FEMAP model connected surfaces exploding
CAWZ
1
Why are my surfaces not connected? Pipe is midsurfaced from a solid import and surface meshed. Nozzle/Stiffener Rings are solid elements from a CAD imported geometry. Upper plate portions are created with surfaces and meshed with plate elements. I've tried non-manifold add feature and surface gluing. When I analyze with an internal vacuum pressure and body acceleration all surfaces explode. What is the correct way to model these connections?
Maybe there's a gap between the surfaces too big for the glued contact to work properly. Increase the search distance. Also make sure that you defined this interaction properly. Remember that connecting solid to shell may require special considerations since these elements have incompatible degrees of freedom. And that you can check your connections using eigenfrequency extraction analysis.
Also take a look at this link:
i'm thinking co-incident nodes.
I don't really understand the issue.
Does the figures show the undeformed model? What do you mean by "all surfaces explode"?
What solver are you using?
My first thougt is like rb1957, have you merged coincident nodes?
Thomas
Maybe you don’t use Geometry->Surface->NonManifold Add, don’t forget to set reasonable tolerance.
