Good soluble cutting fluid for CNC Turning?
Hi
I run a machine shop in England, UK and just wondered if anyone could recommend a good, stable soluble cutting fluid for machining steels and stainless steel upto 65mm diameter. We use a product at the moment that has a poor lifespan and want something we can re-use if possible.
We run Traub Fixed Head Machines, you can have a look at the link below for machine specs:
https://www.mmturnedparts.co.uk/plant-list/
Thanks in advance
RE: Good soluble cutting fluid for CNC Turning?
i understand you use a emulsion at the moment ("soluble cutting fluid"). the lifespan of that type of product depends very much on operating conditions - the lifespan may be shortened quite a bit when dirt or trampoil is mixed with the cutting fluid.
what type of problems do you have? poor quality of machining, bacteria growth, darkening or unpleasant smell?
the first thing to look for is trying to improve operating conditions (cleanliness). if that is not possible you might consider a "synthetic" fluid, a concentrate that is soluble in water (and thus no emulsion).
have you already spoken with the supplier of the present fluid? most problems with machining fluids are due to less than perfect housekeeping or choosing a less suitable fluid for the material to be machined.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The New World of Thermoplastic Manufacturing
Digital-direct thermoplastic manufacturing offers exceptional quality, opens the door to novel design parameters not possible with injection molding while also bypassing the long lead time and up-front investment in injection molding tooling, offering a better total value proposition. Download Now
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
