Creating a center Point of Hole, Circular Cutout, Circular Pocket, Userpattern.
Hi Macro Experts,
I am new to this vba scripting.
My requirement is to create the center point of holes. But the hole is not only made up of hole option in part modelling work bench, In some parts holes are created using circular cutouts in sheetmetal workbench, In some places it may be used circular pocket option. In someplaces it may be made up of userpattern.
I have an idea but i dont know how to script it in vba.
Possibility - 1
First method is to extract the surface of the part
determine the circle cuts or hole cutout region in that surface.
create the center point for the holes cutouts in the surface.
Possibility - 2
Getting user input to select the hole edges
Either use the same selected reference to create the center point or extract that edge then create the center point.
Can anyone help me with scripting for this scenario.
Any new ideas apart from creating coordinated holes from drawing are high appreciated.
Thanks in advance.
Cheers!
Shankar.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - A Guide to 3D Printing Materials
When it comes to using an FDM 3D printer effectively and efficiently, choosing the right material at the right time is essential. This 3D Printing Materials Guide will help give you and your team a basic understanding of some FDM 3D printing polymers and composites, their strengths and weaknesses, and when to use them. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
