hi, i am looking for a software tha
hi, i am looking for a software that can design and analyse various calculations of poles(street light poles and solar light poles). need to calculate various types of loads its strength and all about street light poles and solar light poles
pls suggest the best software to do this.
RE: hi, i am looking for a software tha
Also a pole ( cantilever) should be easy to design by hand :)
Open Source Structural Applications: https://github.com/buddyd16/Structural-Engineering
http://www.powline.com/products/pls_pole.html
I am not familiar with light pole design or if there is another code published specifically for them (AASHTO perhaps?) that you would need to use for design, but if not, PLS-Pole seems to hit on what you are asking for.
There could also be much more specific design software out there, I'm just not aware of it either.
I am not familiar w/ PLS Pole, but as long as you can select the appropriate geometry and material of the pole in the software, PLS Pole should work.
