I/O CARD - CONTROLLER
What's the function of i/o card and the controller in a control panel ?
RE: I/O CARD - CONTROLLER
Are you serious?
I/O stands for input / Output and cards translate the incoming signals into numbers for the control system to read and translate outgoing numbers from the control panel into electrical signals to activate or control equipment.
You get digital I/O which is on or off and
Analogue I/O which is a variable signal.
So e.g.
A valve open / close signal is a digital signal, but a pressure is a variable so is an analogue input.
The controller controls things.
Thank you for your response, but i wanted more details, fore example; the signal comes from the transmitter is 4-20 mA already which means it's already an electrical signal can be readable by the controller, so what exactly the I/O card do ?
thank you again
Turns the 4-20ma into a number between from memory 900 to 64000 which is then transmitted via an interface cable as an 8 bit digital number
This number is then converted in the controller into engineering units.
So a number say 24000 could be programmed to be 2 bar, 20 bar or 200 bar.
thank you, littleinch
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - 10 Reasons to Choose CATIA on the Cloud
To compete in today’s fast-paced and competitive market, smaller and newer firms need a powerful platform that will enable them to compete with bigger players, without the heavy investments needed in computer hardware, software and personnel. Download Now
White Paper - Smart Manufacturing for Electronics
This white paper describes a transformative approach to electronics manufacturing made possible by the addition of Mentor Graphics to the Siemens family. It describes a completely digitalized strategy that supports both printed circuit board (PCB) and mechanical design and manufacturing, uniting the entire product lifecycle – from idea and production to customers and back. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
