can I active and deactive seismic load in one CAESAR II file?
Fatimah Awdhah
SA
Greetings,
I am dealing with a system going AG and UG, can I active the seismic load at the AG line only and then deactivate it at the UG?
please advise
thank you
Yes, it can be deactivated, in a similar fashion as it is activated. Just go to your desired node (from where, you don't need seismic affect),double click "Uniform loads" options, and replace g values with 0.
