Seized studs on discharged flange of Between bearing pump
Dear Engineers,
I work as a shop Engineer for a pump repair shop and recently we received a Single stage-Between bearing-Radially split-Double suction impeller pump (BB2 per API 610). I found that some of the discharge flange studs were seized and customer (Refinery) had to cut them (see attached picture). I wanted to ask you if you have experience this problem before. What were the possible solutions? What can be the root cause of this issue. We will remove the studs and repair the threads but I wanted to bring this topic up for discussion. Thanks
RE: Seized studs on discharged flange of Between bearing pump
Ted
