Contact US
Reducers and enlargers on Up/Down stream of pumps
3
Good day all, Recently I am reading "Piping and instrumentation diagram development" written by Moe Toghraei.
In the centrifugal pump section, it wrote "on the suction side of centrifugal pump we never ever use and enlarger, and on the discharge side of a centrifugal pump we never ever use a reducer."
Can anyone help me understand this? Any comment? Thank you!
RE: Reducers and enlargers on Up/Down stream of pumps
You want the suction piping to be as big as possible (within reason, there are minimum velocity guidelines as well) to reduce NPSH loss for centrifugal pumps. This reduces the risk of cavitation occurring which is damaging to the pump. The author is saying, for example, if you had a 3" suction connection you would not supply 2" suction piping and enlarge to 3" at the pump.
The rule of thumb about avoiding reducing on the discharge side of the pump is primarily to avoid pressure drop issues. If your pump has a 4" discharge and you immediately reduce down to 3", your velocity will be higher which correlates to higher losses; additionally valves and other components will experience significantly larger pressure drop as well.
Thank you RVAmeche
"Never ever" is a bit strong though.
If you've got a small line and for some reason need a pump which just happens to have a larger inlet flange, but the numbers (pressure drop, velocity, NPSH etc) all check out then what are you going to do - Not connect it just because someone in a book decided that?
Same thing on discharge.
Sure it's not "normal" or "usual", but "never ever"?? Old Moe is going a bit far.
Oh and there is no such thing as an "enlarger", there are only reducers (as per ASME B 16.9). A bit strange sometimes when you're used to thinking in terms of fluid flow, but in the piping world they don't care so they are all reducers.
Good to know. In op's defense, Piping and Instrumentation Diagram Development (the book referenced by op) does use the terminology enlarger throughout section 6.14.1.2
This link shows that (if the link works, not sure):
https://books.google.com/books?id=ICONDwAAQBAJ&...
(2B)+(2B)' ?
Yes, I've seen it used before, especially by process engineers, but in piping terms an "enlarger" is just a reducer turned the other way in terms of flow direction.
You won't see it listed as "enlarger" on a piping diagram / isometric construction drawing and would get some strange looks if you tried it on site.
Agree with LI. Our process engineers are constantly calling them expanders/enlargers. In piping, there is no such thing. They're all reducers. That book appears to be written by a process engineer/consultant, so that's probably why you see it referred to as that.
"Thinking is the hardest work there is, which is probably the reason why so few engage in it."
-Henry Ford
ok piping world, no enlarger. Thank you all for the discussions. I was a completion engineer and about to step into a new role which might involved processing stuffs. That's why I am catching up before I start. This book I was referring to is actually a great start for me but it is always nice to have opinions from experinced professionals like you all to help me understand further. Once again, thank you all.
Thank you for all posts.
I know, in the world of piping we only have "reducer", but in the book I (as a process engineer) used enlarger whenever I wanted to refer to usage of reducer to enlarge the pipe diameter.
By the way I am Moe Toghraei, Shahyar is my middle name.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
