I have 4kV vertical motor. From Feb 6, 2019 until "the event" on April 9, 2019, the UMB (spherical roller thrust type) indicated high temperature spikes on numerous occasions. The spikes (+300F) were detected via remote indications and most lasted less than 30 minutes. On April 6, 2019 the motor was run in this condition for about 8 hours before being shut down. The motor was restarted on April 9, 2019 and within 20 minutes temperatures rose and smoke emitted from the UMB vent (the motor was shut down and sent to repair shop where bearing failure was confirmed. In ALL of the high temperature incidents, teams investigated only to find vibrations and sounds to be normal (temperatures to be normal once they arrived on the scene). Historical reviews of vibration checks and oil analysis results also found no evidence of a degrading trend. Vibrations and UMB oil samples are conducted every 3 months on this motor; more often if a problem is detected or troubleshooting is required.
So first, is a series of temperature "spikes" a common precursor to motor bearing failure? Secondly, is it common for a motor bearing to fail with only signs of high temperature spikes and no other symptoms (like oil or vibration problems)?
Thanks in advance,
mmain
Man is troubled by what might be called the Dog Wish, a strange and involved compulsion to be as happy and carefree as a dog --- James Thurber
Thanks in advance,
mmain
