Creating a Coincidence Constraint by picking geometry with Macro
I'm trying to add a Coincidence Constraint by picking geometry in a product after adding a component. I first recorded a macro and then added a user select to pick a cylindrical face. It creates the Constraint but it has the exclamation point next to it. Below is the code. Any help is appreciated. Obviously I'm new at this:)
Language="VBSCRIPT"
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim product1 As Product
Set product1 = productDocument1.Product
Dim constraints1 As Collection
Set constraints1 = product1.Connections("CATIAConstraints")
Dim reference1 As Reference
'Set reference1 = product1.CreateReferenceFromName("Product2/25-10302-0000.1/!Axis:(Selection_RSur:(Face:(Brp:(Chamfer1;4);None:();Cf11:());Chamfer1;Z0;G6719))")
'My Code added to make user selection
Dim oSel as Selection
Set oSel = productDocument1.selection
Dim Filter(0)
Filter(0)="Face"
Dim Result As String
Result=oSel.selectelement2(Filter, " Select Object", False)
Set reference1 =oSel.Item(1).Value
Dim reference2 As Reference
Set reference2 = product1.CreateReferenceFromName("Product2/Part40.1/!Axis:(Selection_RSur:(Face:(Brp:(Pad.2;0:(Brp:(Sketch.2;1)));None:();Cf11:());Pad.2_ResultOUT;Z0;G6719))")
Dim constraint1 As Constraint
Set constraint1 = constraints1.AddBiEltCst(catCstTypeOn, reference1, reference2)
product1.Update
End Sub
RE: Creating a Coincidence Constraint by picking geometry with Macro
I was able to accomplish what I wanted with the script below. Probably a little convoluted.
Language="VBSCRIPT"
Sub CATMain()
Dim Filter(0)
Filter(0)="Face"
Result=oSel.selectelement2(Filter, " Select Body in which you want to add", False)
Result="Product2/25-10302-0000.1/!Axis:("& oSel.Item(1).Value.Name & ")"
MsgBox Result
Set reference1 = product1.CreateReferenceFromName(Result)
product1.Update
End Sub
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - 10 Reasons to Choose CATIA on the Cloud
To compete in today’s fast-paced and competitive market, smaller and newer firms need a powerful platform that will enable them to compete with bigger players, without the heavy investments needed in computer hardware, software and personnel. Download Now
White Paper - Smart Manufacturing for Electronics
This white paper describes a transformative approach to electronics manufacturing made possible by the addition of Mentor Graphics to the Siemens family. It describes a completely digitalized strategy that supports both printed circuit board (PCB) and mechanical design and manufacturing, uniting the entire product lifecycle – from idea and production to customers and back. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
