Determining plasticity parameters of AISI 4130 Steel
Hi, I hope that someone can help me.
I am currently investigating the crash deformation of a tubular space frame chassis on Ansys (Explicit Dynamics)
Ansys has a number of preset Explicit Dynamic Materials that define the characteristics required to help model the material requirements for use with a high impact collision. Unfortunately however, is does not feature 4130, the closest i found was 4340 (which is a much stronger material.)
Does anyone on here have or could point me in the direction of any information that could help me defining the plasticity characteristics of the material (ideally johnson cook strength data) for an 4130 stainless steel.
Thank you
Ryan
RE: Determining plasticity parameters of AISI 4130 Steel
you need to look at the aircraft industry, SAE 4130 is a low alloy Chrome moly steel, not stainless, it is extensively used in welded aircraft steel tube fuselages, look there for analysis.
B.E.
You are judged not by what you know, but by what you can do.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
