Contact US
using of sittfener to adjust for out of tolerance in a tank API 650
hello everyone,
is using stiffener to achieve tolerance acceptable in API 650?
i read somewhere that it's prohibited but i can't seem to find it in the code
thanks
RE: using of sittfener to adjust for out of tolerance in a tank API 650
"Question: Is it permissible to install stiffening rings on cone roof tanks to maintain the roundness, peaking, and banding requirements set forth in Section 5?
"Answer: No."
This is an interpretation from November 4, 1994, to the Ninth Edition of API-650.
I would say that question and interpretation could be taken different ways, though. There's nothing that says you can't put additional stiffeners not required by design on a tank. But the point is, you shouldn't be using stiffeners to force an out-of-tolerance shell into the tolerance.
Nice memory !!!
thank you all for your reply .
JStephen,
Where can i find that interpretation? i found the document "technical inquiries for API standard 650" online from the api committee website but when i search for that one it doesn't show up there.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
