What is the proper method to compact soil above pipeline that will not cause it to fail?
What is the proper method to compact soil above pipeline that will not cause it to fail due to heavy compaction vehicle/equipment?
RE: What is the proper method to compact soil above pipeline that will not cause it to fail?
Using excavator buckets is not really good enough, nor is simply watering the backfill or dumping in large depths in one go.
Adding a small berm on top for a few days will also help as will watching it carefully over the first few days and preventing ruts and a trench to develop which will result in impact loads creating a failure.
https://www.uni-bell.org/Resources/Documents/42/in...
Ductile Iron Pipe Research Association has references for ductile iron (rigid) pipe:
https://www.dipra.org/ductile-iron-pipe-resources/...
