Bearing preload spacer
I want to design collapsible spacer for providing preload on taper roller bearing. The distance between bearing to bearing is 38.5 +/- 0.150 mm. Please guide, how to design spacer length and yield point as well.
RE: Bearing preload spacer
So, something like the crushable steel tube used for differential front yokes?
What is the bearing ID bore?
Are the inner or outer races rotating?
Due to a most unfortunate lack of up-front information I am assuming you are using a pair of opposing taper roller bearingS.
In this arrangement -
https://farm5.staticflickr.com/4822/31377586177_22...
Is this a new design/application?
If an existing design, or thoroughly done new design, is there an assembled rotating torque you are shooting for ? ( which is often the measurable objective of preload ).
Do you know the preload force you want to apply?
Are the loads and rpm (3000 rpm continuous and potentially over 5000 rpm) at all similar to the pinion bearings in some automotive axle that uses a crush sleeve for preload?
To "design" a crush sleeve I'd try to adapt a 5-10$ commercially available part to my purposes. And maybe ponder that OEM design after the project is running successfully
Automotive crush sleeves come in different configurations.
Some are quite short, with deep convolutions that would seem to crush easily.
https://www.napaonline.com/en/p/NDP6351031
http://www.peachparts.com/shopforum/attachments/di...
Others are quite long with subtle cone shapes that by my WAG inspection would appear to be more diffieult to crush.
http://www.gearinstalls.com/humes/pinion4.jpg
Hi Mongrel, Thanks for responding, yes you are correct. I am talking about crushable spacer which placed like sandwich in between both pinion roller bearing.
Hi Tmoose,
Yes, it is new design and need you support to under the crush sleeve force vs deflection principle.
Well, the wall thickness of spcaer is 2.5 mm, Bearing to bearing differential housing distance 38.5 +/- 0.150 mm,
Tightening torque 80 - 380 NM and at preload condition, bearing rotation torque will be 2.5 to 4.5 NM which is suggested by bearing supplier in back to back arrangement.
Static load capacity of bearing 65000 N.
That what I have from design.
So I want to understand crush/collapsible spacer load vs deflection recorvey chart.
Is there room for a bellview spring and maybe some spacers to provide the required preload? Their force/deflection curves are well known.
Timelord,
Could you help me to understand this curve and how I can generate this performance curve?
I don't know anything about this technology.
No special technology. Bellview springs are very high force small displacement springs. They are basically coned washers which flatten under load.
Google "bellview spring" and you will see what they are.
Your question leads me to believe you are not an engineer, as you have never heard of a bellview spring nor understand a force/deflection curve.
The force/deflection curve is a property of the spring and is usually supplied by the spring supplier. If you do not understand what a force/deflection
curve is, you better not be designing anything that lives will depend on. Hire an engineer in that case.
That said, bellview springs can be tricky when applying because unlike other types of springs, friction enters the picture.
... "Belleville" washer/spring.
OOPS.... Brian is correct about the spelling. My bad.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The New World of Thermoplastic Manufacturing
Digital-direct thermoplastic manufacturing offers exceptional quality, opens the door to novel design parameters not possible with injection molding while also bypassing the long lead time and up-front investment in injection molding tooling, offering a better total value proposition. Download Now
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
