Does NUMMRG,ALL command in ANSYS APDL Glues all the surfaces together
(1)I use NUMMRG,ALL command in ANSYS APDL and when I run Modal analysis its showing the areas are not glued together. Does NUMMRG,ALL command glues together all the surfaces. I am attaching the MACRO below.
(2) And the last line in the code "*SET,TSF,YSF *(1+FS), ! TRUE STRESS OF FLANGE (error)" is showing not a valid command and I have run this command singly to execute.
please answer
RE: Does NUMMRG,ALL command in ANSYS APDL Glues all the surfaces together
I would post your questions in the Ansys forum.
I would perhaps suggest to use Workbench (WB) because you have been doing this for weeks, and this could be done in minutes in workbench - APDL has a very steep learning curve. WB is using APDL in the background so it is the same just that the GUI is much easier to use (one can say that WB is another pre/post processor for APDL). In WB/DM one can make everything parametric anyhow.
As for this: I told you before to use APTN and then together with NUMMRG,ALL. So remove that part (ASBL,...) and use this
CODE --> apdl
L, 200, 202
L, 201, 203
APTN,ALL
NUMMRG,ALL
DFLNG = 7850 ! DENSITY OF FLANGE & STIFFNER MATERIAL
For the mesh use ESIZE,0.01, and AMESH,ALL
Thank you sir,
It worked
No worries - good that it is working
The last line in the code "*SET,TSF,YSF *(1+FS), ! TRUE STRESS OF FLANGE (error)" is showing not a valid command and I have run this command singly to execute. the error is like this" no longer a valid command charcater - please use !*SET,TSF,YSF*(1+FS),! TRUE STRESS OF FLANGE
please answer
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
