826
    641, 0.0483576059,  0.740562558
    642, 0.0960274115,  0.809946477
    643,  0.027749138,  0.702843964
    644, -0.0144602451,  0.769241154
    645, 0.0982456356,  0.817548275
    646,  0.104350396,  0.831219852
    647, 0.0597055852,  0.758218586
    648, 0.0618050434,  0.758820593
    649, 0.0188881289,   0.78086859
    650, 0.0204759557,  0.781939268
    651,  0.022956159,  0.781372547
    652, 0.0686135665,  0.766897798
    653, 0.0156358648,  0.778439105
    654, 0.0698276013,  0.768394828
    655,  0.013900023,   0.77706027
    656, 0.0707348362,  0.770258486
    657, 0.0571660697,  0.754114449
    658, 0.0643474534,  0.761246026
    659, 0.0120233903,  0.775653481
    660, 0.0323275402,  0.733535826
    661, 0.0264037233,  0.782693326
    662, 0.0673349798,  0.765247643
    663, 0.0761623383,   0.77535224
    664, 0.0715954006,  0.772423983
    665, 0.0284345783,  0.783105373
    666, 0.0382232629,  0.791947424
    667,  0.074774608,  0.773273885
    668,  0.055154223,  0.747538686
    669, 0.0272674803,  0.722469985
    670, 0.0306219421,  0.783400416
    671, 0.0776286125,  0.777486145
    672, 0.0265599024,  0.727691591
    673, 0.0356379077,  0.788212121
    674, 0.0111153722,  0.771714926
    675, 0.0312958024,  0.730833054
    676, 0.0548534803,  0.754093945
    677, 0.0465586968,  0.799556136
    678, 0.0402184799,  0.793443263
    679, 0.0833912194,  0.786196768
    680, 0.0516189262,  0.805415869
    681, 0.0565906093,  0.806852937
    682, 0.0537066683,  0.801031291
    683, 0.0378560871,  0.737781644
    684, 0.0302155148,  0.722898006
    685, 0.0189950615,  0.705610693
    686, 0.0921195224,  0.810913146
    687, 0.0594355576,  0.805112064
    688, 0.0588712879,  0.821122408
    689, 0.0385835841,  0.747265816
    690, 0.0797246099,  0.785548806
    691, 0.0233186763,  0.703877211
    692, 0.0931126848,  0.814585447
    693, 0.00871883985,  0.770612478
    694, -0.0115053672,  0.764380693
    695, -0.00243544905,  0.767142177
    696, -0.0196982361,  0.767297566
    697, 0.0199386999,  0.779240906
    698, 0.0214536097,  0.780355155
    699, 0.0741345361,  0.776939332
    700, 0.0663413033,  0.766533554
    701, 0.0670643747,  0.768442571
    702, 0.0382653214,  0.787692308
    703, 0.0251224563,  0.780519068
    704, 0.0686513782,  0.769209027
    705, 0.0689578652,  0.770902216
    706, 0.0268060677,  0.780807078
    707, 0.0151647348,  0.775011957
    708, 0.0133320848,  0.773106098
    709, 0.0308265537,  0.781028926
    710, 0.0167849883,  0.776609659
    711,  0.028744055,  0.780957222
    712, 0.0416414738,  0.791510046
    713, 0.0515512191,  0.747896254
    714,  0.018398514,  0.777982473
    715, 0.0278777312,  0.729849279
    716, 0.0654484928,  0.763405919
    717, 0.0398268513,  0.790240705
    718, 0.0574830249,  0.756964386
    719, 0.0611335412,  0.760972142
    720, 0.0520329699,  0.751238465
    721, 0.0628848225,  0.761482775
    722, 0.0755566582,  0.785345495
    723,  0.054983817,  0.756887496
    724, 0.000492467545,  0.768760026
    725, 0.0496564731,  0.799101114
    726, 0.0354093015,  0.785912037
    727, 0.0287281219,  0.731918812
    728, 0.0633186772,  0.825386941
    729, 0.0280149635,  0.724286079
    730,  0.033900369,  0.746325076
    731,  0.043544136,  0.747756839
    732, 0.0613063984,  0.807561159
    733, 0.0168073643,  0.711660564
    734, -0.00256601512,  0.763036251
    735, 0.0904805288,  0.803821623
    736,  0.044758603,  0.796087801
    737, 0.0756509304,   0.77909559
    738, 0.0654144213,  0.820371389
    739, 0.00920721423,  0.767676294
    740,  0.082274124,   0.78952539
    741, 0.0619135797,  0.803534806
    742, 0.0991701931,    0.8311975
    743, 0.0225501712,  0.778824747
    744, 0.0196032152,  0.776319206
    745, 0.0591712035,  0.760329723
    746, 0.0211362988,  0.777612388
    747, 0.0287697185,  0.778794885
    748, 0.0308324452,  0.778616428
    749, 0.0700760186,  0.776350021
    750, 0.0726552531,  0.774780035
    751, 0.0381190255,  0.785609424
    752, 0.0241665803,  0.729276538
    753, 0.0382463299,  0.789336026
    754, 0.0650479794,  0.770801604
    755, 0.0329319984,  0.783534527
    756, 0.0269174557,   0.77899605
    757, 0.0607717298,  0.763186753
    758, 0.0721631721,  0.778586149
    759, 0.0249762069,  0.722275794
    760, 0.0523644313,  0.754333079
    761, 0.0426289551,  0.789816678
    762, 0.0671433806,  0.775787771
    763,  0.025876781,  0.731988311
    764, 0.0647609308,  0.766167879
    765, 0.0776050687,  0.787315369
    766, 0.0451391861,  0.789912283
    767, 0.0468659736,  0.745890439
    768, 0.0292894095,  0.734846294
    769, 0.0489891693,  0.795669198
    770, 0.0570494384,  0.759693146
    771, 0.0526528619,  0.798366308
    772, 0.00550630176,  0.767330825
    773, 0.0167976953,    0.7733652
    774, 0.0846211165,  0.788594663
    775, 0.0122919306,  0.768729866
    776,  0.073762469,  0.780595899
    777, 0.0376323871,  0.752379894
    778, 0.0356694907,  0.742103577
    779, 0.0018866132,  0.773116946
    780, 0.0639962107,  0.814742267
    781,  0.060822472,  0.801270902
    782, -5.53520113e-05,  0.761904359
    783, 0.0930291638,  0.833947599
    784, 0.0877857953,  0.807683885
    785,  0.017548779,  0.715661108
    786, 0.0671336204,  0.816567242
    787, 0.0579292402,   0.82803911
    788, -0.000685228792,  0.764595687
    789, 0.0208420921,  0.774691284
    790, 0.0629025102,    0.7635535
    791, 0.0330334082,  0.781030595
    792, 0.0588000081,  0.762515664
    793, 0.0163203403,   0.76630199
    794, 0.0306024086,  0.776150823
    795,   0.01325374,  0.765345037
    796, 0.0549745895,  0.759397566
    797, 0.0238732975,   0.77738446
    798, 0.0648738146,  0.768509209
    799, 0.0465675779,  0.786423087
    800, 0.0253010746,  0.725284696
    801, 0.0648747534,  0.775177896
    802, 0.0631998852,  0.772865534
    803, 0.0185915455,  0.769976139
    804, 0.0284000561,  0.776613593
    805, 0.0412375256,  0.787976921
    806, 0.0262068212,  0.735371709
    807, 0.0855913386,  0.784793198
    808, 0.0334743969,  0.736337483
    809, 0.0474781692,   0.79172647
    810, 0.0228110291,  0.733125925
    811, 0.0481728092,  0.749021769
    812, 0.0721924752,  0.781832576
    813, 0.0883100703,  0.790168226
    814, 0.0801973641,  0.792658687
    815, 0.0379307531,  0.783273876
    816, 0.00656083599,  0.763306439
    817, 0.0570625849,  0.799143732
    818, 0.0522860214,   0.79546833
    819, 0.0843162388,  0.807108581
    820, 0.0180498492,  0.774965525
    821, 0.0747796074,  0.789061487
    822, 0.0323068276,  0.740224779
    823, 0.0686669797,  0.779215097
    824, 0.0706212893,  0.817621231
    825, 0.0922733322,  0.799440145
    826, 0.00996115059,  0.764272451
    827, 0.0179217849,  0.719369829
    828, 0.0355158858,  0.755146086
    829, -0.000947717344,  0.758265078
    830, 0.0315875374,  0.747369587
    831, 0.0404671356,  0.749926925
    832, 0.0213011894,  0.698791623
    833,  0.070525676,  0.780771434
    834, -0.00404536398,  0.761017263
    835, 0.0880026817,  0.811574638
    836, 0.0163640324,  0.700712323
    837, 0.0138150975,  0.716402292
    838, 0.0246177092,  0.712428927
    839, 0.0652641654,  0.831252813
    840, 0.0949482024,  0.825842023
    841, 0.0629670024,  0.770791173
    842, 0.0617336445,  0.775422037
    843, 0.0583481751,  0.764544904
    844, 0.0330246724,  0.778493345
    845, 0.0353487805,  0.780964971
    846, 0.0142589631,  0.762072563
    847, 0.0254296251,   0.77590704
    848, 0.0408498161,  0.785413563
    849, 0.0662863925,  0.778151751
    850,   0.03021615,  0.773627281
    851, 0.0543355756,  0.761725187
    852, 0.0441024229,  0.787251294
    853, 0.0377646051,  0.780825555
    854, 0.0224523488,  0.776058316
    855, 0.0601451956,   0.76575458
    856, 0.0496689677,  0.792612553
    857, 0.0552382842,   0.79527849
    858, 0.0217237808,  0.726676404
    859, 0.0262821801,  0.738499343
    860, 0.0627257228,  0.768479586
    861, 0.0499225408,  0.754796207
    862, 0.0299932472,  0.738385558
    863, 0.0771836638,  0.790633321
    864, 0.0200821031,  0.730262816
    865, 0.0829563588,   0.79219377
    866, 0.0723899901,  0.784400702
    867, 0.0550092235,  0.797587156
    868, -0.00865135528,  0.755562127
    869, 0.0474973843,  0.788412392
    870, 0.0877496079,  0.797577977
    871, 0.0231002234,   0.73587662
    872, 0.0423221663,  0.752560616
    873, 0.0190189816,  0.772926629
    874, 0.0215724334,  0.722640872
    875, 0.0075612287,  0.759505928
    876, 0.0603333004,  0.798762202
    877, 0.0329257175,  0.753755629
    878, 0.0190846305,   0.76691097
    879, 0.0834338963,  0.815655828
    880, 0.0142784808,  0.719853222
    881, 0.0852852017,  0.802753329
    882, 0.0691030622,  0.783452749
    883, 0.00365228951,   0.75865823
    884, 0.0311408322,  0.749755859
    885,  0.067531459,   0.78134197
    886, 0.0689273328,  0.813370705
    887, 0.0128602432,   0.71285212
    888, -0.00494211819,    0.7565611
    889, 0.0895965919,  0.793141842
    890, 0.0601773486,  0.833118796
    891, 0.0704755634,  0.829869449
    892, 0.0110148899,  0.760829926
    893, 0.0081163561,  0.708339512
    894, 0.0897575915,  0.831791878
    895,  0.035288658,  0.778399348
    896, 0.0222533587,  0.773184836
    897, 0.0329083987,  0.775885046
    898, 0.0608989522,  0.771029532
    899,   0.06385196,  0.777170718
    900, 0.0614310391,  0.773155808
    901, 0.0434584618,  0.784961581
    902, 0.0275160056,  0.774246037
    903, 0.0566055849,  0.765554428
    904, 0.0509056859,  0.760566115
    905,  0.056664478,  0.764038682
    906, 0.0208848156,  0.772024572
    907, 0.0238994155,  0.774505317
    908, 0.0494049825,  0.790051937
    909, 0.0402201079,  0.780625463
    910,   0.06536185,  0.780344188
    911,  0.080751285,  0.795643449
    912, 0.0459592342,  0.784410536
    913,  0.075352788,   0.79589653
    914, 0.0174760018,  0.762986839
    915, 0.0578785315,  0.766613424
    916, 0.0735677108,  0.793399692
    917, 0.0288454127,  0.742013812
    918,  0.084464252,  0.798639774
    919, 0.0523961559,  0.792614937
    920, 0.0465380587,  0.753304243
    921, 0.0180039033,  0.722896993
    922, 0.0196531843,  0.733545363
    923, 0.00895847939,  0.755387545
    924, 0.0177091863,  0.726352692
    925,  0.040504355,  0.783023357
    926, 0.0638681799,  0.796899438
    927, 0.0109638711,   0.72030592
    928, 0.0181991886,  0.760114074
    929, 0.0340365507,  0.757900119
    930, 0.0297887698,  0.746066153
    931, 0.0675260127,  0.786986172
    932, 0.0198839754,  0.736472487
    933, 0.0580019243,   0.79565388
    934, 0.000299426611,  0.754028201
    935, 0.0807095245,  0.806410313
    936, 0.0297790747,  0.752842009
    937, -0.0103926323,  0.759372771
    938, 0.0872325674,  0.820792437
    939, 0.0124529665,  0.757660449
    940, 0.0682590008,   0.80889082
    941, 0.0737018511,  0.821245551
    942, 0.00891575776,  0.713683128
    943, 0.0870032981,  0.833290339
    944, 0.0741778091,  0.824805737
    945,  0.042673368,  0.780372381
    946, 0.0252796765,  0.772882342
    947, 0.0234696195,  0.771481633
    948, 0.0601546466,  0.777271509
    949,  0.032717187,  0.773182571
    950, 0.0278200191,  0.772109807
    951, 0.0548550226,  0.764143705
    952, 0.0583609827,  0.769069552
    953, 0.0520803519,  0.762904763
    954, 0.0399981774,  0.778163314
    955,  0.058494702,  0.792588711
    956,  0.045616325,  0.757487714
    957,  0.021432301,  0.769864976
    958, 0.0209865104,   0.76360023
    959, 0.0495289974,  0.787680507
    960, 0.0627982989,   0.78263706
    961, 0.0609134212,  0.796014726
    962, 0.0711984187,  0.788148761
    963, 0.0778638124,  0.798861742
    964, 0.0144281629,  0.723092675
    965, 0.0554089695,  0.765960038
    966, 0.0186168514,   0.75797224
    967, 0.0488713533,  0.785704672
    968, 0.0167947654,  0.729973733
    969, 0.0637304857,  0.802185059
    970, 0.0226516649,  0.741685212
    971, 0.0282315761,  0.748755693
    972, 0.0314666703,  0.756906509
    973, 0.0352000371,  0.775747478
    974, 0.00439503975,  0.754846811
    975, 0.0623867474,  0.779600382
    976, 0.0812384784,  0.802563071
    977, 0.0799199268,  0.810464561
    978, 0.0146780601,  0.754979253
    979, 0.0525554493,  0.757125199
    980, 0.0523319282,  0.789886355
    981,  0.025466511,  0.743800402
    982, 0.0715670958,  0.797139108
    983, -0.00232410594,  0.748745143
    984, 0.0162191242,  0.733857512
    985, 0.0744283423,  0.813394845
    986, 0.0910103545,  0.821590722
    987, 0.0823313296,  0.820666313
    988, 0.0767962858,  0.821045101
    989, 0.0795981362,  0.789565027
    990, 0.00800816715,  0.719233215
    991, 0.0753314421,  0.828573704
    992, 0.0853274688,  0.829482734
    993, 0.0587393269,  0.771594346
    994, 0.0580607466,  0.775230169
    995, 0.0374804251,  0.775713027
    996, 0.0263929572,  0.771203041
    997, 0.0501886681,  0.764312267
    998, 0.0451142155,  0.780098677
    999, 0.0472334363,  0.759693205
   1000, 0.0618216693,  0.792962968
   1001, 0.0583763272,  0.778921723
   1002, 0.0539503992,  0.768214285
   1003, 0.0635216907,  0.785162568
   1004, 0.0228738524,  0.745150983
   1005, 0.0475167595,  0.779813349
   1006, 0.00504538883,  0.750966847
   1007, 0.0212140754,   0.76002717
   1008,  0.055325482,  0.789703012
   1009, 0.0542158782,  0.766365409
   1010, 0.0714895874,  0.804018199
   1011, 0.0374410078,  0.773059845
   1012,  0.079021275,  0.814519465
   1013, 0.0416288897,  0.757119775
   1014, 0.0664310306,  0.790716708
   1015, 0.0700448528,  0.806205213
   1016, 0.0665446296,  0.799292445
   1017, 0.0398132131,  0.754746854
   1018,  0.039331615,  0.759282053
   1019, 0.0106712934,  0.724335313
   1020, 0.0165248774,   0.73766458
   1021, 0.0256660935,  0.747315228
   1022, 0.0746170655,  0.798347116
   1023, 0.0169338062,  0.756690264
   1024,  0.028354045,  0.756104231
   1025, 0.0171658564,  0.752716541
   1026, 0.0423920155,  0.777965486
   1027, 0.0266190134,  0.751736999
   1028, 0.0520361252,  0.787185013
   1029, 0.0296955314,  0.770861983
   1030, 0.0776613131,   0.80211705
   1031, 0.0510857813,  0.784318268
   1032, 0.0839163885,  0.811301231
   1033, 0.0597338751,   0.78075254
   1034, 0.0761357471,  0.809365094
   1035, 0.0837925673,  0.825551391
   1036, 0.0130634904,  0.729667246
   1037, -0.0063930857,  0.743049681
   1038, 0.0813610107,  0.830967069
   1039, 0.0397060588,  0.773217797
   1040, 0.0236764196,  0.768316865
   1041, 0.0388889685,  0.763743758
   1042, 0.0559477583,  0.772461236
   1043, 0.0562412627,  0.777240992
   1044, 0.0625765622,  0.789451063
   1045, 0.0260753799,  0.768975079
   1046, 0.0487253368,  0.762032986
   1047, 0.0549566895,  0.786792696
   1048,   0.04841768,  0.765952587
   1049, 0.0470421351,  0.777542531
   1050, 0.0378367715,  0.770339549
   1051, 0.0275887493,  0.769579589
   1052, 0.0227326881,  0.766121328
   1053, 0.0444929339,  0.775246739
   1054, 0.0208982043,  0.757042229
   1055, 0.0507075563,  0.781509459
   1056, 0.0585943386,  0.789610028
   1057, 0.0421460643,  0.775482357
   1058, 0.0602836162,   0.78324604
   1059, 0.0319386721,  0.768565178
   1060, 0.0218268372,  0.752725005
   1061, 0.0525336005,   0.77078259
   1062, 0.0543669723,  0.783706069
   1063, 0.0433181673,  0.759411573
   1064, 0.0215102024,  0.748309016
   1065, 0.0410683937,  0.761492193
   1066, 0.0741947666,  0.801477075
   1067, 0.0277236924,  0.759252191
   1068, 0.0175334811,   0.74867034
   1069, 0.0572998151,   0.78093791
   1070, 0.0502857156,  0.768130243
   1071, 0.0195107535,  0.750659704
   1072, 0.0305789243,  0.759760022
   1073, 0.0244792961,  0.755390644
   1074, 0.0124569936,  0.752856731
   1075, 0.00919794664,  0.728852153
   1076, 0.00292727235,  0.745866179
   1077, 0.0658119097,  0.807102263
   1078, 0.0143755917,  0.743022442
   1079, 0.0739726275,  0.804639518
   1080, 0.0122113787,  0.733999431
   1081, 0.0875869468,  0.824757993
   1082, 0.0320661366,  0.743318617
   1083, 0.0652014762,  0.794049263
   1084, -0.00973808207,  0.745130897
   1085, 0.0791154653,  0.836658001
   1086, 0.0441659205,  0.772756398
   1087, 0.0468291603,  0.775020897
   1088, 0.0466976799,  0.763775051
   1089, 0.0429234914,  0.763600945
   1090, 0.0574583672,  0.783602059
   1091, 0.0351866409,  0.769418001
   1092, 0.0323082842,  0.763334572
   1093, 0.0192245506,  0.744865119
   1094, 0.0280764233,  0.767398596
   1095, 0.0301803909,   0.76807946
   1096, 0.0485343784,  0.769736052
   1097, 0.0348346159,  0.764631033
   1098, 0.00688197138,  0.737738252
   1099,  0.053892009,  0.780001283
   1100, 0.0491073243,  0.777384818
   1101, 0.0192535669,  0.754743099
   1102, 0.0090806447,  0.748568118
   1103, 0.0580493659,  0.786575794
   1104, 0.0258023087,  0.767377973
   1105, 0.0543661006,  0.775216579
   1106, 0.0501979776,  0.771258533
   1107, 0.0636565685,  0.805383742
   1108, 0.00852288771,  0.743506253
   1109, 0.0414625183,    0.7700243
   1110, -0.00120334758,  0.744440258
   1111, 0.00585130276,  0.723163545
   1112, -0.0132914931,  0.747822404
   1113, 0.0392538644,  0.768008411
   1114,  0.033300709,  0.767081022
   1115, 0.0310725588,  0.765701354
   1116, 0.0283925999,  0.764586151
   1117, 0.0275731348,  0.762031317
   1118, 0.0491139479,  0.775242805
   1119, 0.0520158298,  0.773772717
   1120, 0.0370515063,  0.766381085
   1121, 0.0495741144,  0.773071945
   1122, 0.0528902523,  0.777268887
   1123, 0.0409930386,  0.765736103
   1124, 0.0435994901,  0.770699024
   1125, 0.00101588643,  0.720587671
   1126, 0.0209930986,  0.767593741
   1127, 0.000573761761,  0.740343153
   1128, 0.0448021106,  0.765644908
   1129, 0.00483396975,  0.741832078
   1130, -0.0120474566,   0.75433749
   1131, 0.0194573067,  0.747258544
   1132, -0.00410104869,  0.738450646
   1133, -0.0132457735,  0.744188309
   1134, 0.0430423543,  0.767622888
   1135, 0.0506328531,  0.777222931
   1136, 0.0450294316,  0.769438744
   1137, 0.0511956364,  0.775842905
   1138,  0.025337033,   0.76507622
   1139, 0.00631749863,  0.747205734
   1140, 0.00251046242,  0.736355841
   1141, -0.0150451632,  0.752368689
   1142, 0.00813958701,  0.733325243
   1143, 0.000687918626,  0.731586695
   1144, 0.0112774447,  0.745699346
   1145, -0.000105536856,  0.716940165
   1146, -0.000370992464,  0.727909863
   1147, 0.00489223516,  0.728067875
   1148, -0.00177211978,  0.734458148
   1149, -0.00144788856,  0.722070456
   1150, -0.00694849202,  0.721918762
   1151, 0.0897107422,  0.836971283
   1152, -0.0220428146,  0.772640944
   1153,  0.104719214,  0.836697936
   1154, -0.00631246483,  0.727205634
   1155, 0.0813405737,  0.840788305
   1156, 0.0936639979,  0.802732646
   1157, 0.00713816378,  0.699020803
   1158, -0.00502362475,  0.765199661
   1159, -0.0210812259,  0.752308428
   1160, 0.00815714523,  0.894639671
   1161, -0.0412855335,  0.767758667
   1162, -0.047656212,  0.760415316
   1163, -0.0449657589,  0.734534979
   1164, 0.0624427274,  0.838677943
   1165, -0.0532022938,  0.866536975
   1166, -0.0514122359,  0.856290102
   1167, -0.0492739193,  0.851618588
   1168, -0.0308489539,  0.842561424
   1169, -0.0358134918,   0.84263587
   1170, -0.0446101166,  0.844751894
   1171, -0.0475202017,  0.847551525
   1172, -0.0405217521,  0.843326271
   1173, -0.0258658379,  0.843220353
   1174, -0.0528276004,  0.861222386
   1175, 0.0783298686,  0.823494613
   1176, 0.0192632265,  0.692891061
   1177, 0.0538348705,  0.895818293
   1178, 0.0631242245,   0.88146317
   1179, 0.0659405664,  0.877202094
   1180, -0.00459939335,  0.874947846
   1181, 0.0190403704,    0.9018206
   1182, 0.0418073758,  0.899796486
   1183, -0.00224057725,  0.880239189
   1184, 0.0120335035,  0.709562302
   1185, 0.0230247714,  0.660674512
   1186,  0.112328313,  0.847206414
   1187, -0.0212799236,  0.759792447
   1188, -0.034152016,  0.772990465
   1189, -0.0349565037,  0.726141095
   1190, 0.0944146141,  0.818076551
   1191, -0.00583564211,  0.731155992
   1192,  0.112772182,  0.853174746
   1193, -0.0188631453,  0.744115829
   1194, -0.0507540815,  0.747204244
   1195, 0.0723685846,  0.834339619
   1196,  0.113071598,  0.859362006
   1197, -0.0113184052,  0.740231037
   1198, -0.00199165591,  0.712592304
   1199, -0.0163594242,  0.659351289
   1200, -0.0230691284,  0.659855187
   1201, 0.00942597724,   0.65998137
   1202, -0.00378265604,   0.65861845
   1203, -0.0101700919,  0.658405721
   1204, 0.0027099445,   0.65928632
   1205,  0.103243031,  0.821307898
   1206,   0.11322429,  0.865768373
   1207, 0.0836036354,  0.928896308
   1208, -0.0189019758,  0.933392465
   1209,  0.111789666,  0.878794909
   1210, 0.0668041483,  0.938814819
   1211,  0.103344083,  0.903498352
   1212, -0.0447080433,  0.903423309
   1213, -0.00234821136,   0.94190675
   1214, -0.0409784913,  0.908624649
   1215,  0.100017376,  0.909114718
   1216, -0.0323765688,  0.918696761
   1217, 0.0242583826,  0.947867215
   1218, 0.0369582437,  0.949878514
   1219, 0.0422577746,  0.948955119
   1220, 0.0308464263,  0.949049532
   1221, 0.0922603309,  0.919422388
   1222, -0.00833902508,  0.939605236
   1223, 0.0726897344,  0.935575545
   1224, -0.0518943667,  0.878968954
   1225, -0.0528537631,  0.872597158
   1226, -0.0237188116,  0.696021914
   1227, -0.0232660417,  0.681571186
   1228, -0.0228887517,  0.674328446
   1229, -0.0236083698,  0.688702583
   1230, -0.0226567779,  0.667097747
   1231, 0.0303610638,  0.901307464
   1232,  -0.02740358,  0.712411165
   1233, -0.0232550222,  0.704668999
   1234, 0.00286174542,   0.71061343
   1235,  0.111509524,   0.84137553
   1236, 0.0248697791,  0.691655636
   1237, -0.0140849994,  0.855555296
   1238, 0.0649823621,  0.852046847
   1239, -0.00940125063,  0.878107488
   1240, 0.0171067212,  0.686018288
   1241, -0.0297948029,  0.761381984
   1242, -0.0431219451,  0.852638304
   1243, -0.0135583533,  0.733729482
   1244,  0.105784692,  0.842227638
   1245, 0.0702710599,  0.841058969
   1246, 0.0715673268,  0.848130822
   1247, -0.0135732973,  0.868607998
   1248, -0.0448866561,  0.747552991
   1249, 0.0594726726,  0.899582446
   1250, 0.00311005698,  0.897298872
   1251, 0.0706041679,  0.858211994
   1252, 0.0111472737,  0.898684621
   1253, 0.0465874411,  0.899219394
   1254, 0.0928002894,  0.841138303
   1255, 0.0365918986,  0.907089174
   1256, 0.0253132153,  0.906930208
   1257, -0.0450499021,  0.754094958
   1258, 0.0746649876,  0.838533878
   1259,  0.105770841,  0.877299488
   1260, 0.0200815797,  0.907646358
   1261, 0.0421377644,  0.905501068
   1262, -0.0182915684,  0.731448352
   1263, -0.0240415856,  0.748403907
   1264, 0.0705225244,  0.852859199
   1265, -0.00646827603,  0.715206802
   1266, -0.0373017266,  0.764322639
   1267, 0.0109599754,  0.689173639
   1268, -0.0231938493,  0.740838349
   1269, 0.000807275006,  0.885553777
   1270, 0.0386594795,  0.944994986
   1271, 0.0743533969,  0.924765944
   1272, -0.00486410456,    0.6645118
   1273, 0.0682283789,  0.885188758
   1274,  0.107096985,  0.865665197
   1275, -0.0188019201,  0.851468444
   1276, -0.0316290669,  0.908493698
   1277, 0.0941998512,  0.905361712
   1278, -0.000175955924,  0.700145066
   1279, -0.0476337597,  0.897838414
   1280, -0.0505358726,  0.885452092
   1281, -0.0320263691,  0.847970665
   1282, -0.0230566505,  0.850142717
   1283, -0.037786644,  0.734247923
   1284, -0.0402610898,  0.899778545
   1285,  0.099491708,  0.895068228
   1286, -0.0429440141,  0.757585764
   1287, -0.0165578816,  0.681951582
   1288, -0.0473237224,  0.866322458
   1289, -0.0135470275,    0.7225492
   1290, 0.0880514756,  0.843463123
   1291, 0.000859586988,  0.705589414
   1292, 0.0600688122,  0.886390269
   1293, -0.0455818884,  0.877755821
   1294, 0.0747444108,  0.874870598
   1295, -0.0161270741,  0.701378822
   1296, -0.0118333884,  0.933033824
   1297, -0.0224746708,  0.715715587
   1298, 0.00487916917,  0.692403018
   1299, 0.0083007291,  0.667213678
   1300,  0.106459267,  0.853430986
   1301,  0.110100985,  0.885176361
   1302, -0.0176648479,  0.695118129
   1303, -0.0145431161,  0.666970968
   1304, 0.0327841863,  0.943041325
   1305,   0.10599108,  0.897523165
   1306, 0.0507575832,  0.936363578
   1307, 0.0118994247,  0.939029872
   1308, -0.0356091261,   0.73728168
   1309, 0.0756504983,   0.85360688
   1310, 0.00550764566,  0.901521027
   1311, 0.0515409522,  0.901312828
   1312, -0.0345726088,  0.761214495
   1313, -0.00142519572,  0.694426119
   1314, 0.00262048375,  0.687002718
   1315, 0.0734724849,  0.888457417
   1316, -0.0119954543,   0.88648814
   1317, -0.000362792431,  0.893405974
   1318, -0.00068327738,  0.899793863
   1319, 0.0648717731,  0.903238595
   1320, -0.0129867829,  0.694598973
   1321, -0.0292838495,  0.853768349
   1322, 0.0309571419,  0.911693215
   1323, -0.0140352491,  0.714722633
   1324, -0.0249735638,  0.764838159
   1325, -0.0205529388,  0.736173511
   1326,  0.102070332,  0.847957551
   1327, -0.0333964601,  0.852505207
   1328, -0.0417938456,  0.865026832
   1329, 0.0739387572,  0.844598114
   1330, -0.0128852036,  0.706169486
   1331, -0.0408150852,  0.870475233
   1332, -0.0440993421,   0.88402611
   1333, -0.0278582666,  0.744281709
   1334, -0.00995594729,  0.682653129
   1335, -0.0404583476,  0.761055231
   1336, -0.0115112346,  0.873302996
   1337, 0.0624440834,  0.894846916
   1338, 0.0490122177,  0.906649292
   1339, 0.00921461917,  0.911015332
   1340, -0.0143053131,  0.880839705
   1341,  0.075804688,  0.883612216
   1342,  0.100356176,  0.859709084
   1343, -0.0207985956,  0.724201798
   1344, -0.0386707708,  0.754712939
   1345,  0.112935446,  0.872268081
   1346, -0.0325071402,  0.899131238
   1347, 0.0929896832,  0.893726766
   1348, -0.0249252655,  0.855519891
   1349,  0.103465497,  0.883156955
   1350, -0.0403660499,  0.744246602
   1351, 0.0901954919,  0.848655641
   1352, -0.028088497,  0.752700865
   1353, -0.0438158922,  0.741026878
   1354, 0.0783664882,  0.846483827
   1355, -0.0103321271,  0.718542278
   1356, 0.0794838965,  0.886051476
   1357, -0.0345508046,  0.752258837
   1358, 0.0852992609,  0.854156613
   1359, 0.0991066769,  0.852707505
   1360, 0.0271551423,  0.917288423
   1361, 0.0017128964,  0.908289254
   1362,  0.053503301,  0.909931719
   1363, -0.0357760601,  0.862897694
   1364, -0.0162003953,  0.875683129
   1365, -0.00329338131,  0.688674808
   1366, 0.0803369507,  0.853848577
   1367, -0.0294331107,  0.732362926
   1368, 0.0111835711,  0.915953219
   1369, 0.0501553789,  0.914635241
   1370, -0.0109472163,  0.698430181
   1371, -0.0259045251,  0.721560955
   1372, -0.0321218669,  0.756033599
   1373, 0.0682852566,   0.89856863
   1374, 0.0713633373,  0.893713415
   1375, -0.014784921,  0.895802438
   1376, -0.0318319947,   0.85830307
   1377,  0.069854632,  0.906941056
   1378, -0.00406666426,  0.909996271
   1379, -0.0332012698,  0.742546558
   1380, -0.00547465868,  0.898142993
   1381, -0.0070330184,  0.695979774
   1382, -0.0230795797,  0.729186118
   1383, -0.0101452218,   0.68995595
   1384, -0.0237299539,  0.862760186
   1385, -0.0155114168,  0.863047063
   1386, 0.0388335213,  0.912287474
   1387, -0.0194102321,  0.883005798
   1388,  0.100776754,  0.866574407
   1389, 0.0212073326,  0.912843227
   1390, 0.0546347126,  0.918274224
   1391, 0.00887447782,  0.922887087
   1392, -0.0272286255,   0.86643523
   1393, -0.00389394723,   0.68293047
   1394, 0.0177859105,   0.91890651
   1395, 0.0435501598,  0.917592824
   1396, -0.0247337613,  0.884539425
   1397, 0.0833458751,  0.883977592
   1398, -0.0208181422,  0.877618551
   1399, 0.0386115387,  0.917741776
   1400, 0.0222801864,  0.917488754
   1401, 0.0948130935,  0.861061454
   1402, 0.0962794721,  0.865356088
   1403, 0.0809098706,  0.860872149
   1404, -0.0362165272,  0.747777045
   1405, -0.0205470771,  0.866559148
   1406, 0.0830694586,  0.864337146
   1407, -0.022497911,  0.873737633
   1408, -0.0307330936,  0.868349075
   1409, 0.00105142163,  0.921299279
   1410,  0.084171094,  0.876040399
   1411, 0.0612463839,  0.918762863
   1412, 0.0475288108,  0.919340551
   1413, 0.0200183988,  0.923433602
   1414, -0.00893258024,  0.675985157
   1415, -0.0290645566,   0.87276268
   1416,  0.102963507,  0.871033728
   1417,  0.032946609,  0.917012513
   1418, 0.0133889429,  0.920852423
   1419, -0.0340483934,  0.874664903
   1420, 0.0236209109,  0.927049696
   1421, 0.0113415476,  0.927597582
   1422, 0.0192035474,  0.932325661
   1423, 0.0888108835,  0.872360885
   1424, 0.0806631148,  0.871532142
   1425, 0.0267001539,  0.922526956
   1426, 0.0901587978,  0.864521682
   1427, 0.0764889196,  0.862384617
   1428, -0.00713422382,  0.669980347
   1429, 0.0392742008,  0.923921943
   1430, 0.0514659472,  0.922812164
   1431, 0.0353157148,  0.931280732
   1432, 0.0444232225,  0.922482014
   1433, 0.00756158214,  0.928602099
   1434, 0.0609762631,  0.927719831
   1435, -0.0396044217,  0.876283944
   1436, 0.0926942006,  0.876547754
   1437, 0.0856488273,  0.868204296
   1438, -0.000482206844,  0.671703041
   1439, 0.0930095091,  0.868572533
   1440, 0.0715035722,  0.863576651
   1441, 0.0415465273,  0.930551708
   1442, 0.00138740265,  0.929752469
   1443, 0.0124134338,  0.933062553
   1444, 0.0639772415,  0.923546612
   1445, -0.0321141891,  0.880154788
   1446, -0.0360353589,  0.887641311
   1447, -0.0303035099,  0.886157632
   1448, 0.0310642347,  0.932265878
   1449,  0.043025177,  0.938997149
   1450, 0.00541904988,  0.937703431
   1451,  0.100582935,  0.875148416
   1452,  0.035190437,   0.93759805
   1453, -0.000714212831,   0.93535769
   1454, -0.0228469782,  0.890990734
   1455, -0.020703733,  0.897669613
   1456, -0.0115122618,  0.903461039
   1457, -0.0100278668,  0.911461294
   1458, -0.00186023128,  0.915835679
   1459,  0.016190175,  0.660499036
   1460, 0.0506292842,  0.744311988
   1461, 0.0660848096,  0.864715755
   1462, -0.0497704037,  0.756225944
   1463, -0.0509558581,  0.751735747
   1464, -0.0479821563,  0.738486826
   1465, 0.0541541688,  0.943701684
   1466, 0.0106831416,  0.945732296
   1467, -0.0234750919,  0.928771615
   1468, -0.0279564336,  0.923766375
   1469, -0.0165946316,  0.846403301
   1470, -0.0126644662,  0.848984957
   1471, -0.00972363912,  0.852687478
   1472, -0.00741795404,  0.856811762
   1473, -0.00583255664,  0.860982001
   1474, -0.00507605728,  0.864434063
   1475, -0.00892198645,  0.866707981
   1476, 0.0690215752,  0.873910725
   1477, -0.0119199725,  0.859218895
   1478, -0.0153011419,  0.852091074
   1479, 0.0449883118,  0.742588401
   1480, 0.0565974116,  0.904708445
   1481, 0.0146693764,  0.909038961
   1482,  0.073004134,   0.86869961
   1483, -0.0183956996,  0.924147308
   1484, -0.0147531694,  0.929214656
   1485, 0.00738851912,  0.906102121
   1486, 0.0491664521,  0.752010822
   1487, 0.0627412647,  0.753521919
   1488, -0.0332745947,  0.766968727
   1489, -0.0464910157,  0.857653499
   1490, -0.044059597,  0.848174036
   1491, -0.040724311,  0.847875357
   1492, -0.0461751521,  0.743776977
   1493, 0.0308001433,  0.906606853
   1494, -0.0434430614,   0.89625752
   1495, 0.0344572142,  0.791625977
   1496, -0.0336287022,  0.732155383
   1497,  0.086174123,  0.914693236
   1498, 0.0802640915,  0.924486518
   1499, 0.0574024729,  0.934538782
   1500, 0.0558084399,  0.811856568
   1501, 0.0697502941,  0.821291625
   1502, -0.0100058503,  0.926676333
   1503, 0.0762730837,  0.849844933
   1504, 0.00616548676,  0.918283105
   1505, -0.0434779674,  0.860489786
   1506, -0.0376591459,  0.852201164
   1507, -0.00908934418,  0.892484546
   1508, 0.0549584776,  0.803866148
   1509, -0.00509857479,  0.904263794
   1510, 0.0666219369,  0.911510348
   1511, 0.0640135407,  0.915984094
   1512, 0.0497503392,  0.757700562
   1513, 0.0440014862,  0.755095363
   1514, 0.0368427522,  0.744589746
   1515, 0.0173013285,  0.779663324
   1516,  0.046733886,  0.797128618
   1517, 0.0255451929,  0.934471369
   1518, 0.0212809518,  0.715254545
   1519, 0.0742205307,  0.817684054
   1520, -0.00952656474,  0.710827768
   1521, -0.0249850508,  0.734068096
   1522, 0.0832966045,  0.845061243
   1523, 0.0118407775,  0.703619182
   1524, -0.0345776342,  0.856111944
   1525, -0.0370564982,  0.895567656
   1526, -0.0304082185,  0.864339769
   1527, 0.0478378348,  0.755738497
   1528, 0.0644628331,   0.75653547
   1529, -0.00444404501,  0.707622409
   1530, 0.000711962639,  0.683130503
   1531, 0.0800708458,  0.857548118
   1532, 0.0801532045,  0.850191772
   1533, -0.0374849811,  0.740533412
   1534, 0.0993588641,  0.826256037
   1535, -0.0340852253,  0.892170429
   1536, 0.0462422632,  0.793947756
   1537, 0.0770125464,  0.917371333
   1538, 0.0930653438,  0.886728644
   1539, 0.0932052359,  0.898386836
   1540, 0.0842777044,  0.904678881
   1541, 0.0865934715,  0.895219147
   1542, 0.0554377809,  0.927153111
   1543, 0.0280993413,  0.929587066
   1544, 0.0635856912,  0.809744298
   1545, 0.0712300166,   0.81482619
   1546,  0.083302103,  0.834997952
   1547, 0.0735270008,   0.91063112
   1548, 0.0530656986,  0.759631395
   1549, -0.0270456504,  0.738773286
   1550, -0.0255163927,  0.898067057
   1551, 0.0837785676,  0.858263373
   1552, 0.0916079357,  0.855395079
   1553, 0.0711154267,  0.810766459
   1554, 0.0238510296,  0.779894769
   1555, 0.0274636988,   0.74486208
   1556, -0.0179915614,  0.755574882
   1557, -0.0143345622,  0.757981122
   1558, -0.00965595245,  0.725346982
   1559, -0.011467943,   0.72933042
   1560, 0.0377160907,  0.756995857
   1561,  0.100211069,  0.843559563
   1562, 0.0728527904,  0.807862222
   1563, 0.00317999674,  0.770340383
   1564, 0.0616979748,  0.756780684
   1565, 0.00660384027,  0.770050406
   1566, 0.0634210631,  0.757774174
   1567, 0.0654894933,  0.760126054
   1568, 0.0257901661,  0.741467893
   1569, 0.0943682641,  0.829892159
   1570, 0.0949659199,  0.821898699
   1571,  0.081940636,  0.783938587
   1572, 0.0913840979,  0.807251275
   1573, 0.0889928937,  0.800808847
   1574, 0.0866902173,  0.794350982
   1575, -0.00654322281,  0.759856462
   1576, 0.0360512622,  0.758730352
   1577, 0.0531631894,  0.764985263
   1578, 0.0517782345,  0.766426444
   1579, 0.0376164727,  0.778294861
   1580, 0.0626243204,  0.798704088
   1581, 0.0466886573,  0.767700553
   1582, 0.0908601359,  0.824992895
   1583, 0.0913506597,  0.818719625
   1584, -0.012877333,  0.750400603
   1585, -0.00714143179,  0.751964986
   1586, -0.00353621412,  0.752885759
   1587, 0.0251883194,  0.778751552
   1588, 0.0430207364,  0.782682836
   1589,   0.06784679,  0.804277241
   1590, 0.0634058937,  0.800354898
   1591, 0.0040995474,  0.732348084
   1592, 0.00376856746,  0.719972491
   1593, 0.0333199576,  0.760658562
   1594, 0.0684153363,   0.79563868
   1595, -0.00972742401,  0.747945189
   1596, 0.0626472384,  0.765974164
   1597, 0.0398233011,  0.775653064
   1598, 0.0610478558,  0.786106348
   1599, 0.0021702738,  0.765769243
   1600, 0.0605275594,  0.768613696
   1601, 0.0298453271,  0.762325943
   1602, 0.0205320399,  0.738717675
   1603, 0.0185557418,  0.741217494
   1604, 0.0265214145,  0.777426183
   1605,  0.083721377,  0.795215786
   1606, 0.0811412334,  0.798973382
   1607, 0.0812881365,  0.787554026
   1608, 0.0633631796,  0.760015011
   1609, -0.00624762196,  0.747978568
   1610, 0.0246404279,  0.762497187
   1611, 0.0782500654,  0.783482671
   1612, 0.0418799371,  0.772960901
   1613, 0.0702901781,  0.801130831
   1614, 0.0644743443,  0.787205577
   1615, 0.0447687246,  0.777736902
   1616, 0.0559562221,  0.767519057
   1617, 0.0396516733,  0.771153927
   1618, 0.0484176353,  0.783951223
   1619, 0.0670571178,  0.770900726
   1620, 0.0778063163,  0.795806587
   1621, 0.0151527682,  0.750573039
   1622, 0.0694716945,  0.773225844
   1623, 0.0324091502,  0.770528018
   1624, 0.0657332242,  0.784472823
   1625, 0.0160401966,  0.746100307
   1626, 0.0748178214,  0.782723308
   1627, 0.0598201975,  0.773852289
   1628, 0.0480663627,  0.781920791
   1629, 0.0651409402,  0.773015797
   1630, 0.0109005533,  0.750316679
   1631, 0.00828684773,  0.751423597
   1632, 0.0497977883,  0.779430091
   1633, 0.0516601987,  0.778544962
   1634, 0.0632707551,  0.774501503
   1635, 0.0668673068,  0.782985985
*Element, type=CPS3
 1, 1417, 1322,  129
 2,  159, 1517,  152
 3, 1268, 1333, 1549
 4,  716,  238,  617
 5,  782,  788,  734
 6, 1607,  740,  989
 7,  763,  715,  727
 8,  821,  722,  765
 9, 1514,  778,  640
10,  873,  820,  773
11, 1587, 1604,  756
12,  885,  882, 1635
13,  915,  843,  855
14,  908,  856,  809
15,  990,  271,  927
16,  959,  908,  869
17, 1019,  964,  264
18, 1102, 1630, 1631
19, 1601, 1116, 1117
20, 1618, 1031,  967
21, 1069, 1001, 1033
22, 1633, 1122, 1099
23,  263, 1149, 1125
24, 1491, 1242, 1490
25, 1218, 1270, 1219
26, 1354, 1329,  178
27, 1381,  275, 1370
28, 1503, 1354, 1532
29, 1408, 1526, 1392
30, 1551, 1403, 1531
31, 1404,  241, 1357
32, 1509, 1456, 1380
33, 1386,  129, 1255
34,  163, 1407, 1398
35, 1511, 1411,  127
36, 1432, 1395, 1412
37, 1444,  144, 1411
38, 1385, 1477,  173
39, 1170, 1490, 1171
40, 1505,  169, 1489
41, 1502,  139,  155
42, 1506,  170, 1242
43, 1527,  861, 1512
44, 1367,  252, 1496
45, 1542,  151, 1430
46, 1548,  796,  851
47, 1575,  834,  231
48, 1582,  193, 1081
49, 1554, 1587,  703
50, 1608,  658,  721
51, 1002, 1616,  224
52, 1635, 1624,  212
53, 1626,  722,  866
54,  842, 1627,  900
*Element, type=CPS4R
  55, 1284, 1212, 1279, 1494
  56,  296, 1212, 1214,    3
  57, 1276,  136, 1214,  122
  58,  120,  135, 1276,  121
  59, 1456, 1457,  134,  120
  60, 1456, 1509, 1378, 1457
  61,  119, 1310, 1485, 1361
  62, 1181, 1260, 1481,  118
  63, 1493, 1256,  117, 1231
  64, 1261, 1255,  116, 1182
  65, 1362, 1338, 1311, 1480
  66,  114, 1319, 1377, 1510
  67,  125,  113,  112, 1540
  68, 1277,  111, 1539,  110
  69,  110, 1211, 1215, 1277
  70, 1497, 1221,  147,  146
  71, 1498, 1207,  148, 1271
  72,  308,  148, 1207,   13
  73,   12, 1223,  148,  308
  74,  307, 1210, 1223,   12
  75, 1210,  307,  306,  157
  76,  149, 1223, 1210,  150
  77,  144, 1444, 1434, 1542
  78,  126,  145, 1511, 1510
  79,  113, 1377, 1319, 1373
  80, 1211,  110, 1285, 1305
  81, 1211, 1305,  312,  311
  82,   98, 1301,  313,   16
  83,   16,  312, 1305,   98
  84, 1465,   11,  305,  158
  85, 1499,  157, 1465, 1306
  86, 1412, 1369, 1390, 1430
  87, 1338, 1362, 1369,  128
  88,  304, 1218, 1219,   10
  89, 1395, 1432, 1429, 1399
  90, 1395, 1399, 1386,  128
  91, 1386, 1255, 1261,  128
  92, 1409, 1504, 1391,  140
  93, 1433,  154, 1442,  140
  94,  156, 1296,  155, 1222
  95,  156,    6,  299, 1208
  96, 1483, 1467, 1468,  137
  97,  137,  134,  138, 1483
  98,  138,  134, 1457,  133
  99,  133, 1458, 1409,  139
 100, 1509,  119, 1361, 1378
 101, 1222,  300,    6,  156
 102, 1453, 1213, 1222,  155
 103, 1450, 1307, 1466,  161
 104, 1517,  159,  153, 1422
 105, 1218, 1220, 1304, 1270
 106, 1216,  135,  137, 1468
 107, 1276,  135, 1216,  136
 108,  104,    2,  294, 1280
 109, 1280,  294,    1, 1224
 110, 1526, 1408,  168, 1363
 111, 1348, 1321,  175, 1282
 112, 1471, 1470,   25,  321
 113,  322, 1473, 1472,   26
 114, 1472, 1473,  173, 1477
 115, 1336, 1247, 1475,  165
 116, 1387, 1396,  163, 1398
 117, 1525, 1535,  106, 1346
 118, 1212,  296,  295, 1279
 119, 1332,  105,  104, 1280
 120, 1415,  163, 1445, 1419
 121, 1385, 1405, 1384,  172
 122, 1471, 1472, 1477, 1237
 123,  173, 1475, 1247, 1385
 124, 1224,    1,  293, 1225
 125, 1288, 1328, 1331,   85
 126,  171, 1376, 1321, 1348
 127, 1168, 1173,  175, 1281
 128,  176,   24,  320, 1469
 129, 1489, 1166, 1167, 1242
 130, 1491, 1490, 1170, 1172
 131,  170, 1505, 1489, 1242
 132, 1165, 1288,   85, 1225
 133, 1165,   18,  315, 1174
 134,   85, 1293, 1224, 1225
 135,  318, 1169, 1172,   22
 136, 1321, 1327, 1281,  175
 137, 1168,   23,  319, 1173
 138,  165,   27,  323, 1180
 139, 1180,  323,   28, 1183
 140,  164, 1316, 1340, 1239
 141, 1454, 1455, 1550,  106
 142,  122, 1346,  121, 1276
 143, 1183,   28,  324, 1269
 144, 1317, 1250, 1318, 1380
 145, 1380, 1456, 1375, 1507
 146,  120, 1455, 1375, 1456
 147, 1455, 1454,  107, 1375
 148,  191,  542,  391,  390
 149,  483,  482,  392,   76
 150,  540,  645,  190,  596
 151,  879,  189,  938,  987
 152,  195, 1501,  941,  944
 153,  738,  728,  688,  634
 154,  479,  541,  335,  336
 155,  474,  479,  336,   39
 156,  468,  471,  337,  338
 157,  454,  518,  522,  459
 158,  678,  666,  717,  712
 159,  845,  895, 1579,  853
 160, 1041,  235, 1018, 1065
 161, 1017,  777,  831,  872
 162,  593,  640,  539, 1479
 163,  727,  675,  660,  768
 164,  763,  810,  265,  752
 165, 1147, 1075, 1142, 1591
 166, 1148, 1191, 1146, 1143
 167, 1197,  253, 1243,  254
 168, 1367, 1521, 1549,  252
 169, 1163,  259, 1283,  251
 170,  259,   51,  366, 1189
 171,  260, 1189,  267, 1371
 172,  267,   52,   53, 1232
 173,  274, 1297, 1232, 1233
 174, 1302,  279, 1383, 1320
 175, 1393,  285,  280, 1530
 176,   63, 1459, 1201,   62
 177,  292, 1185,   65,   66
 178, 1185,  372,   64,   65
 179,  288,  292,   66,   67
 180, 1240,  287,  288,  282
 181,  281, 1267, 1298, 1314
 182, 1278,  275, 1381, 1313
 183, 1520, 1323,  274, 1330
 184,  268, 1343, 1371, 1297
 185,  267, 1232, 1297, 1371
 186,  191,  646,  590,  542
 187, 1534,  742, 1569,  840
 188,  894,  943,  992,  193
 189, 1195,  891,  991,  182
 190,   37,  333,  890, 1164
 191,  728,  787,  196,  688
 192,  839,  728,  195,  891
 193,  184, 1254, 1151,  783
 194, 1155, 1085, 1546,  183
 195, 1258,  178, 1329, 1245
 196, 1164,  177,  332,   37
 197, 1531, 1366, 1358, 1551
 198, 1246, 1264, 1238,  177
 199, 1245, 1329, 1246,  177
 200,   36,  332,  177, 1238
 201, 1251, 1440, 1461,   87
 202, 1264, 1251,   87, 1238
 203, 1179,  330,   93, 1476
 204,   34,  330, 1179, 1178
 205, 1178, 1292,  329,   34
 206, 1319, 1249, 1337, 1373
 207,  114, 1480, 1249, 1319
 208, 1177, 1249, 1480, 1311
 209, 1177,  328,   33,  103
 210,  103,   33,  329, 1292
 211,  563,  566,  505,  502
 212,  439,  502,  505,  442
 213,  711,  747,  748,  709
 214, 1045, 1104, 1094, 1051
 215,  877,  936,  884,  247
 216,  830,  730,  247,  884
 217, 1082,  930, 1555,  917
 218, 1108, 1144, 1102, 1139
 219,  734,  834,  829,  782
 220,  644,  694,  592,  218
 221,  217,   44,  359, 1152
 222,  216, 1152,  359,   45
 223,  215, 1188,  360,   46
 224, 1188,  216,   45,  360
 225,  215,   46,  361, 1161
 226, 1286, 1335,  227, 1162
 227, 1162, 1462, 1257, 1286
 228, 1194,  250, 1492, 1248
 229, 1464,   50,  365, 1163
 230, 1353, 1464, 1163,  251
 231, 1158,  695,  632,  592
 232,  217,  481,  358,   44
 233,  481,  217,  644,  218
 234,  464,  533,  526,  457
 235,  464,  457,   43,  356
 236,  434,  503,  555,  486
 237,  650,  649,  697,  698
 238,  602,  650,  698,  651
 239,  436,  439,  345,  346
 240,  344,  345,  439,  442
 241,  227,   47,  362, 1162
 242,   48, 1462, 1162,  362
 243, 1194,   49,  364,  250
 244,   55, 1229, 1226,   54
 245,   54, 1226, 1233,  367
 246, 1414, 1334, 1287,  284
 247,  285, 1438,  286,  280
 248,  291, 1299, 1201, 1459
 249, 1459,   63,  372, 1185
 250, 1302, 1226, 1229,  279
 251,  368, 1227, 1229,   55
 252, 1428, 1303,  289, 1272
 253, 1272, 1202, 1204,  290
 254,  371, 1204, 1202,   61
 255,  369, 1200, 1230,   57
 256,  370, 1200,  369,   58
 257,   59,   60, 1203, 1199
 258,  289, 1303, 1199, 1203
 259, 1438, 1428, 1272,  290
 260, 1228,   56,   57, 1230
 261,   56, 1228, 1227,  368
 262, 1228, 1230, 1303,  284
 263,  282,  288,   67,   68
 264, 1236, 1176, 1240,  282
 265,  283,  836, 1523, 1157
 266, 1198, 1529, 1291, 1234
 267, 1150,  269, 1149,  262
 268, 1382, 1262, 1325, 1521
 269, 1289,  261, 1343,  268
 270,   68,  386, 1236,  282
 271,  691,  832,   82,  643
 272,  942,  270, 1234,  893
 273, 1592,  270,  990, 1111
 274, 1559, 1558, 1154, 1191
 275,   82, 1236,  386,   72
 276,  476,  643,  385,  384
 277,  685,  627,  733,  277
 278,  271,  990,  270,  942
 279,   72,  385,  643,   82
 280,  524,  528,  458,  448
 281,  800,  858,  874,  759
 282, 1098, 1142, 1080,  255
 283,  270, 1592, 1125, 1145
 284,  515,  524,  448,  273
 285,  669,  622,  684,  729
 286,  675,  727,  715,  635
 287,  471,  474,   39,  337
 288,  741,  781, 1590,  969
 289,  765,  690, 1607,  989
 290,  402,  401,  455,  453
 291,  561,  501,  504,  562
 292,  453,  517,  573,  514
 293,  519,  455,  456,  521
 294,   79,  399,  523,  460
 295,  865, 1605,  911,  814
 296,  886,  187,  940, 1553
 297,  594,  186,  634,  688
 298,  591,  681,  687,  732
 299,  638,  591,  732, 1544
 300,  489,  424,  425,  490
 301,  435,  433,   81,  409
 302,  504,  440,  441,  506
 303,  225,  762,  801, 1629
 304,  809,  766,  869,  908
 305,  633,  673,  702,  753
 306,  398,  397,  465,  462
 307,  470,  469,  396,   78
 308,  642,  537,  596,  190
 309, 1583, 1190, 1570,  986
 310,  480,  478,   77,  393
 311,  482,  480,  393,  392
 312,  540,  482,  483, 1205
 313,   98, 1305, 1285,   99
 314, 1539, 1347, 1285,  110
 315,  100, 1538, 1347, 1541
 316,   99, 1538,   97, 1349
 317, 1439,   91, 1436, 1423
 318,  179, 1351, 1552, 1358
 319, 1342, 1359, 1300,   90
 320, 1326, 1561, 1244,   84
 321, 1153, 1244, 1561,  184
 322,   17,  313, 1301, 1209
 323,   98,   99, 1349, 1301
 324, 1259, 1349,   97, 1451
 325, 1451, 1416,   86, 1259
 326, 1274, 1388, 1342,   90
 327, 1192, 1300,   84, 1186
 328,  389,  388, 1186, 1235
 329,   75,  389, 1235,  185
 330,  314,   17, 1209, 1345
 331, 1345, 1206,   19,  314
 332,   74,  387, 1196, 1192
 333,  122, 1214, 1212, 1284
 334,  297,  136, 1216,    4
 335, 1427, 1403, 1406,   92
 336,   89, 1406, 1403, 1551
 337, 1424, 1410,   95, 1294
 338,  101, 1356, 1397,  100
 339,  112, 1541,  111, 1540
 340,  113, 1373, 1374,  112
 341,  102, 1374, 1373, 1337
 342, 1273,   94, 1341, 1315
 343, 1424, 1294, 1482,   92
 344, 1410, 1424, 1437, 1423
 345, 1274,   86, 1416, 1388
 346, 1402, 1388,   91, 1439
 347,  102, 1273, 1315, 1374
 348,   95, 1397, 1356, 1341
 349, 1445,  162, 1435, 1419
 350, 1525,  105, 1446, 1535
 351,  107, 1454, 1396, 1387
 352,  109, 1269,  324,   29
 353, 1316,  164,  108, 1507
 354,   31,  327,  116, 1231
 355,  326,  117, 1181,   30
 356,  117, 1256, 1260, 1181
 357, 1160, 1252, 1310, 1250
 358,   29,  325, 1160,  109
 359, 1252, 1160,  325,   30
 360,   32,  328, 1253, 1182
 361,  124,  123, 1221, 1497
 362,  147, 1207, 1498,  146
 363,  145, 1271,  149, 1444
 364, 1271,  145,  126, 1537
 365, 1434, 1444,  149,  150
 366, 1540,  124, 1497,  125
 367,  125, 1537,  126, 1547
 368, 1444, 1411, 1511,  145
 369, 1493, 1322,  130, 1256
 370, 1360,  130, 1322, 1417
 371, 1394, 1413,  141, 1418
 372, 1443,  154, 1433, 1421
 373, 1443, 1421,  141, 1422
 374, 1256,  130, 1389, 1260
 375, 1394,  131, 1389, 1400
 376, 1418, 1368,  131, 1394
 377,  131, 1368, 1339, 1481
 378,  135,  120,  134,  137
 379,    5, 1467, 1208,  299
 380, 1296, 1484, 1502,  155
 381,  140, 1442,  139, 1409
 382, 1431, 1448, 1543,  143
 383, 1400, 1389,  130, 1360
 384, 1390, 1369, 1362,  127
 385,   15,  310,  123, 1215
 386, 1497,  146, 1537,  125
 387,  309,  147, 1221,   14
 388, 1499, 1542, 1434,  150
 389, 1441, 1429, 1432,  151
 390, 1483, 1484, 1208, 1467
 391,  158, 1219, 1270, 1449
 392,  159, 1217,  160,  153
 393, 1466,  302,    7,  161
 394,  161,    7,  301, 1213
 395, 1213,  301,  300, 1222
 396,  160,    8,  302, 1466
 397,  160, 1466, 1307,  153
 398, 1304, 1220, 1217,  159
 399, 1293, 1332, 1280, 1224
 400, 1364, 1398, 1407,  166
 401, 1387, 1398, 1364, 1340
 402,  167, 1415, 1408, 1392
 403,   85, 1331, 1435, 1293
 404, 1392, 1526,  171, 1384
 405, 1384,  171, 1348,  172
 406, 1167,  316,   21, 1171
 407, 1348, 1282, 1275,  172
 408,  316, 1167, 1166,   20
 409, 1532, 1366, 1309, 1503
 410, 1258, 1195,  182, 1085
 411, 1258, 1085, 1155,  178
 412, 1151, 1254, 1290,  183
 413,  479,  538,  594,  541
 414,  824, 1501,  738,  786
 415, 1553,  985, 1545,  886
 416,  918,  881,  976, 1606
 417,  469,  465,  397,  396
 418,  819, 1032,  977,  935
 419,  595,   83,  537,  642
 420,  646,  742, 1534,  590
 421,  894,  193, 1569,  783
 422, 1038,  992,  943, 1546
 423,  891,  195,  944,  991
 424,  471,  534,  536,  474
 425,  680,  631,  682, 1508
 426, 1003, 1598, 1058,  960
 427,  699,  750,  667,  663
 428, 1611,  722, 1626,  213
 429,  784,  835, 1032,  819
 430,  982,  916,  913, 1022
 431,  469,  531,  530,  465
 432,  472,  470,   78,  395
 433,  454,  459,  340,  341
 434,  522,  525,  461,  459
 435,  677,  725,  631,  197
 436,  769, 1536,  809,  856
 437,  823,  849,  762,  749
 438,  664,  656,  613,  616
 439,  817,  876,  781,  198
 440,  577,  629,  621,  575
 441,  807,  679, 1571,  578
 442,  421,  420,   42,  351
 443,  706,  756,  747,  711
 444,  853,  909,  925,  815
 445, 1122, 1105, 1043, 1099
 446, 1119, 1137, 1118, 1121
 447, 1103, 1090, 1058, 1598
 448,  216, 1188,  215, 1488
 449, 1557, 1556, 1141, 1130
 450, 1595, 1112, 1133, 1084
 451, 1110, 1037, 1132, 1127
 452, 1110,  983, 1609, 1037
 453, 1324,  696, 1152,  216
 454, 1241, 1324,  216, 1488
 455,  588,  218,  592,  632
 456, 1565,  772,  739,  693
 457,  793,  220,  775,  795
 458,  793,  878,  803,  220
 459,  674,  693,  739,  775
 460,  996, 1051, 1029,  950
 461, 1065, 1018, 1013, 1063
 462,  903,  905,  843,  915
 463,  662,  716,  617,  606
 464,  905,  951,  851,  237
 465,  353,  354,  443,  434
 466, 1488, 1266, 1312, 1241
 467, 1312,  228, 1372, 1241
 468, 1263, 1193,  242, 1159
 469, 1084, 1133, 1197, 1037
 470, 1372, 1352,  229, 1241
 471, 1350, 1533, 1379, 1404
 472, 1584,  243, 1130, 1141
 473, 1112, 1584, 1141,  242
 474,  782,  829,  883,  232
 475,  883,  974,  923,  875
 476,  939,  978, 1023,  233
 477,  966, 1023, 1101, 1054
 478,  875,  923,  939,  892
 479, 1593,  929, 1576,  235
 480, 1576, 1560, 1018,  235
 481,  249,  720,  713,  668
 482,  484,  418,  419,  485
 483,  770,  796,  723,  718
 484, 1194, 1248,  239, 1463
 485, 1159,  242, 1141, 1556
 486,  244, 1076, 1139, 1006
 487, 1603,  970, 1004, 1093
 488, 1602,  256,  970, 1603
 489,  689,  593,  731,  831
 490, 1479,  539,  258,  641
 491, 1479,  767,  731,  593
 492,   73,  417,  418,  550
 493,  477,  375,  374,  258
 494,  535,  586,  466,  477
 495,  375,  477,  466,  376
 496, 1283,  259, 1189, 1496
 497,  864,  858,  752,  265
 498,  880,  827,  921,  964
 499,  549,  684,  556,  491
 500, 1355, 1265,  269, 1150
 501,  270, 1145, 1198, 1234
 502,  837,  785,  827,  880
 503,  273,  448,  382,  381
 504,  430,  379,  378,  438
 505, 1226, 1302, 1295, 1233
 506, 1320, 1370, 1295, 1302
 507,  276, 1291, 1278, 1157
 508,  893, 1523,  277, 1184
 509,  836,  685,  277, 1523
 510, 1334, 1383,  279, 1287
 511, 1157, 1278, 1313, 1298
 512, 1365, 1313, 1381, 1383
 513,  281,  280,  286,  287
 514,   82,  832, 1176, 1236
 515, 1314, 1298, 1313, 1365
 516,  291,  292,  288,  287
 517, 1202, 1272,  289, 1203
 518,  287,  286, 1299,  291
 519, 1229, 1227, 1287,  279
 520,   18, 1165, 1225,  293
 521,    2,  104, 1279,  295
 522,  136,  297,    3, 1214
 523, 1468,  298,    4, 1216
 524, 1217,  303,    8,  160
 525, 1218,  304,    9, 1220
 526,  158,  305,   10, 1219
 527,  157,  306,   11, 1465
 528,  147,  309,   13, 1207
 529,  310,   14, 1221,  123
 530, 1215, 1211,  311,   15
 531,  169, 1174, 1166, 1489
 532, 1170,  317,   22, 1172
 533,   23, 1168, 1169,  318
 534, 1469,  320,   25, 1470
 535,   26, 1472, 1471,  321
 536, 1474, 1473,  322,   27
 537, 1252,   30, 1181,  118
 538,  117,  326,   31, 1231
 539,  327,   32, 1182,  116
 540,   93,  330,   35, 1461
 541,  331,   36, 1238,   87
 542,  196,  787,  334,   38
 543,  591, 1500,  639,  681
 544,  463,  468,  338,  339
 545,  461,  463,  339,   40
 546,  459,  461,   40,  340
 547,  452,  454,  341,  342
 548,  449,  452,  342,  343
 549,  445,  449,  343,   41
 550,  442,  445,   41,  344
 551,  432,  436,  346,  347
 552,  429,  432,  347,  348
 553,  426,  429,  348,  349
 554,  493,  429,  426,  551
 555,  488,  426,  349,  350
 556,  420,  488,  350,   42
 557,  352,  353,  434,  486
 558,  511,  443,  451,  520
 559,  451,  443,  354,  355
 560,  457,  451,  355,   43
 561,  473,  464,  356,  357
 562,  357,  358,  481,  473
 563, 1161,  361,   47,  227
 564, 1463,  363,   49, 1194
 565,  250,  364,   50, 1464
 566, 1163,  365,   51,  259
 567, 1200,  370,   59, 1199
 568, 1204,  371,   62, 1201
 569,   73,  550,  668,  373
 570,  258,  374,   69,  641
 571,  377,  447,  438,  378
 572,  379,  430,  422,  380
 573,  381,  380,  422,  273
 574,  448,  458,   71,  382
 575,  458,  467,  383,   71
 576,  467,  476,  384,  383
 577, 1206, 1196,  387,   19
 578,  388,   74, 1192, 1186
 579,  390,   75,  185,  191
 580, 1205,  483,  542,  590
 581,  478,  475,  394,   77
 582,  395,  394,  475,  472
 583,  532,  470,  472,  589
 584,  399,  398,  462,  523
 585,  456,  455,  401,  400
 586,  403,  402,  453,  514
 587,  450,  446,  404,   80
 588,  446,  444,  405,  404
 589,  444,  441,  406,  405
 590,  440,  437,  408,  407
 591,  437,  435,  409,  408
 592,  433,  431,  410,   81
 593,  431,  428,  411,  410
 594,  428,  427,  412,  411
 595,  425,  424,  414,  413
 596,  424,  423,  415,  414
 597,  423,  419,  416,  415
 598,  419,  418,  417,  416
 599,  485,  419,  423, 1487
 600,  487,  208,  597,  544
 601,  351,  352,  486,  421
 602,  546,  421,  486,  555
 603,  422,  430,  491,  556
 604,  413,  412,  427,  425
 605,  547,  489,  490, 1528
 606,  488,  544,  551,  426
 607,  545, 1487,  489,  547
 608,  429,  493,  496,  432
 609,  430,  438,  499,  491
 610,  428,  494,  492,  427
 611,  432,  496,  498,  436
 612,  431,  495,  494,  428
 613,  421,  546,  487,  420
 614,  433,  497,  495,  431
 615,  436,  498,  502,  439
 616,  407,  406,  441,  440
 617,  435,  500,  497,  433
 618,  447,  377,   70,  513
 619,  516,  512,  574, 1495
 620,  437,  501,  500,  435
 621,  500,  559,  557,  497
 622,  443,  511,  503,  434
 623,  440,  504,  501,  437
 624,  445,  508,  512,  449
 625,  444,  507,  506,  441
 626,  513,   70,  376,  466
 627,  499,  438,  447,  509
 628,  449,  512,  516,  452
 629,   80,  403,  514,  450
 630,  446,  510,  507,  444
 631,  576,  511,  520,  582
 632,  454,  452,  516,  518
 633,  514,  573,  570,  450
 634,  521,  456,  460,  214
 635,  460,  456,  400,   79
 636,  455,  519,  517,  453
 637,  838,  627,  278,  585
 638,  525,  581,  584,  529
 639,  461,  525,  529,  463
 640,  527,  462,  465,  530
 641,  580,  523,  462,  527
 642,  457,  526,  520,  451
 643,  569,  513,  466,  586
 644,  476,  467,  585,  278
 645,  468,  197,  534,  471
 646,  589,  472,  475,   83
 647,  470,  532,  531,  469
 648,  588,  473,  481,  218
 649,  479,  474,  536,  538
 650,  643,  476,  278,  691
 651,  539,  535,  477,  258
 652,  537,  478,  480,  596
 653,   83,  475,  478,  537
 654,  482,  540,  596,  480
 655,   76,  391,  542,  483
 656,  572,  484,  485,  543
 657,  605,  484,  572,  657
 658,  490,  425,  427,  492
 659,  420,  487,  544,  488
 660, 1564,  545,  547,  600
 661,  564,  499,  509,  266
 662, 1487,  545,  543,  485
 663,  551,  544,  597,  601
 664,  496,  493,  553,  558
 665, 1566, 1528,  548,  612
 666,  494,  552,  548,  492
 667,  558,  560,  498,  496
 668,  499,  564,  549,  491
 669,  497,  557,  554,  495
 670,  559,  606,  617,  557
 671,  560,  563,  502,  498
 672,  609,  555,  503,  568
 673,  563,  610,  614,  566
 674,  442,  505,  508,  445
 675,  506,  565,  562,  504
 676,  510,  446,  450,  570
 677,  562,  611,  608,  561
 678,  566,  571,  508,  505
 679,  569,  509,  447,  513
 680,  510,  226,  567,  507
 681,  511,  576,  568,  503
 682,  571,  574,  512,  508
 683,  556,  515,  273,  422
 684,  524,  515,  622,  579
 685,  518,  516, 1495,  202
 686,  573,  620,  618,  570
 687,  518,  202,  624,  522
 688,  577,  519,  521,  578
 689,  625,  576,  582,  219
 690,  519,  577,  575,  517
 691,  522,  624,  581,  525
 692,  214,  460,  523,  580
 693,  524,  579,  583,  528
 694,  533,  464,  473,  588
 695,  628,  580,  527,  813
 696,  838,  583, 1518,  627
 697,  467,  458,  528,  585
 698,  677,  197,  529,  584
 699,  530,  889,  813,  527
 700,  587,  531,  532,  825
 701,  889,  530,  531,  587
 702,  532,  589, 1156,  825
 703,  533,  623,  779,  526
 704,  631,  680,  534,  197
 705,  636,  586,  535,  683
 706,  538,  536,  639, 1500
 707,  594,  538, 1500,  186
 708,  539,  640,  683,  535
 709,  645,  540, 1205,  192
 710,  541,  196,   38,  335
 711,  598,  572,  543,  599
 712, 1528, 1566,  600,  547
 713,  208,  487,  546,  604
 714,  552,  494,  495,  554
 715, 1564,  648,  647,  599
 716,  579,  622,  669,  759
 717,  249,  668,  550,  605
 718,  550,  418,  484,  605
 719, 1554,  743,  797, 1587
 720, 1567,  552,  554,  238
 721,  558,  553,  650,  602
 722,  493,  551,  601,  553
 723,  604,  546,  555,  609
 724,  238,  554,  557,  617
 725,  559,  500,  501,  561
 726,  558,  602,  607,  560
 727,  607,  610,  563,  560
 728,  565,  506,  507,  567
 729,  561,  608,  606,  559
 730,  209,  661,  610,  607
 731,  564,  635,  603,  549
 732,  635,  564,  266,  675
 733,  566,  614,  615,  571
 734,  567,  616,  613,  565
 735,  565,  613,  611,  562
 736,  266,  509,  569,  637
 737,  226,  510,  570,  618
 738,  571,  615,  626,  574
 739,  657,  572,  598,  718
 740,  517,  575,  620,  573
 741,  673,  574,  626,  726
 742,  663,  618,  620,  671
 743,  582,  520,  526,  779
 744,  639,  536,  534,  680
 745,  578,  521,  214,  807
 746,  629,  577,  578, 1571
 747,  807,  214,  580,  628
 748,  583,  579,  272, 1518
 749,  622,  515,  556,  684
 750,  584,  581,  630,  736
 751,  576,  625,  619,  568
 752,  585,  528,  583,  838
 753,  637,  569,  586,  636
 754,  587,  825, 1573,  870
 755,  587,  870, 1574,  889
 756,  529,  197,  468,  463
 757,  623,  533,  588,  632
 758,   83,  595, 1156,  589
 759,  198,  687,  681, 1508
 760,  593,  689, 1514,  640
 761,  634,  186,  638,  780
 762,  594,  688,  196,  541
 763,  595,  642,  686, 1572
 764,  653,  208,  604,  655
 765,  649,  601,  597, 1515
 766,  647,  718,  598,  599
 767,  599,  543,  545, 1564
 768,  648, 1564,  600, 1566
 769,  612,  548,  552, 1567
 770,  648, 1566,  612, 1608
 771,  607,  602,  651,  209
 772,  650,  553,  601,  649
 773,  729,  800,  759,  669
 774,  714, 1515,  653,  710
 775,  605,  657,  676,  249
 776,  652,  662,  606,  608
 777,  608,  611,  654,  652
 778,  568,  619,  659,  609
 779,  614,  610,  661,  665
 780,  616,  567,  226,  667
 781,  656,  654,  611,  613
 782,  665,  670,  615,  614
 783,  618,  663,  667,  226
 784,  616,  667,  750,  664
 785,  719,  648, 1608,  721
 786,  609,  659,  655,  604
 787,  575,  621,  671,  620
 788,  684,  549,  603,  729
 789,  724,  623,  632,  695
 790, 1563,  779,  623,  724
 791,  633,  666,  202, 1495
 792,  624,  202,  666,  678
 793,  625,  693,  674,  619
 794,  693,  625,  219, 1565
 795,  702,  673,  726,  751
 796,  865,  740,  774,  207
 797,  679,  807,  628,  774
 798,  629, 1571,  690, 1611
 799,  621,  629, 1611,  213
 800,  581,  624,  678,  630
 801,  677,  584,  736, 1516
 802,  682,  631,  725,  771
 803,  695, 1158,  734,  788
 804,  660,  637,  636,  808
 805,  257,  822,  862,  808
 806,  675,  266,  637,  660
 807,  780,  638, 1544,  187
 808,  591,  638,  186, 1500
 809,  681,  639,  680, 1508
 810,  778, 1514,  730, 1082
 811,  257,  683,  640,  778
 812,   69,  373, 1460,  641
 813,  642,  190,  692,  686
 814,  685,  691,  278,  627
 815,  696,  644,  217, 1152
 816,  230,  694,  644,  696
 817,  192, 1570, 1190,  645
 818, 1190,  692,  190,  645
 819,  185, 1153,  646,  191
 820,  742,  646, 1153,  184
 821,  647,  648,  719,  745
 822, 1567,  658, 1608,  612
 823,  208,  653, 1515,  597
 824,  744,  714,  710,  820
 825,  698,  743, 1554,  651
 826,  655,  707,  710,  653
 827,  652,  701,  700,  662
 828,  746,  744,  789,  854
 829,  654,  704,  701,  652
 830,  657,  718,  723,  676
 831,  619,  674,  708,  659
 832,  636,  683,  257,  808
 833,  715,  763,  752,  672
 834,  209,  703,  706,  661
 835,  661,  706,  711,  665
 836,  737,  699,  663,  671
 837, 1622,  664,  750,  749
 838,  656,  705,  704,  654
 839,  709,  670,  665,  711
 840,  666,  633,  753,  717
 841,  626,  615,  670,  755
 842,  671,  621,  213,  737
 843,  800,  672,  752,  858
 844,  672,  603,  635,  715
 845,  673,  633, 1495,  574
 846,  659,  708,  707,  655
 847,  920, 1486,  861, 1527
 848, 1516,  769,  725,  677
 849,  630,  678,  712,  203
 850,  774,  740, 1607,  679
 851,  741,  687,  198,  781
 852,  682,  817,  198, 1508
 853,  729,  603,  672,  800
 854,  189,  835,  686,  692
 855,  735, 1572,  784,  201
 856,  687,  741, 1107,  732
 857,  777,  247,  689,  831
 858,  866,  722,  821,  962
 859, 1611,  690,  765,  722
 860,  832,  691,  685,  836
 861,  772, 1563,  724, 1599
 862,  816,  826,  739,  772
 863, 1575,  937,  868,  888
 864,  694,  231, 1158,  592
 865,  695,  788, 1599,  724
 866,  743,  698,  697,  746
 867,  762,  225, 1622,  749
 868,  798,  701, 1619,  754
 869,  757,  719,  721,  790
 870,  804, 1604,  847,  902
 871,  703,  209,  651, 1554
 872,  656,  664, 1622,  705
 873,  704,  705, 1619,  701
 874,  225, 1619,  705, 1622
 875,  794,  748,  747,  804
 876,  220,  708,  674,  775
 877,  708,  220,  773,  707
 878,  726,  626,  755,  210
 879,  820,  710,  707,  773
 880,  712,  761,  766,  203
 881,  668,  713, 1460,  373
 882,  720,  249,  676,  760
 883,  714,  697,  649, 1515
 884,  238,  716,  658, 1567
 885,  662,  700,  764,  716
 886,  852,  805,  848,  901
 887,  805,  717,  753,  702
 888,  745,  770,  718,  647
 889,  792,  745,  719,  757
 890,  760,  676,  723,  979
 891,  713,  811,  767, 1460
 892,  790,  721,  658,  716
 893,  737,  776,  758,  699
 894,  979,  723,  796, 1548
 895, 1565,  219, 1563,  772
 896, 1516,  736, 1536,  769
 897,  725,  769,  818,  771
 898,  755,  670,  709,  791
 899,  751,  726,  210,  815
 900,  727,  768,  806,  763
 901,  787,  728,  839,  890
 902,  831,  731,  248,  872
 903, 1077,  940,  187, 1544
 904,  785,  733,  627, 1518
 905,  837,  887,  733,  785
 906,  231,  834,  734, 1158
 907,  735, 1573,  825, 1156
 908,  736,  630,  203, 1536
 909,  213, 1626,  776,  737
 910,  699,  758,  749,  750
 911,  634,  780,  786,  738
 912,  728,  738, 1501,  195
 913,  732, 1107, 1077, 1544
 914,  742,  184,  783, 1569
 915,  714,  744,  746,  697
 916,  854,  797,  743,  746
 917,  770,  745,  792,  237
 918,  756,  706,  703, 1587
 919,  845,  791,  844,  895
 920,  700,  701,  798,  764
 921,  823,  749,  758,  833
 922,  848,  805,  702,  751
 923, 1629,  801, 1634,  802
 924,  764,  798,  860, 1596
 925,  791,  709,  748,  844
 926,  855,  757,  790, 1596
 927,  843,  792,  757,  855
 928,  874,  921,  827,  272
 929,  272,  579,  759,  874
 930,  872,  248,  920, 1513
 931,  852,  766,  761,  805
 932,  712,  717,  805,  761
 933,  885,  910,  849,  823
 934,  810,  763,  806,  871
 935,  790,  716,  764, 1596
 936,  841,  860,  798,  754
 937,  863,  821,  765,  989
 938,  908,  980,  919,  856
 939,  811,  713,  720, 1486
 940,  248,  731,  767,  811
 941,  768,  660,  808,  862
 942,  859,  806,  768,  862
 943,  203,  766,  809, 1536
 944,  796,  770,  237,  851
 945,  876,  817,  933,  961
 946,  771,  867,  817,  682
 947,  232, 1599,  788,  782
 948, 1599,  232,  816,  772
 949,  773,  220,  803,  873
 950,  628,  813,  207,  774
 951,  795,  775,  739,  826
 952,  812,  776, 1626,  866
 953,  776,  812,  833,  758
 954, 1013, 1017,  872, 1513
 955,  689,  247,  730, 1514
 956,  219,  582,  779, 1563
 957,  786,  780,  187,  886
 958,  781,  876, 1580, 1590
 959,  894,  783, 1151,  943
 960,  188, 1012,  879,  987
 961,  272,  827,  785, 1518
 962,  333,  334,  787,  890
 963,  789,  744,  820,  873
 964,  844,  748,  794,  897
 965,  210,  755,  791,  845
 966,  846,  233,  928,  914
 967,  914,  793,  795,  846
 968,  747,  756, 1604,  804
 969,  897,  794,  850,  949
 970,  846,  795,  826,  892
 971,  979, 1548,  904, 1512
 972, 1587,  797,  847, 1604
 973,  802,  841,  754, 1629
 974,  799,  912, 1618,  967
 975,  849,  899,  801,  762
 976,  842,  900,  802, 1634
 977, 1040,  957, 1126, 1052
 978,  902,  946,  996,  950
 979,  871,  806,  859,  256
 980,  257,  778, 1082,  822
 981,  799,  869,  766,  852
 982,  818,  769,  856,  919
 983,  864,  968,  924,  858
 984, 1486,  720,  760,  861
 985,  882,  833,  812,  866
 986,  740,  865,  814,  989
 987,  989,  814,  206,  863
 988,  815,  925,  848,  751
 989,  875,  816,  232,  883
 990,  892,  826,  816,  875
 991,  935,  976,  881,  819
 992,  201,  784,  819,  881
 993,  821,  863,  206,  916
 994, 1082,  730,  830,  930
 995,  859,  862,  917, 1568
 996,  824,  786,  886, 1545
 997,  188, 1519,  985, 1012
 998,  918, 1605, 1574,  870
 999,  877,  828,  929,  972
1000,  247,  777,  828,  877
1001,  741,  969,  199, 1107
1002,  983, 1586, 1585, 1609
1003,  930,  830,  884,  971
1004,  920,  248,  811, 1486
1005,  283, 1176,  832,  836
1006,  834, 1575,  888,  829
1007,  835,  784, 1572,  686
1008,  835,  189,  879, 1032
1009,  276, 1157, 1523,  893
1010,  887,  837,  271,  942
1011,  890,  839,  181, 1164
1012,  192, 1534,  840, 1570
1013, 1582,  986, 1570,  840
1014,  948,  842,  899,  975
1015,  900, 1627,  993,  898
1016, 1616,  965,  903,  915
1017,  237,  792,  843,  905
1018,  895,  844,  897,  973
1019, 1026,  945,  909,  954
1020,  210,  845,  853,  815
1021,  878,  793,  914,  958
1022,  797,  854,  907,  847
1023,  804,  902,  850,  794
1024,  899,  849,  910,  975
1025,  973,  897,  949,  222
1026,  925,  909,  945, 1588
1027,  954,  909,  853, 1579
1028,  896,  789,  873,  906
1029,  896,  907,  854,  789
1030,  860, 1600,  855, 1596
1031,  857,  818,  919,  204
1032,  771,  818,  857,  867
1033,  867,  857,  933,  817
1034,  864,  265,  810,  922
1035,  921,  874,  858,  924
1036,  860,  841,  898, 1600
1037,  917,  862,  822, 1082
1038,  913,  916,  206, 1620
1039,  922,  810,  871,  932
1040,  870, 1573,  881,  918
1041,  866,  962,  931,  882
1042,  231,  694,  937, 1575
1043,  243, 1585,  868, 1130
1044,  901,  912,  799,  852
1045,  869,  799,  967,  959
1046,  932,  871,  256, 1602
1047,  236, 1089, 1065, 1063
1048,  961,  933,  955, 1000
1049,  906,  873,  803,  957
1050,  938,  189, 1583,  986
1051, 1079, 1562, 1015, 1010
1052,  271,  837,  880,  927
1053, 1606,  976, 1030,  963
1054,  833,  882,  885,  823
1055,  883,  829,  934,  974
1056, 1631,  923,  974, 1006
1057,  212,  910,  885, 1635
1058, 1175,  987, 1035,  194
1059,  733,  887, 1184,  277
1060, 1586,  934,  829,  888
1061,  207,  813,  889, 1574
1062,  194,  991,  944, 1175
1063,  181,  839,  891, 1195
1064,  233,  846,  892,  939
1065,  840, 1569,  193, 1582
1066,  954, 1579,  995, 1597
1067,  907,  896,  947,  946
1068,  900,  898,  841,  802
1069, 1600,  952,  915,  855
1070, 1627,  842,  948,  994
1071,  899,  842, 1634,  801
1072,  912,  901, 1588,  211
1073,  946,  902,  847,  907
1074,  950, 1029,  850,  902
1075,  951,  905,  903,  965
1076,  953,  851,  951, 1577
1077,  999,  956, 1527, 1512
1078,  908,  959, 1028,  980
1079,  910,  212,  960,  975
1080,  814,  911, 1620,  206
1081, 1618,  912,  211, 1628
1082, 1620,  963, 1022,  913
1083, 1594,  982, 1613, 1016
1084,  958,  914,  928, 1007
1085, 1616,  915,  952,  224
1086,  205,  916,  982, 1594
1087,  962,  821,  916,  205
1088, 1568,  970,  256,  859
1089, 1605,  918, 1606,  911
1090,  927,  880,  964, 1019
1091, 1036,  968,  984, 1080
1092,  968,  864,  922,  984
1093,  924,  264,  964,  921
1094,  901,  848,  925, 1588
1095, 1022, 1066, 1613,  982
1096, 1590, 1580,  926, 1016
1097,  966,  928,  233, 1023
1098,  878,  958, 1052, 1126
1099,  777, 1017, 1560,  828
1100,  936,  877,  972, 1024
1101,  981, 1555, 1021, 1004
1102, 1008, 1056,  955,  204
1103, 1614,  931, 1014, 1044
1104,  970, 1568,  981, 1004
1105,  932, 1020,  984,  922
1106,  933,  857,  204,  955
1107,  974,  934,  244, 1006
1108,  976,  935,  200, 1030
1109, 1027,  936, 1024, 1073
1110,  936, 1027,  971,  884
1111,  694,  230, 1557,  937
1112,  937, 1557, 1130,  868
1113,  992, 1035, 1081,  193
1114,  938, 1081, 1035,  987
1115, 1015, 1589, 1613, 1010
1116, 1034,  977, 1012,  985
1117, 1175,  944,  941,  988
1118, 1038, 1546, 1085,  182
1119, 1038,  182,  991,  194
1120,  898,  993,  952, 1600
1121,  211, 1588,  945,  998
1122, 1009,  965, 1616, 1002
1123,  221,  996,  946,  947
1124,  896,  906,  957,  947
1125, 1001,  948,  975, 1033
1126,  949,  850, 1029, 1623
1127, 1009, 1577,  951,  965
1128,  999,  236, 1063,  956
1129,  953,  904, 1548,  851
1130,  895,  973,  995, 1579
1131,  998,  945, 1026, 1615
1132,  980, 1008,  204,  919
1133, 1513,  920, 1527,  956
1134,  947,  957, 1040,  221
1135,  878, 1126,  957,  803
1136, 1033,  975,  960, 1058
1137, 1624, 1003,  960,  212
1138,  961, 1000, 1083,  926
1139,  876,  961,  926, 1580
1140, 1083, 1014,  205, 1594
1141,  963, 1620,  911, 1606
1142,  199, 1016, 1613, 1589
1143, 1002, 1061, 1070, 1578
1144, 1101, 1060, 1073, 1054
1145,  211,  998, 1005, 1628
1146, 1031, 1028,  959,  967
1147,  264,  924,  968, 1036
1148,  929,  828, 1560, 1576
1149, 1560, 1017, 1013, 1018
1150,  246, 1021,  971, 1027
1151,  972, 1072, 1067, 1024
1152,  973,  222, 1011,  995
1153,  939,  923, 1074,  978
1154, 1131, 1064, 1071, 1068
1155,  994,  948, 1001, 1043
1156,  200,  935,  977, 1034
1157,  923, 1631, 1630, 1074
1158,  978, 1074, 1621, 1025
1159,  760,  979, 1512,  861
1160,  980, 1028, 1047, 1008
1161, 1021, 1555,  930,  971
1162,  244,  934, 1586,  983
1163,  255, 1080,  984, 1020
1164, 1519,  188,  988,  941
1165, 1034,  985, 1553, 1562
1166, 1015,  940, 1077, 1589
1167,  986, 1582, 1081,  938
1168,  987, 1175,  988,  188
1169,  927, 1019, 1111,  990
1170,  194, 1035,  992, 1038
1171,  993, 1627,  994, 1042
1172,  224,  952,  993, 1042
1173, 1062, 1099, 1069, 1090
1174, 1049, 1615, 1053, 1087
1175,  221, 1040, 1104, 1045
1176, 1094, 1116, 1115, 1095
1177, 1088, 1046,  997, 1048
1178, 1049, 1005,  998, 1615
1179, 1046,  904,  953,  997
1180,  904, 1046,  999, 1512
1181, 1000, 1044, 1014, 1083
1182, 1043, 1001, 1069, 1099
1183,  224, 1042, 1061, 1002
1184, 1003, 1614, 1044, 1598
1185, 1603, 1078,  255, 1020
1186, 1043, 1105, 1042,  994
1187, 1618, 1628, 1055, 1031
1188, 1127, 1129, 1076, 1110
1189, 1610,  958, 1007,  234
1190, 1578, 1577, 1009, 1002
1191, 1066, 1022,  963, 1030
1192, 1066, 1079, 1010, 1613
1193, 1623, 1091,  222,  949
1194, 1120, 1091, 1114, 1097
1195, 1012,  977, 1032,  879
1196, 1014,  931,  962,  205
1197,  200, 1079, 1066, 1030
1198, 1590, 1016,  199,  969
1199,  926, 1083, 1594, 1016
1200, 1113, 1123, 1134, 1109
1201, 1075, 1019,  264, 1036
1202, 1111, 1019, 1075, 1147
1203, 1020,  932, 1602, 1603
1204, 1021,  246, 1064, 1004
1205, 1054, 1073,  234, 1007
1206, 1023,  978, 1025, 1101
1207, 1131, 1093, 1004, 1064
1208,  954, 1597, 1057, 1026
1209, 1057, 1612, 1086, 1053
1210, 1027, 1073, 1060,  246
1211, 1028, 1031, 1062, 1047
1212, 1097, 1092, 1593,  235
1213, 1059, 1623, 1029, 1095
1214, 1090, 1069, 1033, 1058
1215, 1084, 1037, 1609, 1595
1216, 1087, 1053, 1086,  223
1217, 1011, 1039, 1597,  995
1218, 1097, 1114, 1115, 1092
1219, 1612, 1109, 1124, 1086
1220, 1041, 1120, 1097,  235
1221, 1055, 1632, 1633, 1099
1222, 1056, 1044, 1000,  955
1223, 1003, 1624,  931, 1614
1224, 1115, 1116, 1601, 1092
1225,  996,  221, 1045, 1051
1226,  236,  999, 1046, 1088
1227, 1096, 1581, 1048, 1070
1228, 1048,  997, 1578, 1070
1229, 1053, 1615, 1026, 1057
1230, 1039, 1011, 1050, 1617
1231, 1050, 1011,  222, 1091
1232, 1007,  928,  966, 1054
1233, 1005, 1049, 1100, 1632
1234, 1056, 1008, 1047, 1103
1235, 1056, 1103, 1598, 1044
1236, 1091, 1623, 1059, 1114
1237, 1095, 1029, 1051, 1094
1238, 1071, 1025, 1621, 1068
1239, 1106, 1096, 1070, 1061
1240,  956, 1063, 1013, 1513
1241, 1089,  236, 1088, 1128
1242, 1064,  246, 1060, 1071
1243,  200, 1034, 1562, 1079
1244, 1104, 1138, 1116, 1094
1245, 1078, 1603, 1093, 1625
1246, 1102, 1144,  245, 1630
1247, 1071, 1060, 1101, 1025
1248, 1072,  972,  929, 1593
1249, 1072, 1593, 1092, 1601
1250, 1110, 1076,  244,  983
1251, 1108, 1129, 1098,  255
1252,  199, 1589, 1077, 1107
1253, 1036, 1080, 1142, 1075
1254, 1133, 1112,  242, 1193
1255, 1155,  183, 1290, 1522
1256, 1039, 1617, 1109, 1612
1257, 1121, 1118, 1087,  223
1258, 1128, 1134, 1123, 1089
1259, 1065, 1089, 1123, 1041
1260, 1047, 1062, 1090, 1103
1261, 1120, 1041, 1123, 1113
1262, 1625, 1093, 1131, 1068
1263, 1096,  223, 1136, 1581
1264, 1055, 1099, 1062, 1031
1265, 1095, 1115, 1114, 1059
1266, 1108,  255, 1078, 1144
1267, 1140, 1098, 1129, 1127
1268, 1049, 1087, 1118, 1100
1269, 1067,  234, 1073, 1024
1270, 1104, 1040, 1052, 1138
1271, 1610, 1138, 1052,  958
1272, 1061, 1042, 1105, 1119
1273, 1106, 1121,  223, 1096
1274, 1113, 1109, 1617, 1050
1275, 1111,  263, 1125, 1592
1276, 1136, 1134, 1128, 1581
1277, 1050, 1091, 1120, 1113
1278, 1117, 1116, 1138, 1610
1279, 1067, 1117, 1610,  234
1280, 1601, 1117, 1067, 1072
1281, 1106, 1061, 1119, 1121
1282, 1105, 1122, 1137, 1119
1283, 1135, 1137, 1122, 1633
1284, 1581, 1128, 1088, 1048
1285, 1134, 1136, 1124, 1109
1286,  223, 1086, 1124, 1136
1287, 1148, 1140, 1127, 1132
1288, 1129, 1108, 1139, 1076
1289,  254, 1132, 1037, 1197
1290, 1140, 1148, 1143, 1591
1291,  253, 1197, 1133, 1193
1292, 1135, 1633, 1632, 1100
1293, 1137, 1135, 1100, 1118
1294, 1006, 1139, 1102, 1631
1295, 1147, 1591, 1143, 1146
1296, 1147, 1146,  263, 1111
1297, 1145, 1125, 1149,  269
1298, 1556, 1187,  229, 1159
1299, 1142, 1098, 1140, 1591
1300, 1144, 1078, 1625,  245
1301, 1198, 1145,  269, 1265
1302, 1146,  262, 1149,  263
1303, 1148, 1132,  254, 1191
1304,  262, 1154, 1558, 1150
1305, 1150, 1558, 1289, 1355
1306,  943, 1151,  183, 1546
1307, 1324, 1241,  229, 1187
1308, 1244, 1153,  185, 1235
1309, 1191, 1154,  262, 1146
1310, 1559, 1243, 1262,  261
1311,  735, 1156,  595, 1572
1312, 1159,  229, 1352, 1263
1313,  215, 1161, 1266, 1488
1314, 1462,   48,  363, 1463
1315, 1257,  239, 1248,  240
1316, 1164,  181, 1245,  177
1317,  165, 1475, 1474,   27
1318, 1239, 1336,  165, 1180
1319, 1174,  315,   20, 1166
1320, 1288, 1165, 1174,  169
1321, 1171,   21,  317, 1170
1322, 1490, 1242, 1167, 1171
1323, 1173,  319,   24,  176
1324, 1169, 1168, 1281,  174
1325,  174, 1491, 1172, 1169
1326, 1173,  176, 1282,  175
1327, 1267, 1240, 1176,  283
1328, 1249, 1177,  103, 1337
1329, 1177, 1311, 1253,  328
1330,   94, 1273, 1178, 1179
1331, 1273,  102, 1292, 1178
1332, 1179, 1476, 1294,   94
1333,  164, 1239, 1180, 1183
1334, 1261,  115, 1338,  128
1335,  164, 1183, 1269,  108
1336, 1185,  292,  291, 1459
1337, 1186,   84, 1244, 1235
1338, 1187,  230,  696, 1324
1339, 1189,  366,   52,  267
1340, 1191,  254, 1243, 1559
1341, 1300, 1192, 1196,   90
1342, 1268, 1193, 1263, 1333
1343, 1195, 1258, 1245,  181
1344, 1243,  253, 1325, 1262
1345, 1230, 1200, 1199, 1303
1346, 1204, 1201, 1299,  290
1347, 1203,   60,   61, 1202
1348,  331,   87, 1461,   35
1349,  192, 1205,  590, 1534
1350,   86, 1274, 1206, 1345
1351,   90, 1196, 1206, 1274
1352, 1349, 1259, 1209, 1301
1353,   86, 1345, 1209, 1259
1354,  150, 1210,  157, 1499
1355, 1213, 1453, 1450,  161
1356, 1277, 1215,  123,  124
1357, 1220,    9,  303, 1217
1358, 1223,  149, 1271,  148
1359,  284, 1287, 1227, 1228
1360,  116, 1255, 1493, 1231
1361, 1232,   53,  367, 1233
1362,  893, 1234, 1291,  276
1363,  172, 1237, 1477, 1385
1364, 1469, 1470, 1478, 1275
1365, 1364, 1336, 1239, 1340
1366,  281,  287, 1240, 1267
1367, 1328, 1505,  170, 1363
1368, 1309, 1264, 1246, 1503
1369, 1385, 1247,  166, 1405
1370, 1350, 1248, 1492, 1353
1371,  109, 1160, 1250, 1317
1372,  119, 1318, 1250, 1310
1373, 1403, 1427,   88, 1531
1374, 1427, 1440, 1251,   88
1375, 1252,  118, 1485, 1310
1376, 1182, 1253,  115, 1261
1377, 1254,  180, 1351, 1290
1378, 1255,  129, 1322, 1493
1379, 1257,  240, 1344, 1286
1380, 1268, 1325,  253, 1193
1381,   88, 1251, 1264, 1309
1382, 1265, 1355, 1323, 1520
1383, 1278, 1291, 1529,  275
1384, 1335, 1266, 1161,  227
1385,  228, 1312, 1266, 1335
1386, 1298, 1267,  283, 1157
1387, 1269,  109, 1317,  108
1388,  146, 1498, 1271, 1537
1389,  286, 1438,  290, 1299
1390, 1292,  102, 1337,  103
1391,  176, 1469, 1275, 1282
1392,  280,  281, 1314, 1530
1393,  111, 1277,  124, 1540
1394, 1494, 1279,  104,  105
1395, 1308, 1283, 1496,  252
1396,  105, 1525, 1284, 1494
1397, 1335, 1286, 1344,  228
1398,  285, 1393, 1334, 1414
1399, 1288,  169, 1505, 1328
1400,  261, 1262, 1382, 1343
1401, 1355, 1289,  268, 1323
1402, 1522, 1354,  178, 1155
1403, 1529, 1198, 1265, 1520
1404, 1482, 1294, 1476,   93
1405, 1330, 1295, 1370,  275
1406,  274, 1233, 1295, 1330
1407, 1414,  284, 1303, 1428
1408, 1484, 1296,  156, 1208
1409,  274, 1323,  268, 1297
1410, 1300, 1359, 1326,   84
1411,  152, 1452, 1304,  159
1412,  158, 1449, 1306, 1465
1413, 1306,  151, 1542, 1499
1414, 1307, 1450,  154, 1443
1415, 1379,  252, 1549, 1333
1416, 1283, 1308, 1533,  251
1417, 1361, 1485, 1339,  132
1418,  115, 1253, 1311, 1338
1419, 1352, 1372, 1357,  241
1420, 1315, 1341, 1356,  101
1421, 1374, 1315,  101,  112
1422, 1316,  107, 1387, 1340
1423, 1509, 1380, 1318,  119
1424, 1547, 1377,  113,  125
1425, 1381, 1370, 1320, 1383
1426, 1327, 1321, 1376, 1524
1427, 1399, 1417,  129, 1386
1428, 1524,  170, 1506, 1327
1429, 1281, 1327, 1506,  174
1430, 1254,  184, 1561,  180
1431, 1328, 1363,  168, 1331
1432, 1330,  275, 1529, 1520
1433, 1435, 1331,  168, 1419
1434,  241, 1333, 1263, 1352
1435, 1379, 1333,  241, 1404
1436,  166, 1247, 1336, 1364
1437,  118, 1481, 1339, 1485
1438, 1339, 1368, 1504,  132
1439, 1341,   94, 1294,   95
1440, 1237,  172, 1275, 1478
1441,  260, 1371, 1343, 1382
1442, 1346,  122, 1284, 1525
1443, 1285, 1347, 1538,   99
1444,  251, 1533, 1350, 1353
1445, 1248, 1350, 1404,  240
1446, 1359, 1342, 1401, 1552
1447, 1290, 1351,  179, 1522
1448, 1464, 1353, 1492,  250
1449,  179, 1358, 1366, 1532
1450, 1397,   95, 1410,   96
1451, 1344, 1357, 1372,  228
1452,   89, 1552, 1401, 1426
1453,   89, 1551, 1358, 1552
1454, 1326, 1359,  180, 1561
1455, 1417,  143, 1425, 1360
1456,  142, 1400, 1360, 1425
1457, 1361,  132, 1458, 1378
1458, 1383, 1334, 1393, 1365
1459, 1365, 1393, 1530, 1314
1460, 1367,  260, 1382, 1521
1461, 1390,  127, 1411,  144
1462, 1357, 1344,  240, 1404
1463,  107, 1316, 1507, 1375
1464, 1524, 1376, 1363,  170
1465, 1510, 1377, 1547,  126
1466,  114,  127, 1362, 1480
1467, 1457, 1378, 1458,  133
1468, 1308,  252, 1379, 1533
1469, 1317, 1380, 1507,  108
1470,  167, 1392, 1384, 1405
1471, 1369, 1412, 1395,  128
1472, 1342, 1388, 1402, 1401
1473, 1389,  131, 1481, 1260
1474, 1421, 1391, 1418,  141
1475, 1394, 1400,  142, 1413
1476, 1447, 1396, 1454,  106
1477,  100, 1397,   96, 1538
1478, 1405,  166, 1407,  167
1479,  143, 1417, 1399, 1429
1480, 1402, 1439, 1426, 1401
1481, 1406,   89, 1426, 1437
1482, 1407,  163, 1415,  167
1483, 1408, 1415, 1419,  168
1484, 1504, 1409, 1458,  132
1485, 1430, 1390,  144, 1542
1486, 1413, 1420, 1422,  141
1487,   91, 1388, 1416, 1451
1488, 1368, 1418, 1391, 1504
1489,  142, 1425, 1420, 1413
1490, 1391, 1421, 1433,  140
1491,   96, 1410, 1423, 1436
1492, 1437, 1424,   92, 1406
1493, 1431,  143, 1429, 1441
1494, 1440, 1427,   92, 1482
1495, 1414, 1428, 1438,  285
1496, 1432, 1412, 1430,  151
1497, 1425,  143, 1543, 1420
1498, 1453, 1442,  154, 1450
1499, 1293, 1435,  162, 1332
1500,   96, 1436,   97, 1538
1501, 1423, 1437, 1426, 1439
1502, 1436,   91, 1451,   97
1503, 1461, 1440, 1482,   93
1504, 1449, 1441,  151, 1306
1505, 1452, 1431, 1441, 1449
1506,  155,  139, 1442, 1453
1507, 1443, 1422,  153, 1307
1508, 1445, 1447, 1446,  162
1509, 1447, 1445,  163, 1396
1510, 1448,  152, 1517, 1543
1511, 1452,  152, 1448, 1431
1512, 1452, 1449, 1270, 1304
1513, 1455,  120,  121, 1550
1514, 1541,  112,  101,  100
1515, 1541, 1347, 1539,  111
1516,  641, 1460,  767, 1479
1517,  239, 1257, 1462, 1463
1518, 1467,    5,  298, 1468
1519, 1237, 1478, 1470, 1471
1520, 1475,  173, 1473, 1474
1521, 1483,  138, 1502, 1484
1522, 1487,  423,  424,  489
1523, 1506, 1242, 1491,  174
1524, 1496, 1189,  260, 1367
1525, 1501,  824, 1519,  941
1526, 1502,  138,  133,  139
1527, 1503, 1246, 1329, 1354
1528,  127,  114, 1510, 1511
1529, 1517, 1422, 1420, 1543
1530, 1519,  824, 1545,  985
1531, 1521, 1325, 1268, 1549
1532, 1354, 1522,  179, 1532
1533, 1446,  105, 1332,  162
1534, 1526, 1363, 1376,  171
1535, 1528,  490,  492,  548
1536, 1531,   88, 1309, 1366
1537, 1535, 1446, 1447,  106
1538, 1346,  106, 1550,  121
1539, 1552, 1351,  180, 1359
1540, 1562, 1553,  940, 1015
1541, 1184,  887,  942,  893
1542, 1555,  981, 1568,  917
1543,  230, 1187, 1556, 1557
1544,  261, 1289, 1558, 1559
1545, 1571,  679, 1607,  690
1546, 1573,  735,  201,  881
1547,  997,  953, 1577, 1578
1548, 1583,  189,  692, 1190
1549, 1584, 1112, 1595,  243
1550,  888,  868, 1585, 1586
1551, 1609, 1585,  243, 1595
1552, 1057, 1597, 1039, 1612
1553, 1605,  865,  207, 1574
1554,  754, 1619,  225, 1629
1555, 1068, 1621,  245, 1625
1556,  882,  931, 1624, 1635
1557, 1628, 1005, 1632, 1055
1558, 1630,  245, 1621, 1074
*Nset, nset=body, generate
    1,  1635,     1
*Elset, elset=body, generate
    1,  1558,     1
** Section: Section-element
*Solid Section, elset=body, material=Material-Al
0.375,
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
          0.,    -0.866025,           0.
*End Instance
*Instance, name=Part-1-2, part=Part-1
       -0.12,     0.816026,           0.
       -0.12,     0.816026,           0.,        -0.12,     0.816026,           1.,         180.
*End Instance
*Node
      1, -0.119999997, -0.0499989986,           0.
*Node
      2,           0.,           0.,           0.
*Nset, nset=RP-1
 1,
*Nset, nset=RP-2
 2,
*Nset, nset=Set-fix_st, instance=Part-1-1
  58,  59,  60,  61,  62,  63,  64,  65,  66,  67,  68,  69,  70,  71,  72,  73
 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385
 386,
*Elset, elset=Set-fix_st, instance=Part-1-1
  176,  177,  178,  179,  249,  254,  256,  257,  263,  270,  275,  276,  279,  493,  495,  503
  504,  567,  568,  569,  570,  571,  572,  573,  574,  575,  576,  618,  626,  812, 1347
*Elset, elset=_Surf-dy_S4, internal, instance=Part-1-2
 176, 254, 256, 495, 569, 571, 572
*Elset, elset=_Surf-dy_S2, internal, instance=Part-1-2
  178,  249,  493,  504,  567,  568,  570,  618,  626, 1347
*Elset, elset=_Surf-dy_S1, internal, instance=Part-1-2
 257, 270, 279, 573, 812
*Elset, elset=_Surf-dy_S3, internal, instance=Part-1-2
 177, 178, 179, 263, 275, 276, 503, 574, 575, 576
*Surface, type=ELEMENT, name=Surf-dy
_Surf-dy_S4, S4
_Surf-dy_S2, S2
_Surf-dy_S1, S1
_Surf-dy_S3, S3
*Elset, elset=_Surf-st_S4, internal, instance=Part-1-1
*Elset, elset=_Surf-st_S2, internal, instance=Part-1-1
*Elset, elset=_Surf-st_S1, internal, instance=Part-1-1
*Elset, elset=_Surf-st_S3, internal, instance=Part-1-1
*Surface, type=ELEMENT, name=Surf-st
_Surf-st_S4, S4
_Surf-st_S2, S2
_Surf-st_S1, S1
_Surf-st_S3, S3
*Elset, elset=_m_Surf-st_S4, internal, instance=Part-1-1
   56,   72,   73,   74,   88,  113,  135,  242,  334,  355,  379,  387,  408,  520,  521,  533
  535, 1348
*Elset, elset=_m_Surf-st_S2, internal, instance=Part-1-1
   75,   84,   95,  101,  108,  109,  118,  124,  128,  133,  137,  138,  139,  143,  209,  210
  221,  225,  229,  241,  243,  393,  394,  395,  396,  406,  522,  523,  524,  525,  526,  527
  528,  532,  534,  538,  540,  563,  564,  565,  566, 1314, 1319, 1321, 1323, 1357, 1518
*Elset, elset=_m_Surf-st_S3, internal, instance=Part-1-1
  81,  82, 112, 154, 155, 156, 196, 205, 222, 223, 224, 232, 235, 239, 287, 331
 352, 359, 433, 442, 530, 536, 542, 544, 545, 546, 547, 548, 549, 550, 551, 552
 553, 555, 556, 559, 560, 561, 710
*Elset, elset=_m_Surf-st_S1, internal, instance=Part-1-1
  83, 190, 200, 204, 240, 322, 330, 354, 358, 360, 385, 465, 529, 539, 541, 557
 562, 601, 962
*Surface, type=ELEMENT, name=m_Surf-st
_m_Surf-st_S4, S4
_m_Surf-st_S2, S2
_m_Surf-st_S3, S3
_m_Surf-st_S1, S1
*Elset, elset=_s_Surf-dy_S4, internal, instance=Part-1-2
  535, 1348
*Elset, elset=_s_Surf-dy_S2, internal, instance=Part-1-2
*Elset, elset=_s_Surf-dy_S3, internal, instance=Part-1-2
*Elset, elset=_s_Surf-dy_S1, internal, instance=Part-1-2
 562, 601, 962
*Surface, type=ELEMENT, name=s_Surf-dy
_s_Surf-dy_S4, S4
_s_Surf-dy_S2, S2
_s_Surf-dy_S3, S3
_s_Surf-dy_S1, S1
** Constraint: Constraint-1
*Coupling, constraint name=Constraint-1, ref node=RP-1, surface=Surf-dy
*Kinematic
** Constraint: Constraint-2
*Coupling, constraint name=Constraint-2, ref node=RP-2, surface=Surf-st
*Kinematic
*End Assembly
*Amplitude, name=Amp-1
             0.,              0.,             0.5,              1.,              1.,              0.
** MATERIALS
*Material, name=Material-Al
*Elastic
 1e+07, 0.33
*Plastic
21000.,0.
** INTERACTION PROPERTIES
*Surface Interaction, name=IntProp-1
1.,
*Friction, slip tolerance=0.005
 0.3,
*Surface Behavior, pressure-overclosure=HARD
** BOUNDARY CONDITIONS
** Name: BC-fix Type: Symmetry/Antisymmetry/Encastre
*Boundary
RP-2, PINNED
** INTERACTIONS
** Interaction: Int-snapfit
*Contact Pair, interaction=IntProp-1, type=SURFACE TO SURFACE
s_Surf-dy, m_Surf-st
** STEP: Step-connect
*Step, name=Step-connect, nlgeom=YES, inc=1000
*Static
0.01, 1., 1e-05, 0.05
** Name: BC-motion Type: Displacement/Rotation
*Boundary
RP-1, 1, 1, 0.12
RP-1, 2, 2, 0.049999
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
RE: Combined Displacement/Rotation BC?
The main problem here is that it’s really hard for these hooks to connect due to their geometry. Maybe you could redesign them a bit (if it’s not possible proceed to further suggestions). The way they enter (BCs) should also be different but this requires many tests to get it right. And finally mesh could be refined in the contact area.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
Modern cars, trucks, and other vehicles feature an ever-increasing number of sophisticated electrical and electronic features, placing a larger burden on the wiring harness that enables these new features. As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - Modeling and Optimizing Wire Harness Costs for Variation Complexity
This paper will focus on the quantification of the complexity related costs in harness variations in order to model them, allowing automated algorithms to optimize for these costs. A number of real world examples will be provided as well. Since no two businesses are alike, it is the aim of this paper to provide the foundational knowledge and methodology so the reader can assess their own business to model how variation complexity costs affect their business. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
