Flow calculation through orifices in series
I have two orifices ( Capillary type ) in series in H2 service at 30 kg/cm2_g and 40 Deg C. Line size is 0.75 inch. As per their datasheet
1st Orifice: Do = 0.51 mm & L = 50 mm ; Pressure drop at Max flow : 6.89 kg/cm2_g
2nd orifice: Do = 0.51 mm & L = 50.83 mm ; ; Pressure drop at Max flow : 3.44 kg/cm2_g
Data sheet mentions that both are restriction (choke) type venturi.
However, when I calculated critical pressure under the given condition to check the whether the flow is choked or not, Critical pressure comes out to be 15.2 kg/cm2_g, which is less that the combined pressure drop the two orifices can provide.
In plant, pressure drop measurement is only available across the last orifice.I need to calculate flow rate under operating conditions.
Need expert guidance.
RE: Flow calculation through orifices in series
Did you consider the separation, pressure recovery, and that Pcrit1 ≠ Pcrit2?
Good luck,
Latexman
Engineers helping Engineers
My understanding is that Pcrit is property of service gas at given temperature and pressure. Pcrit is not a function of orifice dimensions.
Also, since it is restriction orifice, I am assuming no pressure recovery.
It does look a little strange. Are you sure of all the pressures used?
Also what is the definition of restriction(choke)? It doesn't say choked flow.
A drawing of the orifice and the actual data sheet would help.
I am also not sure what 'restriction(choke)' mean. I am only assuming it means that choked flow.
Assuming it not choked flow, D/L ration is 0.009. Hence usual orifice formula wouldn't apply.
I do not have drawing of the orifice. Data sheets mentions ' It is a restriction(choke) type venturi and is to be omni-directional'.
Max design flow is 0.226 Kg/hr.
I can not share actual data sheet as this being a propriety information. I can help you with more detail if needed.
Quote (R4j4n)
Yes, but it applies dynamically and will be affected by the separation between the two orifices and depending on how that separation affects pressure recovery. Basically, Pcrit2 depends on Pcrit1 and the loss in orifice 1. T2 ≠ T1 and P2 ≠ P1, so Pcrit2 ≠ Pcrit1.
On the multiple orifices I have seen and designed, enough separation is given (5 pipe diameters) so pressures recover between orifices.
Good luck,
Latexman
What is it though that you're actually trying to do?
You have an inlet pressure of 30kg/cm2;. At max flow you have a certain pressure drop in two stages.
What is changing? you mention "operating conditions". Are these different to the figures you've supplied?
Orifices are great simple devices, but they are not good when process conditions change.
You have max flow I assume from the data sheet.
Long or short cone venturi devices are not called orifices. Venturi flow meters are employed in services where high pressure recovery is required. If I remember correctly, permanent dp is less than 20% of pressure drop at vena contracta for venturi devices. If both devices are operating in choked flow, would agree there is something odd about the 6.9kg/cm2 dp for the first venturi; the second one with dp of 3.4kg/cm2 dp seems more reasonable at first glance.
A 7kg/cm2 dp on the first device seems more like the performance of a regular thick plate restriction orifice, provided you have the appropriate t/d on the plate thickness.
Use of terminology here is confusing: capillary(?) orifice ; orifice ; venturi
Quote (LittleInch (Petroleum))
At current conditions:
DP across the second orifice is 2.8 Kg/cm2_g. I am trying to calculate flow in this case.
Critical flow venturis are used where precise restrictions are required.
https://www.ceesi.com/services/critical-flow-ventu...
As long as the dimensions are unchanged, and the device has been recently inspected, the flow rate is only determined by the upstream pressure.
Most plants do not have certified measurment lab facilities...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
Modern cars, trucks, and other vehicles feature an ever-increasing number of sophisticated electrical and electronic features, placing a larger burden on the wiring harness that enables these new features. As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - Modeling and Optimizing Wire Harness Costs for Variation Complexity
This paper will focus on the quantification of the complexity related costs in harness variations in order to model them, allowing automated algorithms to optimize for these costs. A number of real world examples will be provided as well. Since no two businesses are alike, it is the aim of this paper to provide the foundational knowledge and methodology so the reader can assess their own business to model how variation complexity costs affect their business. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
