Cast Iron Repair Qualification Test
Please advise what standard/Code should be followed for Cast Iron Repair welding procedure qualification?
RE: Cast Iron Repair Qualification Test
Actually, I didn't know it could be done to any great extent.
Googling around, I find this:
"ISO 15614 consists of the following parts, under the general title Specification and qualification of welding procedures for metallic materials — Welding procedure test:
"— Part 1: Arc and gas welding of steels and arc welding of nickel and nickel alloys
"— Part 2: Arc welding of aluminium and its alloys
"— Part 3: Fusion welding of non-alloyed and low-alloyed cast irons..."
There's a section of ASME Section VIII that deals with cast iron, and I see that the cast iron materials required by that section are not included in the base metal tables in Section IX, so that doesn't look promising.
Probably doesn't really answer your question the way you want, but AWS has a guide for welding cast iron, but it's not a code. AWS D11.2.
And I don't have one handy at the moment, but have you checked any of the ASTM material specification on cast irons? The ASTM material specifications for cast steels have repair qualification requirements- they refer to ASTM A488. Perhaps the cast iron ASTM specs have a similar reference?
Now I could be wrong about cast Iron not be a weldable metal as it has been in past years, to my understanding at least, that cast iron could only be brazed.
Cast iron can be welded using an oxy-acetylene torch and cast iron rod (it is actually cast iron cast into "sticks". I've completed several cast iron repairs, but in each cast the entire part was preheated to a very high temperature and slow cooling ensured by burying the completed weldment in a charcoal fire that burned itself out overnight and cooled as the fire burned itself out.
As is the case with people, one shoe size doesn't fit all. Different cast irons have different properties by design. The repair I described would be fine for chilled cast iron, but the resulting properties wouldn't be the same as a chilled cast iron. The same is true with a repair made on ductile iron, the weld would revert back to a plain cast iron with the same brittle nature. It wouldn't have the ductility of the original ductile iron.
Best regards - Al
Well I learned something from GTAW
eBook - Mastering Tolerances for Machined Parts
When making CNC machined parts, mastering tolerances can be challenging. Are general tolerances good enough? When does it make sense to call out for tighter tolerances? Do you need a better understanding of fits, datums, or GD&T? Learn about these topics and more in Xometry's new e-book. Download Now
eBook – How to Choose the Correct Corrosion Testing Method
When designing a metal component, engineers have to consider how susceptible certain alloys are to corrosion in the final product’s operating environment. In a recent study by NACE (National Association of Corrosion Engineers), it was estimated that the direct and indirect costs of corrosion in the United States is approximately 6.2% of the GDP. In 2016, that cost exceeded $1 trillion dollars for the first time. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
