Reservoir mixing (homogenization) calculations
I have a reservoir, 65'W x59'L x 11.5' D full of water, I want to ensure homogenization being that I will test pH at the outlet, and dose acid or base accordingly to maintain specific pH range.
Is floating mixers the best way to ensure homogenization in a basin this size, or should I be concentrating on a different technology that may have a lower capital cost?
If floating mixers is an acceptable mixing method, How should I calculate the number of floating mixers, motor power, diameter/type of impellers?
Thank you
RE: Reservoir mixing (homogenization) calculations
What is the hhydraulic detention time and how quickly can you dose the acid or base?
Ashtree
"Any water can be made potable if you filter it through enough money"
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Considerations for choosing a 3D printing technology
The adoption of 3D printing into major companies’ product development life cycles is a testament to the technology’s incredible benefits to consumers, designers, engineers and manufacturers. While traditional production methods have limitations in manufacturability, 3D printing provides unparalleled design freedom due to the additive method of building parts layer by layer. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
