Effect of Control Valve Stroke Length on Response Time
I am considering replacing a 6" cage guided globe valve with a 6" back-pressure regulator. The globe valve has a stroke length of around 3 inches whereas the regulator has a stroke length of around 1 1/2 inches. The valve has to provide a very quick response time to limit back-pressure during pump start-up. It is likely that the back-pressure regulator will have a better response time due to the shorter stroke length?
RE: Effect of Control Valve Stroke Length on Response Time
IMO, the selection of the control valve vs. back-pressure regulator can be based on several factors, such as quick action vs modulating controlling function, adjusting flow rates, etc.
The regulator valve can be used to simplify the control function and replace the typical control valve if it can satisfy the process need.
sysengineer,mk3223,
When it is necessary to upgrade a Control Valve situation, be sure to investigate the "Cam-Flex" Control Valve (available in 6" size).
Check below:
https://www.setpointis.com/replace-globe-valves-ca...
Sometimes its possible to do all the right things and still get bad results
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
