How to make components of an assembly fixed to each other but not the assembly itself?
Hi!
I have an assembly composed by 3 components. I did 2 mates to fix the two components to the other one.
However, if I try to move the assembly together, as one, the 3 parts with displace and scatter from the set.
How can I make components of an assembly fixed relatively to each other but not the assembly itself as a whole?
I am using SolidWorks 2018
Thank you,
Best regards,
Thank you,
Best regards,
RE: How to make components of an assembly fixed to each other but not the assembly itself?
Also, in a typical assembly the first part is fixed and will not move unless you change it to floating. So, when all your other parts are fully mated to the first one, they will not move either.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
