Sleeve size for 1-1/4 schedule 40 and schedule 80 removable rails
Does anyone have a suggestion for sleeve sizes to use for removable guardrails - 1-1/4" sch 40 and 1-1/4" sch 80?
All I know is P/A and Mc/I
RE: Sleeve size for 1-1/4 schedule 40 and schedule 80 removable rails
Bagman2524:
So you have 1.66” for an o.d. on the 1.25” pipe posts; and 1.38” i.d and .14” wall thk. for the sch. 40 pipe; and 1.278” i.d. and .191” wall thk. for the sch. 80 pipe. Now, look for round mechanical tubing (at most steel supply outfits), various material specs., with a slightly larger i.d. and a comparable wall thk. for either one of the pipe posts, and you’ll be in the right ball park. Maybe 2.125” dia. w/ .188 wall thk. and 1.75” i.d.; and 2.25” dia. w/ .25” wall thk. and 1.75’ i.d., should get you started. The sleeve gets welded to some sort of a base pl. with A.B’s. and it might be 8” long, and is drilled for a through bolt on its neutral axis, w.r.t. its bending stresses (that is parallel to the direction of the railing). The sleeve could also be embedded in the conc. The annular space btwn. the two tends to fill with junk and rust, so you have to deal with that.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - A Guide to 3D Printing Materials
When it comes to using an FDM 3D printer effectively and efficiently, choosing the right material at the right time is essential. This 3D Printing Materials Guide will help give you and your team a basic understanding of some FDM 3D printing polymers and composites, their strengths and weaknesses, and when to use them. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
