Contact US
pipe or tube
pipe or tube
pipe or tube
what is the difference between "pipe" and "tube" ? and what about "piping"
RE: pipe or tube
Google "pipe or tube", plenty of info' to explain the differences.
RE: pipe or tube
thanks. Clear
RE: pipe or tube
A "pipe" is used for fluid power or transport systems, whether it be in a plant, pipeline, residential plumbing, etc.. It is referred to by it's nominal diameter, which does not necessarily coincide with it's actual outside or inside diameter, and a schedule which determines it's wall thickness. Engineers are generally interested in the ID of the pipe. They are also generally more rigid than tubing and come in a much larger size range.
A "tube" can also be used for fluid power systems, however, it can also be used in structural applications as well. This can cause the shape of the tube to be round, square, or rectangular. Tubes are referred to by their outside diameter and wall thickness (or gauge), and are generally less rigid than piping. Tubing is often more expensive than piping due to higher manufacturing tolerances.
"Thinking is the hardest work there is, which is probably the reason why so few engage in it."
-Henry Ford
RE: pipe or tube
Are pipes mostly tubular in shape, but not all tubes are also pipes?
Tube is mostly a shape. Pipes generally have stuff going through them.
RE: pipe or tube
You can order things from vendors that are called pipes. In North America, pipes are based on a standard that specifies outside diameters and wall thicknesses. Beyond that, I would say that if someone insists on calling it a pipe, it is a pipe.
JHG
RE: pipe or tube
Actually, in North America, at least what's known as common or iron pipe, is NOT sold based on its outside diameter or wall thickness, but rather is specified as described by DGrayPPD above. Tubing, on the other hand, irrespective of the shape of the cross-sectional profile, is sold by the outside dimension(s) and the wall thickness.
The item below should help explain these differences:
https://www.sharpeproducts.com/pipe-or-tube-unders...
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: pipe or tube
My interpretation is "pipe" will be the the schedule sizes that @JohnRBaker's link references. I'll also take the steel grade to be A53. When I see "tube" I usually think (and correct the reference) to an RHSS size. Yield strength, diameter, and wall thickness will be different compared to a pipe. I think verbally pipe and tube are used interchangeably, but in written form I won't call something that needs to be an HSS a "pipe".
RE: pipe or tube
JohnRBaker,
I did not claim that the nominal size equals the actual OD. smile
JHG
RE: pipe or tube
pipe is generally rigid and not intended to bend.
most tubing is flexible enough to bend. there are tools for forming an elbow into copper tubing or stainless steel tubing once during initial installation. heat exchanger tubing is an exception to this terminology though.
(2B)+(2B)' ?
RE: pipe or tube
I disagree about bending as a distinction. Schedule 40 and schedule 80 rigid conduit differ from “pipe” in that interior is smoother. Conduit certainly gets bent.
RE: pipe or tube
Now conduit introduces a whole new animal to the discussion. And while it's true that pipe can be bent, it usually entails a lot of heat being applied before attempting to actually bend it. Tubing, at least copper, and some of the other mild steel varieties, can generally be bent without the need for heating it first.
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: pipe or tube
Besides the smooth interior, how does GRC (referred to as pipe to distinguish it from EMT, where T=Tubing) differ from similar size “pipe”? Plumbers don’t bend pipe because they can use small radius fittings, electricians bend both pipe and tubing because their universe doesn’t include small radius fittings.
You could probably hand the same 10 foot piece of stock to each trade and one would tell you it can’t be bent and the other would ask where you want it to fit.
RE: pipe or tube
They differ at least in function. The potential consequences of residual stresses in a bent pipe (imagine a high energy fluid system) are certainly different than those in a bent conduit. Of course there is a hydro test, and the is possibility of problems even with welding, but maybe the balance of factors plays out against bending. I’m not a mechanical guy, just offering how I’ve heard the terminology used and what I’ve seen.
(2B)+(2B)' ?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
