Bottom Plate thickness
Dear All,
May I know, is there any criteria in API 650, that the thickness of the Bottom plate shall be equal to the thickness of the First Shell course.
Also, should the thickness of the Annular plate (if used) shall be equal to the thickness of the Bottom plate.
Thank you in advance,
Jay,
Jay,
RE: Bottom Plate thickness
Usually, an annular plate is same thickness as the rest of the bottom, or thicker. I've never seen an annular plate thinner than the remainder of the bottom.
