KBC PETRO-SIM - How to generate properties for heat as per HTRI
takiyasamsama
Chemical
MY
Dear All,
How do I generate properties (heat properties with enthalpy at each point) in KBC Petro-SIM? Something similar like below.
In KBC Petro-SIM, I don't usually use the heat exchanger for generating these table, I only use the stream function to generate properties since I only want to generate and know the properties of the compositions.
Look forward for helpful info from you guys, thanks!
