Gaussmeter to verify motor field problem
i heard about possibility to make some measurements with gaussmeter (or similar) to check about winding condition of the motor,
anyone have experiences about it?
Could be usefull more than vibration analysis for electrical poiint of view?
Could you suggest some device to try?
RE: Gaussmeter to verify motor field problem
Whatever you are talking about is not in common use.
Maybe you can give some more details.
(2B)+(2B)' ?
@electripete
i saw an SKF instrumentation (but i'm not certain) moving on rear of the motor to evaluate the magnetic flux of it but i don't remember details
SKF has a gizmo that claims to tell you something about whether the electromagnetic environment is bad for your bearings, especially on a vfd motor.
https://www.skf.com/us/products/condition-monitori...
Is that what you're talking about? We have a resident expert skogsgurra who knows a lot of related background (search his old posts)
Btw that device is not monitoring winding condition.
(2B)+(2B)' ?
I have and occasionally use a Flux Coil from CSI (now Emerson-CSI) that is placed on the motor case and detects the flux field. Spectrum analysis can reveal electrical faults similar to (but not identical) motor current spectrum analysis. The Flux Coil can supplement vibrations, current, and sound spectrum analysis for machine diagnostics.
Walt
@strong
Exactly what i need, can you share here your experience with?
Do you think good help in electric problem?
What fault type this technology can reveal?
Regard
Personally, no.
Looking at the CSI paper, what are they trying to detect?
Quote:
The tests were designed to evaluate turn-to-turn shorts, of differing severity, and changes in voltage balance (for the 50 hp motor only) at different sensor locations about the motors
Shorted turns - with very few exceptions (there are a few isolated exceptions I've heard of on ungrounded system random wound machines), shorted turns progress generally progress quickly due to autotransformer effect causing large heating leating quickly to ground fault and motor trip. It's not very useful to monitor for something that will be apparent within a few seconds after you detect it.
Unbalanced voltages. I'd rather measure the voltages or compare the three phase currents. Failing that, vibration twice line frequency would probably increase (and I monitor vibration anyway, for reasons that are much more useful, like bearings). But I wouldn't want to have to get into the business of evaluating every vibration or flux change that might indicate voltage unbalance, unless there was some overheating, tripping, or abnormal currents noted.
The linked paper seems to be a research type paper. It's dated 2009, yet many years later this monitoring approach hasn't taken off for induction motors (something similar is used for shorted turns on sync generators I believe... big difference is that sync generator rotor circuit shorted turns can last a long time since the rotor circuit is dc and not subject to the autotransformer effect as induction motor stator). I don't see prominent mention (marketing) of flux monitoring technology in the literature of Emerson (successor to CSI) although they do provide a compatibility for gathering this data within their AMS condition monitoring software. Sensitivity depends on sensor location.
Color me skeptical.
(2B)+(2B)' ?
@electripete
yes this is what i want to understand.
This technique is already used?
It is really usefull as i think?
Are commonly use in a investigation techniques?
My full time job for the last 19 years is overseeing a program for monitoring / maintenance of plant electric motors. I haven't seen this method used.
My opinion, no. I tried to explain why in my previous post.
(2B)+(2B)' ?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
