Hello, We need Distillation Co
St sh
IR
We need Distillation Column to separator alcohol vapor and steam in Resin Production process.How we can design this column?which standard or handbook can we use for this matter?
If you have zero experience, an expensive distillation column is a bad place to do your learning ...
Engage and contract the services of an experienced chemical engineering firm.
MJCronin
Sr. Process Engineer
You World usually boy Thisted type of equipment
Thank you MJCronin.
I think you are right...
CR
