Questions about seismic parameters on very soft clay, based on ASCE 7-16
I'm working on a site in Foster City on very soft Bay Mud, site class E. In running the software to obtain the seismic parameters, I got the message, "null-See Section 11.4.8" for Sms, Sm1, Sds, and Sd1. I don't have a copy of ASCE 7-16. I found a paper on what to do, but it was unclear. Any advice? Can I use ASCE 7-10 and get reasonable results? It's for a two-story house.
RE: Questions about seismic parameters on very soft clay, based on ASCE 7-16
My advice. Forget about trying to make some program work. Do the evaluation manually. Apparently the mud is one step above the properties of water.
It's been awhile since I've used Seismic Design Map software. Last time I did, USGS Hazard Tool was still up and running. Have you tried this one: https://seismicmaps.org/?
MTNClimber, I used the website you referenced. And two others. They don't work on site class E soils.
I could do it by hand, but the usual procedure is apparently no longer valid for E soils. Otherwise, I would get a result as I do using ASCE 7-10. I need to see Section 11.4.8 in ASCE 7-16, or just use 7-10. But I don't have a copy of ASCE 7-16.
Looks like you'll have to do a site specific analysis(Link). I don't work in CA so I'm not sure if it's needed for a two-story house. I would presume its not but I'll leave it to you or others to comment on that.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
