Removing air from underwater pipelines
I am in need of urgent help.
Can anyone please tell me how is the air removed from a offshore pipeline?
The air that gets accumulated within a pipe pumping liquid and since the pipe being below over the sea bed how do we remove the accumulated air from it?
For instance if the pipe is above over the land we use air valves to release this air similarly how do we do that when the pipe is underwater?
Sarvesh Rahate
Water & Wastewater Engineer
RE: Removing air from underwater pipelines
Pump faster.
Depending on your angles of the pipe you normally need about 1m/sec or faster velocity in the liquid to "blow out" or entrain all the air in the liquid.
Nowhere near enough information here to offer much more advice or comment.
try adding
#Service
~Fluid
Size of pipe
Flow rate / velocity
Length
why is this an issue
A diagram / profile sketch
pressure
end connection
The more info the better
Thank You LittleInch.
The fluid velocity within the underwater conduit is around 0.7m/s.
The main issues are:
1. The incoming flow at the particular pump station is low.
2. We have very less chance of reducing the diameter.
In this case is there a way out of the removing the air within the pipeline. Can this be done using valves or some other air removal mechanism? Is there any other alternative?
Awaiting for you reply!
Sarvesh Rahate
Well answer a few of the questions I asked and we might get somewhere.
However a 0.7m/sec I would imagine if this is a fairly gently sloping pipeline that the air has already been removed.
I ask the question again - why do you want to know / is there a particular problem?
Can you pig the line? That would sweep it out, but water / waste water lines tend not to include pig traps.
The details are as follows:
1. Service (Fluid) : Untreated Sewage (Wastewater)
2. Size of the pipe : 180 NB
3. MOC : HDPE
4. Flow / Velocity : 12 l/s / 0.7 metres per second
4. Length : 2000 meters
5. End Connection : Open to Atmosphere
6. Profile: Indicative (See attached)
I hope I have answered all the questions with all the information that I have.
Sarvesh Rahate
White Paper – Your Construction ERP RFP Checklist
Selecting business software for a medium to enterprise-sized construction concern is extremely challenging in large part because most enterprise resource planning (ERP) suites originated in the world of repetitive manufacturing and are therefore a poor fit for a project and asset-centric business. However, midsize to large contractors need the predictable, auditable processes that ERP delivers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
