CAN BUS protocol modeling on Matlab or some software - Wired and Wireless CAN BUS research
Williamdc5
Automotive
Jun 20, 2019
Hi everybody,
I need to modelate CAN BUS protocol because of my final posgrade work. Specifically I need to modelate wired CAN BUS and after that to modelate wireless CAN BUS (I did it physically by using RF 433 Mhz modules). But I want to get basic CAN Bus parameters, I mean, the data frame on both environments, bit times, delays between sent frame and received frame, etc.
How can I get this using Simulink of Matlab?
I use Vehicle Network Communication Tollbox to mount the wired CAN BUS model, but I don't know how to get CAN BUS basic parameters.
Thanks in advance
Will
Did you find anything? A quick google search should point you in the right direction. Standard data rates are 1 Mbps or 250 kbps.
Z
I thought the bihl wiedemann or prosoft a nice internet explorer interface that showed the diagnostics that you look like your trying to accomplish. This is different protocols but maybe get you in right direction of examples.
