The number of history output requests in this analysis step has exceeded 10X the maximum value
mdama
Materials
GB
I got this error, How can I fix it?
I installed abaqus on my laptop and create the .inp file and then use HPC to run nip file. I can not find .env file.
Either reduce the frequency of history output saving or increase the limit by editing .env file. You can find more details in the „Using the Abaqus environment file” chapter of the documentation. The variable to be modified is called max_history_requests.
Thanks, but I can not find any .env file in the folders where Abaqus installed on my PC, It seems It's not there. And, since I run it the inp file on HPC, Shouldn't I find the .env file for the host? (or on my PC?)
You should be able to find .env file in the Abaqus installation folder under SMA/site. I suggest searching for .env files in this folder. Your PC should locate it quickly.
