Pump primer valve for suction lift
Hello
There is a pump that will have to lift from a tank. The bottom of the tank is about 15 feet below the pump inlet. This corresponds to about 7 psi of NPSHa, which is more than the 5.3 psi NPSHr.
But the suction line needs to remain filled somehow. Is there a primer valve that someone has used before for this type of application - to fully fill a suction header for a pump that lifts? Also an air purge valve?
Thanks for any input
RE: Pump primer valve for suction lift
Either way for this issue you either need a vacuum pump connected to the inlet line or a self priming pump. I'm not sure a self prime will lift 5m though.
Typically the pump needs a manual prime if it doesn't have some kind of assist mechanism, the case is opened and filled and that starts the prime to give it something other than air to work with. Depending on the lift required this doesn't always work, or sometimes needs more than one shot. After the initial prime the case should remain flooded, and a foot valve (check valve designed to be the point of suction in cases like this) will keep the suction line flooded to start fully primed from then on, unless the prime is lost.
High capacity auto air vents can be used, alone or in combination with manual air vents. The pump will pass air to the discharge side where it's easier to deal with, but venting is definitely needed to help get things started.
Once a day then operation non stop all day.
Every 10 minutes.
Fully automatic for unattended operation.
Flow rate.
Product being pumped.
Electric or engine driven pump.
More detail for your application will ensure better answers
Consult with seal vendor.
A well phrased question has answers in itself!!!
However the point about the inlet operating well below atmospheric pressure is a good one - the seals could easily leak air into the liquid unless specifically suitable.
