Rooftop Unit Equipment Load
I have a question regarding catwalks at the rooftop. As per ASCE7-05, the uniform load is 40 psf and concentrated 300 lbs. Are these laods supposed to be applied together? I can't seem to find any text mentioning otherwise.
RE: Rooftop Unit Equipment Load
IMHO, yes, apply the loads simultaneously.
My reason has nothing to do with the document's text, just engineering judgement:
If the catwalk is designed so "closely" that adding exactly one, 300 lb. concentrated load (anywhere on the catwalk) to a 40 psf UDL makes the structure "unsafe", the design is unrealistically "precise".
www.SlideRuleEra.net idea
That's true. Thank You for the input.
In ASCE 7-10, 4.4 explicitly states it is either uniform OR concentrated, whichever produces the worst effect.
cgstrucg,
The Code does not require the UDL and the Concentrated loads to be applied concurrently. Essentially the UDS is for main carrying member design, and to provide sufficient mass in the building for the VFRS and the LFRS. The concentrated load often controls the grating design and the grating supports.
Long ago, my brother worked for a pacemaker manufacturer.
The pacemakers had a lead on them that the surgeon trimmed to length when installing it.
So as long as it was plenty long, it didn't really matter how long.
But, it was a highly regulated industry, so it had to be just so-so on paper.
So their slogan was "Measure it with a micrometer, mark it with a piece of chalk, cut it with a hatchet."
So, if I calculate seismic loads to 10 decimal places, that's the thinking behind it.
On the loads there- yes, see 4.4 and also note that it defines how big a "concentrated" load is. Also, see the load combinations in Chapter 2.
OSHA has some load requirements for stairs and ladders, but I don't see anything specific for general walking surfaces.
Cgstrucg:
The 300lb. concentrated load is sorta supposed to represent a 250lb. worker and 50lbs. of tools and equipment, per OSHA and others. Then, I wonder if you’ve ever seen two guys working close together on something, plus a few pieces of pipe or other bldg. material laying on the catwalk? I’m inclined to agree with SRE and also agree with jittles thinking, ‘which ever produces the worst loading.’
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
