Contact US
Difficulty with Modeling a flat slab structure with drop
I have been working on a project to submit for my PG program where in I have to model a structure in L shape with 6m spacing between columns and of 10 stories. The type of slab configuration adapted is Flat slab with drops and also shear walls protecting the corners on the building. Can somebody check and tell me what mistake i have been making since the deflections post analysis are beyond normal (500k mm). kindly help me correct my mistake and analyze this building using response spectrum method.
RE: Difficulty with Modeling a flat slab structure with drop
Hi Ali,
I changed the shell types from membrane to shell-thin, assigned a default mesh as opposed to Auto-Cookie Cut and manually split the shells over the column lines. See deflection results from the attachement (Max deflection = -1.189 mm)
Any reason why you assigned a membrane type slab specifically?
Hope this helps.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
